What's this part?
What's this part?
Hi all - been riding my 197? peugeot for several years with the odd repair here and there. Most recently the crank assembly seized up and I had to disassemble, grease and reassemble. Changed the pedals while I was at it. here's the thread: https://www.bikeforums.net/classic-v...-question.html
I got hit by a reckless cyclist the other week - ruined the front wheel and bent the front forks beyond repair. The frame was ok. (so were the both of us). I found another vintage Peugeot on Craigslist to part together a full bike. I broke a part in disassembling one of the headsets (don't remember which one now:
This fits right between the washer that holds the front brake cable and the nut that holds the front fork in place. Does anyone know 1. what it's called, and 2. where i could source a replacement? (short of buying a whole noter busted up old bike to steal parts from)
Thanks!
Geoff
Thanks!
Geoff
Quoted: 978 Post(s)
Liked 1,642 Times
Gee... I got about four of these that look just like it... Broken in half... Ha
Just get some aluminum headset spacers. The notch and holes are not really that important. The space it occupies is...
Likes For zandoval:
Quoted: 604 Post(s)
Liked 1,064 Times
It is one of these, a drilled 1” headset spacer, apparently I bought the last one a couple of weeks ago.
Tim
Tim
Likes For tkamd73:
blahblahblah chrome moly
Quoted: 1182 Post(s)
Liked 2,579 Times
If you leave the holy washer out, you'll need to also remove the pin on the screwed race that sticks up into the hole in the washer.
Likes For bulgie:
Quoted: 1645 Post(s)
Liked 837 Times
Cool drillium holes on that thing......but it makes it much more prone to breaking like the one pictured..... I think you could not see those holes anyway; when the headset is installed.....
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Liked 2,579 Times
If you don't want to remove the pin on the screwed race, like out of a conservationist, stewardship impulse, then (1) good on ya, and (2) just drill one hole going that direction in a normal headset washer, for the pin to go up in. Then you have to remove the tongue if it's a tongue washer, or file the hole round if it's a D-shaped hole for a steerer with a flat. The washer with the hole will need to be free to rotate, or you won't be able to adjust the headset. Sorry if I'm belaboring the obvious.
That might be too much work, so I won't judge ya if you just perform a pin-ectomy. These aren't precious artifacts.
AFAIK, the headset in question is a Peugeot proprietary part, maybe even made in-house? Never seen 'em on any other bike brand, except for the badge-engineered brands like Helium that were just Peugeots in other livery. They didn't use the Peugeot headsets in PXes though, not that I saw. PX-10 and it's higher-end cousins always got a brand-name headset like Stronglight.
I think the headset with the "drillium" adjusting washer was used on UO-8 and its lower-end cousins.
Quoted: 2365 Post(s)
Liked 1,753 Times
Seems to me the spacer is drilled all the way around in order to accommodate the pin in the threaded race no matter what angle/position it's in when it's properly loaded. And the spacer then ties that position to the steerer via the internal notch that engages the slot on the steerer. This is analogous to the headsets that have the jagged-tooth interface between the threaded race and the spacer, which also has the internal notch. Of course, there are plenty of headsets that rely simply on the pressure between the treaded race and the locknut, via a notched washer, without any such "indexing". I reckon this design and the jagged-tooth design allow for lower torque on the top nut.
Likes For madpogue:
Quoted: 1110 Post(s)
Liked 1,330 Times
That is a supposed locking mechanism so (supposedly) the cone won't move when you tighten the locknut.
It is another bad idea (see fluted seatposts etc) because
a) it doesn't work
b) it limits the precision of cone adjustment - you only have as many positions as holes - almost certainly one will be too tight and the next too loose.
Throw it away, knock off the pin, use a plain spacer if necessary, and prevent the cone from moving by, um, preventing from moving: use TWO spanners.
You can get perfect adjustment, and it won't change.
a) it doesn't work
Stop reading my posts!
Quoted: 1448 Post(s)
Liked 1,067 Times
I agree it's fussy and prone to break: IIRC it's some zinc-alloy too so even more brittle than if they had used steel.
