Go Back  Bike Forums > Bike Forums > Winter Cycling
End of studs
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
End of studs
Old 03-09-19, 11:34 AM
baldilocks
Bikes: Giant ATX Lite & Schwinn Mesa
Quoted: 156 Post(s)
Liked 7 Times in 7 Posts
End of studs
When do you stop using studded tires. The temps may be getting to the forties, but when I leave for work in the morning, it's still 27 degrees. If it weren't so salty, I'd like to get my good bike out. What is the deciding factor for you as far as when you switch to your other tires. They've been great when I've needed them (first winter with studs), but I'm ready for them to be gone. Maybe next year I'll get a second set of tires.
baldilocks is offline
Old 03-09-19, 12:31 PM
mcours2006
mcours2006's Avatar
Bikes: ...a few.
Quoted: 2012 Post(s)
Liked 409 Times in 235 Posts
I hear you about riding on studded tires. I've had them on all winter, but yesterday I swapped them out for non-studs, and man, what a nice change.
It's too early to put them away. There is plenty of winter left. I'd say at least another month for me and I can start thinking about it. This past week has been quite dry and the road conditions have been good, and that's why I sneaked in a ride without them.
mcours2006 is offline
Old 03-09-19, 01:38 PM
parkbrav
Quoted: 220 Post(s)
Liked 114 Times in 97 Posts
I had this exact question last winter. I bike all year round and switch the tires once per season.
The advice I got was essentially, keep them on because there's lots of winter left and it's cheaper to keep them on than risk a wipeout and possible medical bill in case winter makes a sudden return.
The advice I got was keep them on for about two or three weeks of low temperatures above 32F. If it can't freeze then no black ice thus time to start thinking ahead to spring and summer.
For me this means about the Master's PGA tournament, which is April 11-14 this year, or one week before Easter
parkbrav is offline
Old 03-09-19, 01:52 PM
2_i
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times in 251 Posts
I use studded/aggressive tread only on rutted ice/heavy snow. Otherwise I ride on non-studded Continental Winter tires that take me without hiccups between seasons with swinging temperatures below and above freezing. There are similar offerings apparently from other manufacturers.
2_i is offline
Old 03-09-19, 02:22 PM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
I have a spare bike. it's wheels with studded tires, it just gets parked in the basement,
3 separate days in last 30, right at 0C snow/rain mix, last night dry cloudless , it dipped colder..
but I'm maybe 20 feet above sea level 10 miles from the ocean.. more snow higher up the hill ..
its gone by now..
But at 1600 feet, over the Coast Range, things are different..
fietsbob is offline
Old 03-09-19, 02:34 PM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
This is a particularly dangerous time of year, because the snow melts (or it rains) and can freeze into icy patches overnight. I put up with studs for a while after we start getting above-freezing daytime temperatures just to make sure I'm not unpleasantly surprised out on the road.
Suck it up, they're making you strong.
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 03-09-19, 02:36 PM
bark_eater
Quoted: 753 Post(s)
Liked 737 Times in 422 Posts
I'm holding out for another storm. I only got a couple hundred miles of riding in this winter with a studded single speed mountain bike but it was nice to have the "no excuses" bike ready to go.
bark_eater is offline
Old 03-09-19, 02:42 PM
ljsense
ljsense's Avatar
Quoted: 284 Post(s)
Liked 152 Times in 92 Posts
Agree -- early spring is when studded tires are most valuable, because meltwater freezes overnight, and thin ice over pavement are where studs shine.
Rule of thumb would be the same for when you can put flowers out -- last freeze. Or just watch for tulips coming out of the ground, and change your tires when you see them bloom.
ljsense is offline
Old 03-09-19, 05:02 PM
2_i
Quoted: 840 Post(s)
Of course you do what you feel that you need to do. However, relative to what you can encounter in winter, short flat patches characteristic for temperatures going up and down late and at at times early in the season are a minor issue. You can get through such patches through inertia. Obviously you should not sleep under conditions of such type and particularly pay attention if you need to turn. Rough situation is when deformed ice builds up and you can only get through with studs or by walking and that is usually deeper into the season. Whether or not you have studs you need to strategize and as you gain skill you find fewer and fewer situations where studs make much difference.
2_i is offline
Old 03-10-19, 06:18 AM
mcours2006
mcours2006's Avatar
Bikes: ...a few.
