Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Ask your small, random, track-related questions here
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 09-03-14, 09:17 PM
  #1276
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
Originally Posted by Hida Yanra
You know how I do it...
carleton is offline
Old 09-03-14, 10:37 PM
  #1277
derek.fulmer
derek.fulmer's Avatar
Can I run a DA 7700 BB with 7710 cranks or do I have to have 7710 for both?
derek.fulmer is offline
Old 09-04-14, 12:02 AM
  #1278
carleton
Elitist
carleton's Avatar
Yes.
There are also some Ultegra and 105 BBs floating around that will work, too. I don't know the model numbers, but they are much cheaper.
carleton is offline
Old 09-04-14, 02:54 PM
  #1279
derek.fulmer
Originally Posted by carleton
Yes.
Awesome is the Dura Ace 7710 stuff still available new or has it been discontinued? That's the impression I've been under.
Old 09-04-14, 03:27 PM
  #1280
carleton
Elitist
carleton's Avatar
It is still produced new. Just because it's old tech, doesn't mean they stopped producing it.
It is the track standard for racing and is even certified for racing NJS events (big money) in Japan. Just like the square tapered Campagnolo Pista and Sugino 75 cranks and bottom bracket are still currently being produced.
Shimano even still makes high-end race wheels for road and track using loose ball bearings. Their new track disc and 5 spoke use the 7600 track hubs which are loose ball. I've seen some Dura Ace road wheels with loose ball, too.
If it ain't broke, don't fix it.
carleton is offline
Old 09-04-14, 05:13 PM
  #1281
derek.fulmer
Good to know, thanks!
Old 09-07-14, 12:38 PM
  #1282
MrMinty
Bikes: Cannondale Caad8, Claud Butler Roubaix, Raleigh Equipe
Quoted: 14 Post(s)
How do I know when a chain is binding?
MrMinty is offline
Old 09-07-14, 12:55 PM
  #1283
carleton
Elitist
carleton's Avatar
Remove the chain and pull it over your fingers and see if you notice a stiff spot.
carleton is offline
Old 09-07-14, 03:28 PM
  #1284
MrMinty
Quoted: 14 Post(s)
Thanks. How slack should the chain be?
MrMinty is offline
Old 09-07-14, 04:42 PM
  #1285
carleton
Elitist
carleton's Avatar
If you do find a stiff spot, gently bend the chain laterally back and forth till it loosens up. It should only take like 2-3 wiggles.
Not to be rude but I'm in the gym and can't type much. Google track bike chain tension for videos.
If your chain is stiff and hard it's too tight. You should have about 1" of vertical play when the wheel is set.
Too tight is bad. It binds and wastes watts via friction.
carleton is offline
Old 09-08-14, 07:52 PM
  #1286
Owen21
Generic bike question: For my birthday i'd like to get myself a track specific bike. Now i like the look of the Dolan Pre Cursa's and have ridden them at the track a few times, plus you can customise the colours etc on their site when you order. Also in the frame is the Hoy Fiorenzola - better components but not as eye catching and i havent actually ridden one with intent. Also on ebay is a Switch carbon, Ridley and Race-lite Pista - not too familiar with these. Also a Moda fresco, or FormeTR1.0??
Any advance on the above? im leaning towards the dolan i think....are there any other i should also consider?
Owen21 is offline
Old 09-09-14, 12:12 PM
  #1287
700wheel
Quoted: 144 Post(s)
Liked 14 Times in 11 Posts
I would say get a bike that best fits your body geometry. I've owned Benotto (steel), Bates (steel), Leader (alum), and Ridley (alum) framesets. The Ridley is the best fitting and handling bike I've owned to date. I ride masters TTs.
700wheel is offline
Old 09-09-14, 11:10 PM
  #1288
TurtleRacer
Chain maintenance
How often do you clean/lube your chain? (I'm sure it differs if you're riding indoor vs outdoor tracks)
TurtleRacer is offline
Old 09-10-14, 12:33 AM
  #1289
carleton
Elitist
carleton's Avatar
It's not really a function of time. It's more of when it's gritty or dry.
carleton is offline
Old 09-10-14, 04:10 PM
  #1290
carleton
Elitist
carleton's Avatar
Does anyone have a link to results for the 2014 Pan-Am track championships that are happening now?
carleton is offline
Old 09-10-14, 08:07 PM
  #1291
gl98115
Quoted: 141 Post(s)
There are some results being posted on Twitter hashtag #ccpista . @FixedGearFever is retweeting random links as well. I couldn't find anything comprehensive, but I was only searching in English.
The daily resultados are posted here:
https://federacionmexicanadeciclismo.com.mx/
gl98115 is offline
Old 09-16-14, 10:56 AM
  #1292
carleton
Elitist
carleton's Avatar
Can someone offer a good example of a pursuit schedule and/or how you'd like to see it represented in a mobile app?
*The closest thing to a pursuit I've ever done is a kilo
carleton is offline
Old 09-16-14, 11:17 AM
  #1293
Quinn8it
Quinn8it's Avatar
Bikes: Bianchi Pista, Bianchi Vigorelli
hey Carleton-
did you ever see the one that was on FGF?
you picked a goal time and a "start lap differential" and it gave you your goal splits. It also included things like cadence, speed, pedal revs per lap...
Im about as far from being a Pursuiter as you are.. But my understanding is most set a schedule based on even splits and then ramp up as the get near the end..
Quinn8it is offline
Old 09-16-14, 11:59 AM
  #1294
carleton
Elitist
carleton's Avatar
Originally Posted by Quinn8it
hey Carleton-
I remember a spreadsheet of some sort. But I deleted it back in 2009 or so.
BTW, I have made lots of progress. I'll email you later today.
carleton is offline
Old 09-16-14, 12:13 PM
  #1295
Quinn8it
Quinn8it's Avatar
Another feature that's pretty cool- was included on that track app that came out a year or so ago (by a team USA sprinter)
was a standard UCI count down to the stopwatch starting.. Let your holder focus on holding you- and ten just do splits and stop
Quinn8it is offline
Old 09-16-14, 12:37 PM
  #1296
Hida Yanra
VeloSIRraptor
Quoted: 22 Post(s)
mmmm I don't know where my pursuit sched is, gear bag is out on loan, but let me dig around and see what I can find?
Hida Yanra is offline
Old 09-16-14, 01:11 PM
  #1297
700wheel
Quoted: 144 Post(s)
Norman Sheil's Training Manual has pursuit schedules (see page 61- 69). Perhaps a little out of date today for elite riders but might be useful for some masters age groups.
700wheel is offline
Old 09-16-14, 02:58 PM
  #1298
carleton
Elitist
carleton's Avatar
According to Amazon, it's out of print
carleton is offline
Old 09-16-14, 02:59 PM
  #1299
carleton
Elitist
carleton's Avatar
Great idea!
Thanks!
carleton is offline
Old 09-16-14, 05:36 PM
  #1300
slindell
Looking for something like this?: https://www.easterleycycling.org.uk/pursuit_schedule.xls
The simple method is to take the target time subtract 5 seconds for the start then divide by the lap count to get time per lap, add 5 back for the first lap.
The preferred method is to look at the calendar and if it is an odd numbered year it might be time to ride one.
slindell is offline
