Handle Bar Extensions 😎😎😎
Quoted: 7 Post(s)
After weeks of purchases/returns/modifications/fabrication and paying the LBS to help me...I am thrilled with my new creation. The first picture are the bars installed (with help from the LBS because I could NOT figure it out). The handles are ridiculously close and riding was very unstable. The second picture is my final version. I had the center bar cut, and welded to make it longer. I have a bad neck and shoulder. The second position is a welcome relief and grabbing the brakes is pretty quick and easy. Cost WAY more than I originally intended, but I got in too deep and had to just cut my losses to get it finished.
Looks nice. One question, did you have to revamp the clamps on the bars where they were mounted on the fatter part of the bar and now on a narrower? Or do the clamps have that much adjustment? Oops that's two questions ... 😜
Quoted: 5224 Post(s)
Liked 3,581 Times
wider is better, you'll have more leverage & stability, meaning less twitchy. have you taken it for a test ride?
