Tubeless tyres; wet area on tyre when left overnight
Quoted: 800 Post(s)
Liked 512 Times
While riding a few weeks back I had a puncture in my front tyre. The Orange Seal did it's job and I was able to ride home. I pumped up the tyre and the tyre had held air ever since. Except...when I take the bike down from the wall (all my bikes hang by the front wheel) there is a wet spot/mark on the tyre where the puncture happened.
Suggestions on what steps to take next? Do I need to put in a plug? I've never done that before. The plugs I bought (after reading about them here on the forums) are the Genuine Innovations ones.
https://www.sovereigncycle.com/genui...ubeless-t.html
Likes For jadocs:
Quoted: 1818 Post(s)
Liked 1,693 Times
Like you, I had a tubeless puncture last year that sealant did not repair properly. So, I dismounted the tire and applied a proper patch on the inside. It has been fine ever since
Likes For alcjphil:
Quoted: 800 Post(s)
Liked 512 Times
Thanks for the info/recommendation. Any particular patch you'd recommend?
I've got one now, punctured on Saturday, sealed, but opened up again (and re-sealed) this morning. I have a Dynaplug kit, so I'm going to try this. In part because I've never used it and want to be sure I know how to use them.
Bikes: Pinarello F8 & F10
Quoted: 7 Post(s)
Btw, the Genuine plugs you bought will come out after a while because of the high pressure in the tyre, better is to use the Dynaplug kit.!
Quoted: 800 Post(s)
Liked 512 Times
A couple of questions folks:
- Patching is different from plugging, correct?
- A plug is used on the outside of the tyre, correct?
- Would something like this work for an inside the tyre patch? https://www.mec.ca/en/product/5048-2...zing-Patch-Kit
I popped a Dynaplug into my tire last night, worked great, sealed the hole immediately and there is no sealant weeping from it overnight. Will see how it holds up. I'm guessing I've got maybe 500-800 miles left on this tire, so it's a good one to experiment with.
Likes For jimincalif:
Quoted: 7 Post(s)
I put 75 miles on my tire with the Dynaplug over the weekend. No leaks.
