About to start commuting in the winter - how's my clothing plan look?
Bikes: 2007 Specialized Tricross Sport
Quoted: 34 Post(s)
I've always just used my general winter clothes for winter commuting, but am getting pretty tired of that.
Route is 17 miles each way. Temps get down to about 20º F (-7º C) at the lowest, although will usually be closer to freezing when I'll be riding. I have a set of fleece pants and a warm lightweight jacket that I don't mind layering with all of the below occasionally.
My goal is to have the fewest items that cover the most situations with proper layering. Don't mind paying a bit extra for performance and durability. Don't care much about looks, although you can't go wrong with black.
I go for Merino wool wherever possible for skin-contact clothing - seems to have the widest comfortable temperature range of what I've used.
Thanks for any input!
Shorts - $50 - Canari Velo Gel Shorts - Didn't go for Merino here since I don't know if it would be durable enough. Definitely prefer shorts over bibs.
Leg Warmers - $75 - Rapha Merino Leg Warmers
Wind/waterproof shell - $100 - Patagonia Torrentshell Pants - Want something as light as possible so it can be removed and packed when not needed.
Jersey - $75 - Rapha Classic Jersey II
Long Sleeve - $175 - Rapha Classic Long Sleeve Jersey II - Don't like that price for what it is, but I figure it will last a very long time.
Wind/waterproof shell - $140 - Arc'teryx Incendo Hoody - A little more expensive than I'd like, but works for plenty of non-cycling applications. Very light, so easily stored.
Socks - Owned - Injinji Lightweight NuWool Toesocks
Warm Socks - Owned - Darn Tough 1474 or 1405 Socks
Shoes - Owned - Shimano SH-R107 - Thinking about replacing these, since the toe area is a bit cramped for me.
Toe Covers - Owned - Pearl Izumi Elite Thermal Toe Covers
Light Gloves - Owned - These things - Wouldn't mind replacing with something a bit more comfortable since these are starting to develop a few holes.
Heavy Gloves - Owned - Outdoor Research Arete Gloves
Liners - Owned - Terramar Thermasilk Liners
Balaclava - $35 - Icebreaker Oasis Balaclava
Ear Warmers - $25 - Icebreaker Quantum Headband
Glasses - $55 - Veloce Crystal Clear - Don't particularly like these. Looking for something clear, no bottom rim, non-polarized.
Goggles - $30 - Giro Tempo
Black is great for absorbing the suns heat, but not good if it gets dark on you. I would make outer layer hi vis if possible.
Quoted: 5224 Post(s)
Liked 3,581 Times
I like that those outer pants have pockets!
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
The only thing really missing from the list are some additional base layers, just regular wicking jerseys but you probably already have them for general cycling. You have easily enough for down to 20°, actually quite a bit more extensive than I've used and I ride frequently in colder temperatures (having not skipped a winter commute in 5-6 years).
A couple of other things I'd advise is a pair of neoprene shoe covers, and a waterproof rain jacket (even just a thin generic one) just in case of heavy rain.
Quoted: 1186 Post(s)
Liked 289 Times
Hard to go wrong with merino wool for commuting. My only recommendation would be to buy more. I have many long and short sleeve merino wool baselayers of various weights. You don’t need a fancy wool jersey with pockets if you’re going to put a jacket or vest on top. In the spring and fall I often end up with a long sleeve wool baselayers with a wind proof vest on top.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Toe covers definitely won't cut it. Full neoprene booties will be much better.
I own a short and long sleeve Rapha Classic II jerseys. They will not provide enough insulation for the temperatures described.
The Arc'teryx Incendo is a fine jacket but again, not enough insulation when combined with the above jerseys. The hood will be of limited value and could even be dangerous as it blocks side vision. A helmet cover is a better option if rain/show is a concern.
Be careful when choosing a balaclava. Many block wind but do a poor job of insulating the top of the head.
A neck gaiter is an inexpensive investment and easily stowed if not needed. I own the Smartwool Merino 250.
My insulating mid-layer in very cold weather is an Arc'teryx Delta LT full zip made from Polartec Powergrid. This is another incredibly versatile garment and amazingly warm for its weight.
-Tim-
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times
Top of the head is not so much a concern unless OP rides without a helmet. I have a relatively thin balaclava which does a fine job on my face and neck. Even when temps drop to -10*C it's still fine. Top of the head is sufficiently insulated with the helmet on top of the balaclava. Below this temperature, another layer is added, but more so for the face and ears than the top of the head.
