Totally Tubular
Totally Tubular
Old 11-22-05, 10:01 AM
USAZorro
Señor Member
USAZorro's Avatar
Quoted: 1491 Post(s)
Liked 1,090 Times in 638 Posts
Vittoria Rallys seem to be a pretty good compromise. They've worn well, ride well, have Kevlar, and aren't all that expensive. True, they aren't as nice as the latex tubed Wolbers I was on for awhile, but I liked them as well as anything else I've tried. Of course, I am a bit cheap.
USAZorro is offline
Old 11-22-05, 11:49 AM
cyclezen
OM boy
cyclezen's Avatar
Bikes: a bunch
Quoted: 515 Post(s)
Liked 644 Times in 438 Posts
Originally Posted by number6
3M Fast-tak is good. The reputation that it causes the base tape to separate is that often upon removal the base tape is bonded to the rim more effectively than the tire. Be sure to use the #8031, not #8001. the 001 stuff dries brittle.
Find this stuff truly tenacious. A lot of track riders used it cause it just doesn't pull off. I've not used it as rim cement mainly cause I want the option to REMOVE the tire without havin to cut it off
One use I have found though is to re-adher the basetape back to the casing after a repair - doesn't seem to work on all tires (I guess dependin on what is originally used on the tire casing) but for those that it does adher to, it is tenacious!
cyclezen is offline
Old 11-22-05, 12:19 PM
USAZorro
Señor Member
USAZorro's Avatar
I haven't had much trouble getting tires off, but perhaps I use it a bit more sparingly than others might. I've had success gluing tires even when I only put a single coat on the rim (and none on the base tape).
USAZorro is offline
Old 11-22-05, 12:32 PM
Bob S.
One thing that I am having difficulty finding is a decent 'tire bag' for tubulars. I am old school enough that I used to have a relitively flat, rectangular bag (I can't remember the brand name) which I strapped under the seat with a spare toe clip cinch strap. My memory is that is was specifically set up for tubulars. The bag was light weight, simple & effective. Big enough to comfortably carry a tire, kit & an odd tool or so, but also big enough that I could jam in 2 tubulars if I was in the mood.
Unfortunately, that bag ate the dust long ago. I don't like the way the tubulars fit in the under seat bags I find these days. They appear to be too areo (triangular in shape) which doesn't lend well to the tubulars. Just too many folds needed.
Any ideas or suggestions for decent tubular bags? Thanks Bob
PS. While on the subject... Any one know of a source for NOS Bata Bikers shoes?
Bob S. is offline
Old 11-22-05, 01:54 PM
cyclezen
OM boy
cyclezen's Avatar
Bikes: a bunch
Quoted: 515 Post(s)
Originally Posted by Bob S.
One thing that I am having difficulty finding is a decent 'tire bag' for tubulars. I am old school enough that I used to have a relitively flat, rectangular bag ... Big enough to comfortably carry a tire, kit & an odd tool or so, but also big enough that I could jam in 2 tubulars if I was in the mood.
Jandd Mountaineering
TireBag II
willhold 2, but looks pretty much like a traditional tiere sock in size, good stuff
most of the shops around here stock this if they carry Jandd...
Otherwise, Lone Peak (stilla round?) mkes one that is a bit more 'wedge', but still designed to carry a sewup with minimal folds - I gave mine to my son. Nice, w/coin pocket.
The Jandd, however, looks the real vintage deal.
Bata Bikers, dooooodeeee, prolly the same dealer/shop/place that has NOS stock on Bell Bikers...
cyclezen is offline
Old 11-22-05, 02:27 PM
USAZorro
Señor Member
USAZorro's Avatar
The Zeus tire holders are pretty nice too - I can only fit one tubular in though, and it doesn't hold anything else. Kind of a minimalist approach. https://cgi.ebay.com/ZEUS-spare-tire-...QQcmdZViewItem
USAZorro is offline
Old 11-23-05, 03:33 PM
wildjim
Guest
Posts: n/a
Quoted: Post(s)
I have used a Vittoria tire holder; which seems identical to the Zeus. It seemed to work it's self loose and fall off as the metal hooks are soft easy to bend metal. Another problem with the open air holder is that the spare tire is covered in road grime when you need it.
I also use a Cannondale tubular tire bag much like the Jandd described above. I believe that the tire bag is a better way to carry the spare but not as elegant as the tire strap.
Old 11-23-05, 03:46 PM
lotek
lotek's Avatar
Bikes: 1 trek, serotta, rih, de Reus, Pogliaghi and finally a Zieleman! and got a DeRosa
Quoted: 15 Post(s)
Liked 9 Times in 9 Posts
just use an old toe strap and let the tire hang
down under the saddle or seatbag. Show em
what you got, and put your faith in the
gods of cycling that you'll never need that
spare.
marty
Sono più lento di quel che sembra.
Odio la gente, tutti.
Want to upgrade your membership? Click Here.
lotek is offline
Old 11-23-05, 05:07 PM
luker
juneeaa memba!
Bikes: Crap. The box is not big enough...
Quoted: 13 Post(s)
Liked 3 Times in 3 Posts
sliding the topic over a little.
I rode a bike today that I hadn't ridden in a while, equipped with tubulars. About five miles out of town the rear tire developed a marked thump and on inspection there was a little bump just after the stem insertion point. I said oh well (carrying my spare in my back pocket) and finished out the 20 mile loop. When I got home I pulled the wheel off in preparation for putting on a new tire, let the air out of the tire, and found that I'd never glued the dam*ed thing on!
The tire gradually crept around the rim and bunched up behind the valve stem, making a hump. I shudder to think of all of the ways that disaster may have befallen me. So, in the interest of public safety, here's a little reminder from your safety committee chairman.
Check your glue job periodically.
