The ultimate 27" tire reference thread!
#76
Bikes: You mean this week?
Quoted: 29 Post(s)
Liked 28 Times
I looked at the tires, there is no identification on them as to the manufacturer. They are marked Schwinn Passage LF and Dual Hardness. They are a true tan skinwall with a reddish color at the bead. The tread is the 80s-ish thin, slightly raised rib in the center with herringbone on either side. They are also marked 270-gram. The tread is pretty thin, I doubt if it would be more than a 3000 mile tire. As for the ride quality...I don't know yet. I bought them right after I put a new set of Paselas on my touring bike and I haven't had to mount them up. Come to think of it, that touring bike (Schwinn Voyageur) needs some more road time!
#77
Bikes: 1974 Copper Raleigh International, 1975 Olive Green Raleigh Grand Prix, 1974 Raleigh Europa Custom
Quoted: 104 Post(s)
I have a pair of Schwalbe Active with the tan sidewalls and puncture protection. While not exactly a fast tyre they have been getting a lot of use. A combination of too much air pressure and a 700c tube forced the tyre off the rim after an hours ride when first fitted. Replaced the tube with a 27 x 1 1/4 and the with the pressure at 60 have had no issues. Pulled an industrial staple out of the tread a few weeks ago thinking it would puncture but so far so good.
#78
Quoted: 7348 Post(s)
Liked 2,462 Times
@mobilemail if you post a picture, I might be able to make a good guess of who made them. If you care.
#79
Quoted: 29 Post(s)
Liked 28 Times
Here ya go!
#80
Quoted: 2432 Post(s)
Liked 638 Times
Unless I missed it I don't think the Nashbar Prima 2 Plus has been mentioned. 280 grams for the 1 1/4.
Mountain Bike Tires | Road Bike Tires | Bike Nashbar
#81
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Since I grabbed a 2016 Panaracer catalog I went through it for 27's
Pasela PT with "400D Lite Extra Cord" and "PT Belt," each in tanwall with aramid or wire bead
25-630 27 x 1, 250/310 g, max 115 psi
28-630 27 x 1 1/8, 270/330, 105
32-630 27 x 1 1/4, 350/410, 95
Pasela with "400D Lite Extra Cord" in all-black or tanwall with wire bead
25-630 27 x 1, 290, max 115 psi
28-630 27 x 1 1/8, 320, 105
32-630 27 x 1 1/4, 390, 95
Genesis 49:16-17
Genesis 49:16-17
#82
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I've been running a pair of those "cheap" Kenda 1 3/8" knobbies this winter, and like them a lot. They came in like new condition, on a $20 Schwinn, so the Schwinn was basically free. Hey, what does a 27" x 1 3/8" equate to in metric size, like a 35 centimeter?
#83
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
Those Kenda 1-3/8" tires should measure about 30mm wide on a 22mm rim. Typical 1-1/4" tires measure 28-29mm on a 22mm rim, but Michelin World Tour and Panaracer Pasela 27x1-1/4" tires measure true to size (about 32mm), so are relatively huge compared to their competitors.
A 1" Pasela is as wide as most 1-1/8" tires, about 26mm on a 22mm rim.
#84
Partially Sane.
Quoted: 972 Post(s)
Liked 643 Times
Converting 1-3/8" to metric gives 35mm, but as with most 1-1/4" tires, they measure much smaller than listed.
#86
Quoted: 71 Post(s)
Liked 5 Times
Hey GB, did you ever get a fender mounted on those Sand Canyons? I assume probably not, or at least without modifying the fender mount higher. I really like the look of the SC tread. Having said that I just mounted the latest iteration of the 27 1/4 Continental tour ride. The tire seems to have changed radically in last few years, but was cheap and is narrow enough to where I could mount it with fenders. Will test it soon and report back. I picked this one b/c there are some really rotten roads around here and sand, gravel, huge cracks, etc are the norm a good part of the year. So really I like a good tread similar to what is on those sand canyons but also need fenders.
#87
Liked 1,295 Times
That 30mm seems really small for a Pasela 1-1/4" tire. Can I assume you're using narrow (19-20mm) rims? How about inflation pressure?
I always use a 22mm Mod58 rim for my 27" tire test-fits, and I got 32mm at 90psi after the inflated new tire had settled for an hour on a warm day.
30mm is still at least as wide as the 1-3/8" knobbies though, and wider than the 1-1/4" Aramdillos.
#88
Liked 638 Times
#89
Bikes: All 80s Schwinns: 88Prologue, 88Circuit, 88Ontare, 88KOM, 86SS, 88Tempo, 88V'ger, 80V'ger, 88LeTour, 82LTLuxeMixte, 87 Cimarron, 86H.Sierra, 92Paramount9c
Quoted: 188 Post(s)
I'm looking for some Paselas in 27 1-1/4" folding for backup on my touring setup. I can't seem to find them anywhere. Any clues? I think I stumbled over the folding Pasela in 1-1/8", guess for backup purposes that would suffice, but just wondering if anyone has seen the 1-1/4s lately. The sand canyon 1-3/8 looks very interesting but not only are most of my rides on pavement, they're mostly on fresh paved rail trails, so don't need an aggressive tire, at least for now.
#90
I'm also looking for the Paselas in 27 X 1-1/4, none of the U.K. Sites seem to carry them where are you guys ordering them from?
#91
Unavilable due to riding
Bikes: Nishiki Olympic
Quoted: 127 Post(s)
Need 27 x 1-1/4 tires for my Nishiki. LBS says $25 EACH and i said no thanks.
I found 2 for $25.90 shipped on Amazon. https://www.amazon.com/Cheng-Shin-C6...6%3A1253555011
#92
I'm here to bump, and ask if this perhaps can be made Sticky status. I've had to do a search for this thread a few times.
There are also Continental SuperSport, in addition to the other Conti's listed here.
Avenir Discovery (I assume just cheap CST crap?)
Bontrager T1.
Has anyone tried (and liked) the Bontrager's? I've enjoyed their tires on my mountain bike, and am thinking of replacing the 27 inchers on my Falcon, perhaps with these. I like that they are more slick than others listed here.
Bontrager T1.
#93
Quoted: 1856 Post(s)
Liked 664 Times
I agree with stickiness!
#94
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1296 Post(s)
Liked 940 Times
Dirtfarmer, the Bontragers I have used have all been great tires.
Besides the T1, they have two others available in 27"
Tires/Tubes - americancycleandfitness.com
(I had some Avenir Kevlars in 700c that I liked, by the way.)
I didn't think Avenir was still making tires.
If you want something a little hotter than most, there is a NOS set of IRC Triathlons at your favorite online auction house, as-we-speak. 115psi, 127tpi and 27x1". Old style cookin'!
#95
Bikes: 1970 Schwinn Racer, 1976 Schwinn Continental, 2015 Electra Cruiser 1
I didn't see (and maybe I missed it), but I'm running Michelin Proteks on my '76 Schwinn Continental and they're doing great after 1,400 hard miles. I would've preferred World Tours, which I ran for years, but those are apparently now made of unobtanium.
I'll use nothing else unless someone here can prove to me a different tire is better!
#98
Forum Moderator
Quoted: 3089 Post(s)
Liked 6,589 Times
Any new suggestions for 27" tires?
#100
Forum Moderator
Liked 6,589 Times
We thought that we'd try it as a sticky. But, I don't know if there are any new choices out there in 27" tires.