Shimano Certified
I am a fan of my Bontrager JFW shoes with insulated insoles and toe warmer packets below 30 deg(11 hrs of warm). Just got Bontrager OMW winter pants with much positive results as well. Spent all day friday in and out of rain at work and didn't even notice the wet at all since it repelled right off. Warm legs and warm feet make everything else work better. Cold feet(especially spd) will kill your feet tendons in a heartbeat.
I posted this a few years ago. I should update it because it has changed a bit: Mostly that I wear my road helmet down to 10F with a merino cycling cap with ear flaps.
Quoted: 34 Post(s)
Thanks for all the great input everyone! Bought some things before seeing of the responses, but I'll give it a shot and go from there.
Made a few changed to the list in the original post:
Shorts- $50 - Canari Velo Gel Shorts - Went with the Voler Jet FS Shorts instead. Seemed to be a bit better quality, still black but with reflective accents, and made in my home state!
Leg Warmers- $75 - Rapha Merino Leg Warmers - Stuck with Rapha, but just got the knee warmers. Seemed a bit more versatile, and also not out of stock...
Jersey- $75 - Rapha Classic Jersey II - Skipped for now since it's so cold. Got a few months before I'll need to decide here.
Long Sleeve- $175 - Rapha Classic Long Sleeve Jersey II - Switched it up a bit with the Rapha Brevet Windblock. More Merino, plus integrated windblocking. I think this will make me a lot more comfortable in that range between extreme cold and slightly warm. Got it on sale too! I also have a 200 weight Merino base layer when needed.
Wind/waterproof shell- $140 - Arc'teryx Incendo Hoody - Slight upgrade to the Arc'teryx Squamish Hoody. A bit heavier and more expensive, but seems to be a better build and fit, especially with the hood.
Goggles- $30 - Giro Tempo - Went with the Smith Squad MTB Goggles. They had a lot more information available about them, and confirmation of some features I was looking for like full UV blocking and good helmet compatibility.. The Giro's probably would have been fine, but I figure these will last me quite a few years, so I don't mind a slightly higher price.
Got a Giro Synth MIPS helmet as well. Pricey, but by far the best helmet I have ever owned.
Still undecided about glasses and cool (not cold) weather gloves. Will probably look at some better foot covers, or even warmer shoes...
Will update when things start arriving this week!
Shorts
Leg Warmers
Jersey
Long Sleeve
Goggles
- Soli Deo Gloria -
Liked 736 Times
Long Sleeve - $175 - Rapha Classic Long Sleeve Jersey II - Switched it up a bit with the Rapha Brevet Windblock. More Merino, plus integrated windblocking. I think this will make me a lot more comfortable in that range between extreme cold and slightly warm. Got it on sale too! I also have a 200 weight Merino base layer when needed.
I own this jersey. It is not 100% wind block like a Gore Windstopper product. I can push air through the Polyester face fabric with my mouth. I'd estimate it at about 85% wind block. The way they applied wind block to the arms doesn't seem optimal - when on the hoods the wind block seems to be on the sides of the forearms, not the front. Not sure if any of this will matter to you.
It isn't very thick but the Merino is really nice and it makes a great layering piece. The front pockets will be great for commuting.
If you are looking for a Windblock garment then have a look at the 7Mesh Synergy. I also strongly recommend the Castelli Alpha ROS jersey and especially the Alpha ROS jacket for temps below freezing.
-Tim-
Quoted: 34 Post(s)
Do you have this in hand yet?
-Tim-
-Tim-
- Soli Deo Gloria -
Liked 736 Times
-Tim-
Quoted: 34 Post(s)
Did my first ride! About 20 miles (32 km) and 1:30 each direction. Not too proud of that time, but has some ridiculous winds, so will hopefully get that closer to 1:00 with good weather and getting in better shape.
Weather was about 29º F with an apparent temperature of 19º F (-2º and -7º C).
Anyway, even with the toe covers (Pearl Izumi), wool base toe socks (Injinji), and wool mid-weight hiking socks (Darn Tough), my feet were half numb. Not nearly the worst they have been, but worth addressing. I'd rather not get a whole second set of shoes and it seems like only a bit extra is needed, so I'm going to try some full shoe covers. Beside's that, everything performed well, and I think I'm alright with the toe space in the Shimano shoes after all.
Hands were just about perfect with the Terramar silk liners and cheap Aufwarmen gloves. Got a bit chilly when starting out, and a couple other times for some unknown reason. Not numb though, and better than sweating. My heavy gloves probably would have been too warm.