Yep. A week's worth of riding on studs, and a net headwind, is worth about 1.5 weeks or more of summer riding in terms of work and effort.
Still blows, though.
Old 03-10-19, 06:28 AM
bark_eater
Quoted: 753 Post(s)
Add a 50lb kid in a trailer. "Up hill, both ways"
Old 03-10-19, 06:39 AM
baldilocks
Quoted: 156 Post(s)
Based on the forecast I can take them off in April. That's with only one degree to spare. I don't mind riding on them that much. But after riding down a street that looked like a sheet of glass, I feel silly using them when all I see is clean pavement. But then, I think I bought them for what I don't see (black ice) and at age 52 I'm too young for a broken hip.
Old 03-10-19, 08:19 AM
Daniel4
Bikes: Sekine 1979 ten speed racer
Quoted: 1481 Post(s)
Liked 639 Times in 437 Posts
As long as there are patches of ice on the trails, the studs stay on.
Daniel4 is offline
Old 03-10-19, 09:42 AM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,584 Times in 2,344 Posts
When the ice is off the trails I like. Last year I took a non studded bike down to our local river trail cuz there wasn’t any snow or ice anywhere well except for these trails so had to ride back home to get the studded bike then ride to the trails all over again
yesterday I kept driving south looking for ideal snow depth for my mtb
pre-spring is tricky
rumrunn6 is offline
Old 03-10-19, 03:34 PM
ZIPP2001
Life Is Good
ZIPP2001's Avatar
Bikes: Zipp2001 Carbon Belt Drive SS, Kestrel RT900SL, Kestrel KM40 Airfoil 1x10, Orbea Occam H30, Trek Stache 5 29 Plus, Giant Yukon 2 Fat Bike
Quoted: 277 Post(s)
Liked 870 Times in 443 Posts
The trails still have several inches of ice under the snow out my way so studs stay on for a while longer.
ZIPP2001 is offline
Old 03-10-19, 05:32 PM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
That's exactly why I am keeping my studs on for a little while longer, those early morning commutes can be very slick... Last year we had a big ice storm in the middle of April. It's only March and anything can happen.
wolfchild is offline
Old 03-11-19, 05:40 AM
parkbrav
Quoted: 220 Post(s)
Boston had a slush / freezing rain storm yesterday and now the suburbs are covered in a sheet of black ice. I guess "winter wants to play a little longer"!
parkbrav is offline
Old 03-11-19, 12:58 PM
Daniel4
FYI. It's still winter. Where I live, we get snow right into April. Everybody should expect it but everybody is always shocked when it happens.
Daniel4 is offline
Old 03-11-19, 01:00 PM
rumrunn6
rumrunn6's Avatar
not yet
rumrunn6 is offline
Old 03-11-19, 01:23 PM
parkbrav
Quoted: 220 Post(s)
Gotcha, you're right, but it is awfully tantalizing because when it's not precipitating it's actually sunny here and the snow is melting rapidly.
The other day I got to run on the public outdoor track. That's rather remarkable because they clear off the athletic field in the center and store the snow on the track. Usually, that track is under feet of snow this time of year.
parkbrav is offline
Old 03-11-19, 04:05 PM
mcours2006
mcours2006's Avatar
Bikes: ...a few.
On a day like today you'd be foolish to ride without studs. The warmer temp yesterday melted a lot of snow, creating lots of wet patches and puddles on the road. Over night the temperature dipped below freezing and created just the situation against which many of you were warning. So, a bit premature to talk about taking off the studs.
Sidewalks were even worse. I went for a run this afternoon and it was downright dangerous.
Old 03-14-19, 03:20 PM
Daniel4
Slush is too thick to ride without fat bike tires. I tried with my beater mountain bike (studded 2 in tires). Had too hard a time. Then the next day, went out with my fat bike and it was a breeze.
Daniel4 is offline
Old 03-20-19, 08:32 AM
rumrunn6
rumrunn6's Avatar
come heck or high water, neither would I wish on anyone, what a weird expression, this Sunday 3/24/19 ...
rumrunn6 is offline
Old 03-20-19, 09:36 AM
ThermionicScott
My phone is forecasting a few nights below freezing next week, but not by much. Probably a safe gamble.
RUSA #7498
Old 03-20-19, 09:40 AM
parkbrav
Quoted: 220 Post(s)
I am highly suspicious that the Boston area will get an "April-Fool's Day" snow storm this year. It often happens, of varying intensity.
parkbrav is offline
