Frame size suggestion
Old 01-06-19, 09:42 AM
cemark
Bikes: Cannondale Synapse SE
Quoted: 12 Post(s)
Currently I am riding 52 Caad10 Track. Because its track geometry I dont feel perfectly comfortable and I prefer more upright position. I also have been craving to buy a Cinelli and I found two good deals but with the sizes I have never ridden. I found Cinelli Vigorelli Steel frame set small size (50) and Vigorelli Aluminium large size (56). I can either buy one of these two or pay extra 250$ and buy size 54. What would you suggest?
My height is 1.73 and inseam 77cm.
Caad10 track (M) 76cm standover 51.4cm stack . 40cm reach
Vigorelli Alu (L) 81cm standover 56cm stack 40cm reach
Vigorelli Steel (S) 77cm standover 51.5cm stack 39cm reach
cemark is offline
Old 01-06-19, 07:27 PM
phobus
Quoted: 155 Post(s)
Liked 55 Times in 31 Posts
I'd suggest using this fit calculator as a starting point:
https://www.competitivecyclist.com/S...ulatorBike.jsp
If you're actually after an upright position, though, the Vigorelli's probably not going to work out for you.
phobus is offline
Old 01-06-19, 08:43 PM
mouse
dumb
Quoted: 174 Post(s)
I’ve played this game. It’s not fun. It’s worth the extra $ for a proper sized frame. You quickly realize if a frame is too small or large. Not only that but someone comfortable with a 50cm is NOT going to be comfortable on 56cm
mouse is offline
Old 01-07-19, 01:31 PM
cemark
Quoted: 12 Post(s)
Thanks for this site. It helped a lot. I am obviously in the 52/54 range as I expected. Actually even with the Caad10's more downward geometry its not that uncomfortable but I have been craving to buy a Cinelli and their geometry is way more upright. I tried Vigorelli at a bike shop 2 months ago. The bicycle was way heavier than mine but it was really comfortable and it was a smooth ride. My pocket says go for the 56 Vigorelli but my body needs 52 or 54. Thanks for the help. I think I wont buy another bicycle for at least 4 5 years, so it will worth it hopefully.
cemark is offline
Old 01-07-19, 01:33 PM
cemark
Quoted: 12 Post(s)
Yeah, you right. I am going for the 52 probably. My bicycle shop doesn't have it at their stock right now. They had 54 2 months ago and it was pretty smooth ride. Hopefully they will have 52 in 3 weeks and I will buy that beauty. Thanks for the help.
cemark is offline
pressed001
Road Cycling
11
08-02-18 01:39 PM
Drashkum
Fitting Your Bike
31
05-06-17 08:46 PM
Nikke
Singlespeed & Fixed Gear
7
09-03-14 01:21 PM
blackeneddandy
5
04-03-13 10:42 AM
ForSureForSure
9
07-23-11 04:57 PM