Wore the Voler shorts and Rapha knee warmers (which are long enough to almost be leg warmers) with an old pair of fleece pants on top. Temperatures were great - not cold at all, but no sweating. Did start to get some chafing with the shorts toward the end of the return trip, maybe from the pants? Seemed to be mostly in the chamois are though, and I've never had an issue even while wearing tri shorts or even some regular pants. Besides that, everything stayed in place and was comfortable.
The Rapha windblock jersey really impressed me. It, plus an Icebreaker 200 wt Merino baselayer, kept me warm, but well vented where needed. Had some strong winds that night too. The neck of the jersey was a bit tight when zipped up fully while wearing a balaclava, but has a very nice fit without. Front pockets on the jersey were a nice touch, with loops on the zippers that made using them easy even with gloves.
Neck was a bit cold with an old cheap polyester balaclava. Ears and head were a bit warm with a set of earwarmers borrowed from my wife, so I just put them around my neck and things were alright. Icebreaker Merino balaclava and earwarmers should be here Friday, and I think I should be fine with just the better balaclava unless it's significantly colder out.
Helmet was amazing - forgot it was even there most of the time. Same with the goggles, with visibility and field of view almost the same as without anything on. No fogging at all, and they stayed in place the whole time without being very tight. Also found an old taillight that I clipped to the back of the goggles strap as a backup for my bike's taillight.
All that said, next step is getting some shoe covers and maybe replacing the old fleece pants with something a bit closer fitting. Will try riding with just the shorts and knee warmers first to make sure I need anything at all.
Bikes: 2010 Fuji Absolute 3.0 1994 Trek 850
Quoted: 762 Post(s)
Liked 555 Times
suggest hiking boots a size larger for your feet and a reflective strap or vest
https://www.amazon.com/REFLECTIVE-Li...flective+strap
also some buffs
https://www.amazon.com/KINGREE-Headb...ords=mens+buff
also some buffs
Quoted: 34 Post(s)
also some buffs
also some buffs
And thanks for reminding me I have one of those gaiters somewhere in my closet! Will pack that Friday in case the balaclava falls short.
https://www.pearlizumi.com/US/en/Sho...ght/p/11111713
I didn't look at all of your tops but in the winter I put this over top of my coat so I am easier to be seen. Bonus that they are cheap.
https://www.homedepot.com/p/TR-Indus...8008/207007269
Plus one on the shoe covers. But to be honest my Shimano SW81 winter boots were worth every penny they cost. A pair of smart wool base sock with summer socks over those keep my feet nice and toasty.
fasthair
- Soli Deo Gloria -
Liked 736 Times
Thanks for the report!
Figuring out what works is half the fun and there is a thrill in overcoming the risk of the first ride.
Congratulations!!!
A few suggestions:
Grip Grab shoe covers - Racethermo or Arctic depending on your needs and location. They are not available in the US but can be ordered through Wiggle.
Consider a neck gaiter. They are highly versitile. At 55 yearts old I rarely ride without one, even if it is only in my pocket. Cheap insurance against a sore throat.
Castelli Nanoflex knickers or tights are great and for colder temps the Sorpasso 2 Wind bib tights can't be beat. These are the only things I wear below 45°. Shop around for price and size up. Way up.
You may also need this for your skin after a few weeks in the cold.
-Tim-
Congratulations!!!
-Tim-
Quoted: 762 Post(s)
Liked 555 Times
balaclava for me was too warm. You will heat up pretty good in 17 miles.
gaiter/buff is so versatile and blocks wind from your neck hole. Can be pulled up over the ears and chin, and can even be used as a layer on your head
my feet get cold. I tried a lot of things, but the hiking boots with room for extra layers or warmers is the ticket
might want to look up rain poncho
Liked 3,581 Times
don't think shorts & knee warmers are gonna be enough for 19 degrees
Quoted: 34 Post(s)
For pants these are hard to beat. I've got two pair and they are many years old and still look and feel like new. If it gets real cold (10f or lower) I will but a pair of "long Johns" under them. I chose these so I can wear my own bike shorts under them.
fasthair
fasthair
A few suggestions:
-Tim-
A few suggestions:
-Tim-
I will keep considering the bib tights... I've never been able to get into bibs though. I know I'm probably on the minority side here haha. I see, and appreciate the advantages, but the extra material on the torso bothers me, and the constant light pressure on the shoulders. It's weird - I'll carry a heavy pack all day, but even just using shirt stays is uncomfortable for some reason. I have torn both my AC ligaments, so maybe that is something to do with it haha.
I don't think so either, but it won't hurt for too long to try and find out! Either it works or I'll be numb pretty quick haha.
