Ask the Community
Bikes: cheap ones
Quoted: 25 Post(s)
I ride the A530's on my touring bike for the reason you described--wanting the option to ride the bike casually around town with whatever shoe, but then clipping in for longer rides. They're a great, versatile pedal in that regard.
For riding fixed, though, I do enjoy having a double sided pedal and not having to think about it. I rode with Shimano A520's for a while, but would get annoyed in traffic when clipping out and trying to clip back in again. It's not the biggest deal, really, but since I already had a pair of M520's I switched back and haven't regretted it. Something about cranks spinning and clipping in with ease just makes it worth it.
My advice: grab a pair of A530's and find out for yourself. You can always switch back to your M520's if you want. Wellgo also makes a fairly popular platform/SPD pedal, too (big fan of the oil port for maintenance): Wellgo R120B Sealed Bearing Road Pedals | Chain Reaction Cycles
Clark W. Griswold
Quoted: 4252 Post(s)
Liked 3,866 Times
I would be doubtful you would want to not be clipped in while riding fixed. If that is the case, something with a "cage" around the pedal (not a toe clip but extra material around the pedal to give you a stable surface) will help rather than a platform on one side and clipless on the other.
Bikes: cheap ones
Quoted: 25 Post(s)
I don't see what the big deal is. I don't live in a hilly area and my bike has a front brake. I'd just like to be able to ride to the store or the bar without having to wear special shoes.
Pedal straps might be a better solution but I hate the way they look.
I just bought some new bar tape, I accidentally bought some with adhesive backing. I always use the non adhesive kind, is there any problem I'll encounter with me applying it without pulling the tape backing off? I never tried it this way before.
Bikes: steel track
Quoted: 235 Post(s)
Seems like you wouldn't be able to stretch the tape properly, and that the backing wouldn't tack correctly to the bar and tape surfaces it wraps around.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Adhesive makes a mess and is a PITA to clean.
Back in the day tape never came with adhesive. It was just a strip of leather or cork and was wrapped so that it wouldn't come off - overlapped properly, in the direction of pressure from the hands, etc. Millions of riders never had a problem. I see no reason why it wouldn't work for @Philasteve.
-Tim-
-Tim-
Calamari Marionette Ph.D
Bikes: steel track
Quoted: 235 Post(s)
-Tim-
-Tim-
Veteran Racer
Bikes: 32 frames + 80 wheels
Quoted: 1331 Post(s)
Liked 762 Times
The backing will simply break up as soon as the tape is stretched, and covers too small an area to affect adhesion.
Bikes: steel track
Quoted: 235 Post(s)
Ah, I was imagining backing that covers the whole width:
Dunno why I made that assumption in this case.
Agree that if it's just a narrow band it shouldn't be a big deal.
Veteran Racer
Liked 762 Times
What you are seeing in that image is simply the outer packing plastic to keep the tape from unravelling. The inner adhesive strip is very thin and does not cover the whole width of the tape.
What, Me Worry? - Alfred E. Neuman
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
Bikes: steel track
Quoted: 235 Post(s)
Ack, I should be concentrating on work instead of playing on the internet with half (or less) a brain. Lesson learned.
I've already been riding fixed for a couple months now without foot retention and I didn't die in some horrible firery crash.
Foot retention isn't the key to humanity's survival. Sure makes a fixed gear bike better though. Don't knock it till you try it.
And putting on special shoes to bike is half the fun.
What part of Columbus do you live in?
Quoted: 71 Post(s)
Liked 12 Times
Non adhesive tape always slides around from my experience, especially if it gets wet from riding in the rain. The paper backing will probably rub off/tear during application so just peel it off and let the adhesive do its job. lots of stuff you can use to get the sticky stuff off later without damaging the bars.
Thanks for the advice everyone, I'm going to just give it a shot without taking it off. I have a feeling when stretching it, it will expose a little bit of the adhesive so we'll see where it gets me.
Bikes: cheap ones
Quoted: 25 Post(s)
Do you hate toe clips and straps? Or the thick straps for platform pedals?
I'm in the suburbs, Grove City
Warehouse Monkey
Quoted: 305 Post(s)
Liked 7 Times
How often should I service my drivetrain, like regrease my hubs, soak the chain, etc? Wait until it makes noise? Every so many miles?
'10 Specialized Hardrock
What compares to a FSA SL-K Light crankset? Would Sram Force be a step up or down?
Any BB30 or PF30 crankset suggestions for SSCX?
Bikes: CENTURION / LOOK / Bianchi
Quoted: 214 Post(s)
Liked 10 Times
Depends on how often you use your bike. Normal use i'd go with cleaning the chain every 2 weeks and re-grease hubs etc every 6 months
Quoted: 8 Post(s)
Ok, my turn: Who makes a 1" quill stem that has a quill that isn't 42 feet long? I'm short. I ride a 49cm frame. Every quill I can find is longer than my left leg. Help please community.
Bikes: steel track
Quoted: 235 Post(s)
Buy any quill stem you like, disassemble, hack as much off the angled part (at a similar angle) as you want, reassemble. Done.
Quoted: 214 Post(s)
Liked 10 Times
Need some help setting up a SS CX Surly Steamroller.. I need to acquire a 42t(ish) front chainring (130bcd) and brakes that will accommodate 700c-35 tires.. I would pick stuff up from Scrod but he doesn't really stock these kind of items..
Good places to go shopping?
The challenge may be your headtube length, and how tall the stem is above your headset.
If there's a bike co-op in your area, head over there and look for vintage SR stems. I once had one that was 60mm!
