Go Back  Bike Forums > The Racer's Forum > Track Cycling: Velodrome Racing and Training Area
Ask your small, random, track-related questions here
Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Old 11-11-14, 04:46 PM
  #1501
WhatsYoCadence
Annoying Member
WhatsYoCadence's Avatar
Originally Posted by carleton
Adding road gears was Mike Dancel's idea. I never did many track training efforts on the road. My road bike was for easy rides mostly. I'm glad to see you guys getting use out of it.
I'm open to feedback, most of which eventually makes it into the app. Right now I'm adding the option to indicate which tire size you are using for precise calculation based on Mark Tyson's suggestion. Basically it's only 1% difference, but for the athletes he coaches, they train all year for a 1% gain...so precision is important.
I think that would be a good thing to add and get out of the way. What's the name of your app?
WhatsYoCadence is offline
Old 11-12-14, 11:18 PM
  #1502
derek.fulmer
derek.fulmer's Avatar
Should I get a custom wheel set made, or just get mavic ellipse's? Custom wouldn't be fancy or special. Clinchers, training and racing double duty.
If custom, what rim/hub combo? I'm about 225lbs.
Anything special about the mavics I should know about?
derek.fulmer is offline
Old 11-13-14, 12:21 AM
  #1503
700wheel
Quoted: 144 Post(s)
Liked 14 Times in 11 Posts
I was going to buy a set of ellipses but I read somewhere (on this forum I think) that there are no serrations on the axle nuts that face the inside frame dropouts and may slip under load. Is this true?
700wheel is offline
Old 11-13-14, 12:27 AM
  #1504
derek.fulmer
I dont think the spoke count is high enough for me any way.
Anyone have any thoughts on H+ Son archetypes for entry level racing? Im sure theure fine for training.
Kinlin? Velocity? Two other brands suggested to me.
Old 11-13-14, 07:07 AM
  #1505
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
My apps can be found here: https://itunes.apple.com/us/artist/c...ll/id925659196
You don't need a custom set of wheels. I weigh more than you and Ellipse have worked for me (even with only 20 spokes) or any 32 spoke wheels really.
The lack of serrations seem to allow the axle the spin when you are tightening the wheel on to the frame. This has nothing to do with whether the wheel will slip under load or not. I've never had an Ellipse slip under load.
They are pretty fast wheels, too. I once set a PB flying 200M on them. They are great for use as training/race wheels. I own a set right now.
Just buy some pre-built wheels. You don't *need* custom wheels. Buying custom track clincher wheels is luxury, not a necessity. If you were going tubular, then your options are sorta limited. But, for clinchers, there are LOTS of inexpensive pre-built sets out there. Go to velomine.com.
carleton is offline
Old 11-13-14, 08:35 AM
  #1506
mukman
Is there a huge reason why you would want 50/16 over 47/15? They're pretty close in gear-inches, so in theory it shouldn't matter, yes?
mukman is offline
Old 11-13-14, 09:07 AM
  #1507
Velocirapture
Velocirapture's Avatar
Bikes: S-1 :-D
Quoted: 17 Post(s)
This has been discussed at a bit of length somewhere here before - someone may be able to point you to the thread. Basically there are folk who say there is no different, and folk who have a distinct preference for what combination takes them to a particular ratio.
For the latter group, sprinters or any rider needing to make quick accelerations would theoretically favor the 47/15 (small/small) combo - less chain links for an overall lighter chain, and smaller cog and ring for both less turning mass, and (possibly? i may have my physics wrong), better leverage at the crank - these factors make for a 'snappier' drive train that can accelerate just that little bit better, as there is not as much momentum.
And drive train momentum would be the same reason the large/ large combo would be theoretically preferred by pursuiters; it might not get up to speed as quickly, but when it is you have a bit of a fly wheel effect. Additionally, the more open link angles where the chain wraps around the cog and chain ring give slightly less friction
Differences are obviously very small. I'm not sure if i would feel the difference, but some folk can.
Velocirapture is offline
Old 11-13-14, 09:11 AM
  #1508
queerpunk
aka mattio
queerpunk's Avatar
Bikes: yes
Quoted: 344 Post(s)
Liked 58 Times in 35 Posts
Some people say some things about how you should use the largest possible combinations. I don't know. Always sounds like witchcraft to me.
From what I can see there's a .2 GI difference between 50/16 and 47/15, so no, there's not a huge reason, but there's a .2GI reason. Sometimes you need something a hair larger or smaller.
queerpunk is offline
Old 11-13-14, 09:29 AM
  #1509
carleton
Elitist
carleton's Avatar
In theory yes, but in practice, no. The problem comes with having enough chain to put on warmup gears and race gears. Certain gear combinations take up a little chain and others take a lot of chain. After you do this for a while, you'll find a "family" of gear combinations that will allow you to warmup and race without having to change your chain. Changing chains is a pain when you are exhausted between efforts.
Also, both of the gears you list are warmup gears.
carleton is offline
Old 11-13-14, 09:37 AM
  #1510
mukman
Ok cool, I'll do 47/15 for now since I already own the 15 and it's easier to find a 47 than a 50 here. I understand these are warm-up gears, I am just starting at the velodrome and trying to get through their introductory trainings. I kind of doubt I will race this season, maybe I will just be training.
mukman is offline
Old 11-13-14, 09:50 AM
  #1511
carleton
Elitist
carleton's Avatar
I've found that for beginners, there is a smart order in which you should buy your gears in order to maximize usage. Kinda like when you get your first professional job and need a basic wardrobe on a budget. Some things you'll use a lot, so buy those first.
https://www.bikeforums.net/track-cycl...l#post13581017
carleton is offline
Old 11-13-14, 10:43 AM
  #1512
carleton
Elitist
carleton's Avatar
I'm in a bike shop now and apparently American Classic makes a track wheel just like the Ellipse with 20 bladed spokes. I'm looking at them on a Langster. They are probably cheaper than Ellipse. They are nice.