That said I believe I have a complete HS with that washer (unbroken for now) from a 1950's era Peugeot which I'd sell complete and you could take any/all parts from it that you want. But I don't want to break it up (if it is complete like I remember) just shoot a PM
UPDATE: my "complete but without loose bearing balls" HS is SOLD.
For the trivia buffs this was supposedly circa 1952 and the "perforated washer" was indeed not steel, something like zinc alloy.
The thing I noticed is several of the parts were stamped with a "Peugeot Lion" logo so this was a proprietary part BITD.
Likes For unworthy1:
Liked 1,753 Times
The catch is, a lot of the headsets that use race locking mechanisms like this, and the jagged-tooth style, do not have flats on the threaded race for the preferred two-spanner approach as described above. So if you decommission the locking mechanism, you need some other way to hold the threaded race in position. A strap wrench might do the trick.
Or, at that point, a headset that actually accomodates two spanners might be in order. Depends on your level of ambition.
Liked 2,579 Times
Yes, see posts #7 and #8.
With only one hole drilled, you'll need to remove whatever keys the washer to the steerer. A "tongue" in the case of this Peugeot (file the tongue off), or a flat in the case of most other French bikes, making the hole in the washer sort of a "D" shape. File the flat off until the hole is round.
Likes For bulgie:
Liked 2,579 Times
Likes For oneclick:
Liked 837 Times
If that washer forces you to clock anything on the headset at certain increments, it's not really the best situation, IMO..
I'd rather adjust the clocking with infinite possible positions to provide appropriate amount of drag and tension at the bearings and races of the headset.
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Just so I understand, the amount of resistance on turning the handlebars is only a function of how tight the headset nuts/etc are cranked down, right? Is there any recommended torque specs? Thus far I've just been tightening until it "feels right."
Thanks!
Liked 1,330 Times
I don't think it does lock you into fixed positions, but I'm replacing with a solid washer anyway, since it's broken, so moot point.
Thanks!
Thanks!
The thread pitch is 1mm.
That hole-ey washer thus limits you to adjustment steps of roughly 0.04mm.
It's not difficult (with spanners) to set the cones at intervals on the order of a degree or less.
That means adjustment steps 16 times smaller than what the washer will allow.
Half-decent balls are ground to an accuracy of 0.000025mm, which shows what kind of accuracy is desirable.
Headset bearings need little (if any) preload.
So "tightness" should not be a determining factor in the adjustment; instead lack of play should be.
If you are unsure, after setting the locknut tight against the cone lift the front wheel a few inches off the ground and bounce it; the point at which play occurs will be easily noticed as the fork rattles in the bearings.
Foe extra surety, bounce the wheel with the bars turned left and right - if anything is out-of-round or otherwise mis-aligned that will likely show it.
Likes For oneclick:
Liked 2,579 Times
Thanks!
Thanks!
Then you tighten the the two screwed members (the upper race and the locknut) as tightly against each other as you can, within reason — like don't round off the nut on a soft-alloy headset like Super Record. Then re-check the adjustment because tightening the nut often changes it slightly. You may have to undo it and try again, making small adjustments.
Most bearings are OK with a little preload, i.e. just the tiniest bit tighter than the "no free play" point, because balls and races are elastic and compress under load, causing some slack to appear. I think headsets may be an exception, due to the way they're used, staying in one place a lot of the time, not spinning. I think an overly tight headset will wear out faster than one on the loose side. I still want no detectable free play, but avoid preload beyond that point. That is, err on the loose side, as long as it doesn't clunk.
Some people say to adjust it with the stem installed, on the theory that the quill expander cone or wedge being tightened shortens the steerer slightly. I'm sure that's true at a microscopic level, but I've never noticed that effect, myself. So I feel free to adjust with the stem out. Makes it easier to feel when the friction starts to go up.
EDIT: Looks like @oneclick beat me to it, covered it while I was typing.
Likes For bulgie:
