The ultimate 27" tire reference thread!
#51
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
Getting a flat on a tandem's rear wheel isn't fun at all, what with the drum brake and extra heft!
#53
Bikes: 1980 Avatar 2000 (LWB/USS recumbent), 1982 Infinity (aluminium LWB/USS recumbent), c. 1984 Maruishi Tour Ace TA18, 1986 Miyata 912, 1989 Miyata 312, 1982 Bridgestone Regulus, 2015 Rodriguez UTB, c. 2002 Birdy folding (Sach 3x7)
I know this is an old thread, but since it is intended as a pinned reference:
The new owner of the Loose Screws NOS parts dealership, following the former owners' retirement, has brought out two new 27" folding tires:
SwiftTire ''Sand Canyon'' 27 x 1 3/8 Folding Touring Tire, Black Sidewall (120 TPI)
SwiftTire ''Sand Canyon'' 27 x 1 3/8 Folding Touring Tire, Tan Sidewall (66 TPI)
More from their blog:
SwiftTire ?Sand Canyon? 27 x 1 3/8 Tire 37-630 Made in Japan by Panaracer | Loose Screws
The new Loose Screws tires are described as 27 x 1 3/8" (which would be 35mm wide), but as typically 33mm wide when mounted on "touring rims".
Both versions appear to have the same tread. I like the Continental Gatorskin or Ultra Sport slicks, but they are wire bead, slick for smooth rolling on pavement, and not available wider than 1 1/4".
The Loose Screws tires look potentially interesting for people looking for a folding touring tire and/or for a slightly wider tire, with enough tread for mixed paved/unpaved riding.
I'd be interested in reports from anyone who tries these.
I have no affiliation with or interest in Loose Screws, but I have several bikes with 27" wheels.
Last edited by ehasbrouck; 02-04-15 at 10:42 AM. Reason: correct description of link
#54
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,699 Times
@ehasbrouck
Score.
Thank you for the heads up. I've kind of daydreamed about a non-knobby 1 3/8" tire since getting a wheelset with a Specialized 27 x 1 3/8" Expedition tire. I had no inclination to go any more than 5-10 miles from home on those 30+ year old tires, but they felt nice. I can imagine that if the tire were just a hair larger it would not be as... nice.
It was paired with this on the front:
Score.
Commence to jigglin’ huh?!?!
#55
Quoted: 830 Post(s)
Liked 2,123 Times
@The Golden Boy: I also acquired a bike with the same 30+ year-old Specialized Touring tires. I was more willing to ride 'em. After a few months the sidewalls split and the tube started creeping out the side. Fortunately, I noticed before it blew at a bad time. Now I haven't been riding that bike since it needs new tires. I think you're wise not to push your luck with those.
#56
Liked 1,699 Times
#57
Sunshine
Quoted: 10954 Post(s)
Liked 7,482 Times
https://www.amazon.com/Origin8-Elimin.../dp/B00SZ0EF8K
$27 for a 27 x 1 1/4 folding tire. No idea who actually makes it, but there are few folding 27s, so I figured it'd be a good option for some around here.
I have 2 on a bike and just picked up and extra that I will bring along when out riding for multiple days.
They ride fine- nothing impressive but also nothing to cry about.
#58
Liked 1,295 Times
As far as actual width is concerned, it's not so much what is printed on the sidewall but what the actual inflated width is on any particular rim.
Those old Expedition tires were no bigger than a 1-1/4" Pasela, or 1-1/4" World Tour, or 1-3/8" folding Hi-Lite Tour, all are about 32mm upon initial inflation.
Some 1-3/8" tires such as Kenda Cross-Cyclo, Club Roost or Cheng Shin actually measure less than 32mm, more like 30mm, but still are wider than most tires marked 1-1/4" since these can be as narrow as 27mm on a 22mm rim!
Like a lot of poorly-standardized bicycle parts, such as bottom bracket spindles and even quill stem extension lengths, it is up to the end user to actually measure (and perhaps even test-install and/or test-ride) things if they want to achieve precise results relating to things like crank chainline, bike/rider fit and tire clearance.
#59
Liked 1,699 Times
The Expedition was noticeably bigger than the Touring, which was about the same size as a Pasela 1 1/4".
#60
Liked 1,295 Times
The Paselas in 1-1/4 are pretty huge though. And I have several pair of those, so can test as well.
#61
OldBikeGuide.com
The Chen Shin 27 x 1 3/8 knobbies are a good value. I see them lasting a long time as commuter tires, though they do not fold. They prob retail for $12 max.
#62
Liked 1,295 Times
I can't remember ever seeing a ChengShin knobby in 27", but perhaps likely Cheng does make the 1-3/8" ClubRoost "inverted"-style knobby?