They have weird locks on the nuts though. Or it's a one sided cinching system. Weird for sure.
carleton is offline
Old 11-13-14, 10:44 AM
  #1513
carleton
Elitist
carleton's Avatar
It also has an Izumi V chain. Odd.
carleton is offline
Old 11-13-14, 12:50 PM
  #1514
derek.fulmer
Thanks carleton. When i say custom, i definitely don't mean super expensive or exotic. I just mean choosing the right rim/hub/spoke pattern & spoke type for my needs. I have a great relationship with velomine and will likely go through them or Psimet who is local to me.
Old 11-13-14, 04:18 PM
  #1515
WhatsYoCadence
Annoying Member
What are some well respected track frames for racing?
Where do all the high end fixed gear frames (cinelli, all-city, dodici.. etc) stand up?
Old 11-13-14, 06:04 PM
  #1516
carleton
Elitist
carleton's Avatar
Read here: https://www.bikeforums.net/track-cycl...ete-bikes.html
As far as your second question goes:
That is too broad. This isn't the fixed-gear forum. You should ask over there: Singlespeed & Fixed Gear
I know you are curious about a lot of stuff, but specific questions get specific answers. Don't expect us to do a brain dump of info to satisfy a passing curiosity.
carleton is offline
Old 11-13-14, 07:50 PM
  #1517
bigfred
Bikes: More than 1, but, less than S-1
Quoted: 5 Post(s)
....specific questions get specific answers. Don't expect us to do a brain dump of info to satisfy a passing curiosity.
Carleton, mind if I borrow that?
Birth Certificate, Passport, Marriage License Driver's License and Residency Permit all say I'm a Fred. I guess there's no denying it.
bigfred is offline
Old 11-13-14, 08:13 PM
  #1518
noglider
noglider's Avatar
Quoted: 7333 Post(s)
Liked 2,430 Times in 1,419 Posts
Hahaha! OK, I'll take a crack at it:
How do all the high end fixed gear frames (cinelli, all-city, dodici.. etc) stand up?
The high end stuff is generally well respected.
noglider is offline
Old 11-13-14, 08:37 PM
  #1519
McRussellPants
The Ammy Cs generally go 650-750 on eBay.
The downsides you listed aside, Theyre lighter than the ellipses by about 200 gram and the hubs are so smooth. They're tough as nails too, 230lbs when I was using them for hipster alley cat duty.
I can't speak highly enough about them. Besides that one sided rear.
McRussellPants is offline
Old 11-14-14, 12:58 AM
  #1520
Velocirapture
Bikes: S-1 :-D
Quoted: 17 Post(s)
Has/ does anyone use pre-work out suppliments, specifically those with Nitric Oxide? And if so, would that be only for weight-training or sprint training, or has anyone found benefits for general track training?
Old 11-14-14, 02:32 AM
  #1521
TurtleRacer
Relevant BroScience video: https://www.youtube.com/watch?v=KmmZULPUEkQ
Supplements should be used to 'supplement' that which is missing or lacking. Taking an untargetted supplement with not known ingredients doesn't fit that bill, and I think is a bit scary.
Do you already have your diet, sleep, training and coaching dialed in? If not, I'd focus on getting those dialed in before worrying about supplementation.
Note to self: I should dial in my diet, sleep and training...
TurtleRacer is offline
Old 11-14-14, 03:02 AM
  #1522
carleton
Elitist
carleton's Avatar
Supplements work. Creatine monohydrate, among others, works.
Maybe Velocorapture has dialed in diet, sleep, training and coaching. Is that your business? The question was about supplements.
carleton is offline
Old 11-14-14, 04:51 AM
  #1523
Minion1
Quoted: 51 Post(s)
Liked 23 Times in 19 Posts
I've found Creatine to be great for the gym, though the amount I had to take was quite high and it wasn't cheap. It definitely made recovery between sets much, much better, and I had a lot more energy afterwards. I got 2 months worth for free through work, and used it when I started going to the gym earlier this year, so there may have been some easy novice gains in the mix as well, but if I was going to look at supplements it'd definitely be on the top of the list.
Rugby players at my school were all over it, especially the positions where you can't bulk too much, but they needed to increase strength as much as possible (think school boys playing grown adults at club level).
Can't talk too much about the effect on on - the - bike training, since I was taking it during winter and our velodrome was closed for refurbishment.
edit; perhaps ask in the weightlifting thread? There are some quite experienced guys in there that may not check this thread as much.
Minion1 is offline
Old 11-14-14, 06:43 AM
  #1524
Velocirapture
Bikes: S-1 :-D
Quoted: 17 Post(s)
Thanks for the responses thus far.
I'm specifically interested in the effects of NO, either as a direct supplement or via the precursor, Argenine... but probably better to ask in the weightlifting thread, thanks Minion1
Old 11-16-14, 02:24 AM
  #1525
Owen21
Does anybody do any sprinting of the running form to supplement their training? Or is it not transferable?
Owen21 is offline
