Drive by wire on a bent?
has anyone ever hooked servos up to the steering wheel of a tadpole and then connected a joy stick so that steering could be done with the joy stick? Sounds really cool...but am not sure how safe it would be.
Bikes: GT3 trike,Viper chopper, electric assist Viper chopper,Electric moped(Vespa style)
Fun, but would be deadly on roads, a touch of servo shudder, a wire vibrating loose, the control potentiometer wiper getting dirty, battery pack failure, road pot hole causing stripping of the output gears.... you get the picture.
Digital feed back servo same issues different causes.
Then you have possible interference issues if you fit a power assist.
And no doubt someone will mention planes use it, it only took decades and billions to do.
Car companies are still currently trying to perfect it.
Hooligan
Location: Base of the Rocky Mountains, Canada. Wonderous things!
Bikes: 2010 Cannondale Hooligan 3
It would be neat, but I don't see the benefit of it besides well, being neat. On a bike, what design could you cook up that you'd need remote steering for?
Try it and report back.
Recumbent Evangelist
Bikes: Rebel Cycles Trike, Trek 7500FX
You can get close to joystick control with a trike like the Windcheetah. It has a central control arm that rotates around a U-joint.
Bendigo Youth Racing
Sounds awfully unnessacery and heavy. Plus, you can't beat "feeling" the road beneath your tyres. The loss of a direct link from your hands to the road surface would make steering more of a guessing game then it ever should be.
Uber Goober
Seems to me that servos big enough to control a bicycle would suck up a fair bit of power, which means a sizable battery to lug along.
cyclopath
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
Liked 6 Times
Sounds like a great idea for a shaft drive vertical tandem trike....
No need for shaft drive - put the servos on the bb and the front axle. Front wheel drive with no chain!
cyclopath
Liked 6 Times
Sure - perhaps one of those 30hp gas powered servos and you'd really move!...