Thank you, and good evening.
luker is offline
Old 11-23-05, 08:02 PM
Bob S.
Yes indeed. Earlier this summer I was going out for a ride with my son. I had just mounted a new tire on back. By the time I got to the top of my very steep drive way & started down the road, I felt that same thump & bump you described. I felt pretty foolish considering I had just schooled my kid on how to mount a sew-up. Good to be kept humble. Bob
Bob S. is offline
Old 11-25-05, 12:18 PM
avenan
Originally Posted by lotek
A word on Tufo gluing tape.
I had the oppertunity to change one of the tires recently (sprinter
with enough wear that it was unsafe). Removing the tire was no more
difficult than a tubular glued with mastik or any other glue.
There was significant sticky residue left on the rims that cleaned
up (with a little difficulty) with goo gone (or goof off).
This begs the question -- how safe/practical is it to use Tufo tape on non-Tufo tires? Its a given that it'll be marketed as being unsuitable for anything but Tufo tires, but they don't have a traditional base tape. Can a "normal" tubular be removed without pulling up the base tape?
avenan is offline
Old 11-25-05, 03:18 PM
lotek
lotek's Avatar
Quoted: 15 Post(s)
I think its mostly lawyerly weasle words concerning tufo tape and
normal tubulars.
I have not problem with the base tape (and this tire was on 2 years approx.)
pulling off the sprinter tire. I had heard that rumor but that wasn't the
case, again it was the normal tape, not the extreme.
Now what does that say about how well the tire was glued to the
rim? well I had sore fingers and 1 blister from trying to remove 2 tires.
The only tire that I have that has lost base tapes were some old Clement
Paris Roubaix and they are going to be shipped off for new tubes and base.
would I use the Tufo tape again? I don't think so. Not because I felt it
was unsafe, or pulled base tape but because of the godawful sticky mess
it left behind. At least Glue dries and can be chipped off.
marty
lotek is offline
Old 11-26-05, 07:39 PM
Road Fan
Road Fan's Avatar
Quoted: 1856 Post(s)
Liked 664 Times in 506 Posts
Lotek, what do you mean about sending the Clements away for tube and base tape replacement? Who does this sort of work? I have some nice old ones that could use some similar refurbishing!
Ken
Road Fan is offline
Old 11-26-05, 07:56 PM
lotek
lotek's Avatar
Quoted: 15 Post(s)
Tire Alert in florida does this kind of repairs.
lotek is offline
Old 11-26-05, 08:02 PM
wildjim
Guest
Posts: n/a
Quoted: Post(s)
https://www.tirealert.com/
Old 11-26-05, 09:32 PM
Motophoto
UberClydesdale
Motophoto's Avatar
Bikes: Klein,Panasonic
Is it just me that does this but I like to spread the glue on the rim and tire with my finger . Guess I am a big kid I like getting my fingers in the stuff and I feel I really know the glue is evenly spread over the entire surface of the tire/rim.
I am interested in the method others use to get the old glue off of their rims when changing tires?
Motophoto is offline
Old 11-27-05, 09:03 AM
Bob S.
My method has always been rather basic (kind of like mouthing method mentioned above: the finger smearing the glue around): A little bit or acetone, adheasive remover or similar solvent (what ever I happen to have laying around) on a rag. Basic, but works.
Bob S. is offline
Old 11-30-05, 03:36 PM
mollusk
Elite Fred
mollusk's Avatar
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 60 Post(s)
Liked 42 Times in 19 Posts
spare.
marty
I don't like my tires getting that much UV unless they are mounted. Check out my avatar for what I use. My old Cannondale tire sock must be getting close to 23 years old and still works quite well. A "real" sock also works OK and would be easier to find. That would be even more correctly "old school".
mollusk is offline
Old 11-30-05, 06:35 PM
peripatetic
peripatetic's Avatar
Bikes: All 70s and 80s, only steel.
You mean an actual sock for one's foot? Or is there actually such a thing as an old school tire sock? And if so, where does one buy one?
peripatetic is offline
Old 11-30-05, 08:37 PM
USAZorro
Señor Member
USAZorro's Avatar
Yes, there is such a thing. Read back in the thread for a link.
USAZorro is offline
Old 11-30-05, 08:46 PM
peripatetic
Oh, uh, I guess that you mean the Jandd? I have been lurking through the whole thread, I was just wondering if the new word that had appeared, "sock", referred to something even more traditional. Would that piece of canvas that Rivendell carries work, or is that too small? I'm starting to contemplate something more homemade, maybe just canvas folded over the tires in a small plastic bag?
Old 11-30-05, 08:54 PM
USAZorro
Señor Member
USAZorro's Avatar
As long as its the right size, it ought to work. This is a decidedly low-tech piece of equipment that anyone with a sewing device, a bit of sense and sufficient ambition could rig up.
USAZorro is offline
Old 11-30-05, 09:51 PM
peripatetic
Yeah, that's what I thought. Okay, thanks for being patient and sharing with a neophyte to the world of tubulars. Good learning.
Old 11-30-05, 11:03 PM
luker
juneeaa memba!
Quoted: 13 Post(s)
I used to use an actual wool sock to hold the tubie, a dollar, and a few wrenches. Held it on with a toeclip strap...I recommend vigorelli winter socks for that totally vintage look...
luker is offline
Old 12-01-05, 08:37 AM
lotek
lotek's Avatar
Quoted: 15 Post(s)
funny thing, I was in LBS last week and they had Jandd seat bags on
sale. So I bought the tubular bag for cheap. It is like the bags of old,
holds little more than than a tubular and maybe a velox repair kit and
multi tool.
I like it. I'd take pics but as we know they aren't working right now.
guess I'll put that old toestrap back in the parts bin.
marty
lotek is offline