I've used the Kenda Knobby on the back wheel of my Miyata SixTen tourer. It rode and wore reasonably well but blew out in the center of the tread for unknown reason when the tread was about 2/3 worn. Here it is:
#63
Quoted: 227 Post(s)
Liked 390 Times
Lots of 27 tires from this joint. >https://www.biketiresdirect.com/prod...rosscyclo-tire
#64
Bikes: 2005 Cannondale R5000 1986 Basso Gap(Super Record) 1986 Schwinn Voyager SP 1975 Schwinn Paramount Track Bike 1974 Raleigh RRA
Quoted: 31 Post(s)
I haven't been completely the same since I stopped riding on the Specialized Expedition 1 3/8 tire...I can't find a smooth replacement.
#65
The Vittoria Zaffiro is a tire tread I designed around 1995. What a trip to still see it around twenty years later.
#66
Quoted: 7348 Post(s)
Liked 2,461 Times
This week, I got an email from loosescrews.com:
We have our own tire! Made by Panaracer in Japan, the 27 x 1 3/8 size also fits common 1 1/4 inch rims. They are folding touring
tires measuring 33mm wide. Light and supple, there are two distinct types, both costing a staggeringly low $31. We want to keep
classic bicycles running and the low price is our way of saying thanks. Here's a secret only for the email list here, it's the same guys
making our tires, that make the custom Panaracer tires for the high end companies that like to charge over $50 for these. Some
are approaching $80 even. That's a lot to pay for special casings when the normal Panaracer ones we use are near perfect
already. Save the money and use the wheels you already have. Great for touring, commuting, and camping. Perfect for restoring
a bike prior to sale. Just search the site for SWT of SwiftTire.
#68
Bikes: You mean this week?
Quoted: 29 Post(s)
Liked 28 Times
I picked UPS a stack of NOS Schwinn Passage 27x1-1/4 folding tires. I actually prefer the Panaracers, but rubber at the right price got me.
#69
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,103 Times
One thing I really enjoy about C&V is the industry vets. I just tried to fit one of these. The Nashbar reviews said it fit really tight. Man, it's no fooling! I marred up the rim and pinched the tube in the process. I might try it tubeless just to offend the maximum number of purists on every side.
Genesis 49:16-17
Genesis 49:16-17
#70
#71
Have bike, will travel
Quoted: 910 Post(s)
Liked 288 Times
Soma has a tan wall 27 inch tire made by Panaracer, anyone using it?
Soma New Xpress 27" Skinwall Tire
#72
Liked 2,461 Times
Those Soma tires look the same as Paselas. Is there reason to justify the higher price?
#73
rain dog
Quoted: 16 Post(s)
Liked 8 Times
Looks like the images in my original post have gone away thanks to imageshack jumping the shark and switching to a paid-only service. I'll work on updating them to use a different host and add in the newer 27" tire offerings.
#74
Liked 1,699 Times
Dear ImageShack Users,
You are receiving this email because you have at least 100 or more images
in your ImageShack account. And have not used your ImageShack Account
for a while.
We wanted to appraise you of some changes at ImageShack that likely affected
your account.
If you are FREE ImageShack account user, your images will no longer work
on websites other than (removed link to Imageshack)
In order for your images to work, if you have a free account, it must be
brought to "paid" status. We understand that some of you are not interested
in upgrading your accounts, in which case you can bulk download your images
by using our Skypath desktop application that can be downloaded for Mac
or Windows here: (removed link)
For those people who are still considering to upgrade, we are now offering
deeply discounted yearly subscription of only $18.99/year, that's less
than $2/month. To take advantage of this offer, and to bring your free
ImageShack account to "paid" status, please follow this link (while being
logged in to your account): (removed link to Imageshack)
We are not planning to remove or delete any images from your
(removed link to Imageshack)account, even if your account remains free until
January 31st, of 2016, so you have ample time to download your images.
After that date, your account will be considered abandoned, and your images
will be deleted.
Thank you,
ImageShack Team
for a while.
your account.
will be deleted.
Thank you,
ImageShack Team
Yay Imageshack- they've already ****ed with picture sizes, ****ed with picture orientation and now you won't be able to link to the pix? Good bye and good riddance you clowns.
#75
Liked 1,699 Times
And for the 27" tire thread- these are a couple of my posts from another thread about tires
[/URL]
I have the tires mounted on some Super Champion (I assume Modele 58) rims- and for comparison porpoises, a Pasela PT or TG or whatever on a Wolber Model 58:
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
Last edited by The Golden Boy; 11-07-15 at 02:18 PM. Reason: Can't edit because of this typing thing
Likes For The Golden Boy:
