Bonded Frames
Bikes: A Blue One and 2 Green One's, then there's the Yellow one. And oh, yeah, a Black One. Did I mention the Red One?
Quoted: 75 Post(s)
Liked 195 Times
Bonded Frames Discussion and Pics
I'd be interested to know what people here think of the 90s fad of bonded frame bikes.
Experiences through ownership, grapevine stuff and especially any failures people have had and heard of.
Off the top of my head the most prolific were Raleigh and Trek. We see a lot of these two at the co-op.
So far I have only heard of one failure, and that may have been due to owner error with heat, but they are pushing 30+ years old now.
Are there any current models?
Has it run it's course?
Should they all be scrapped?
Let's see your bonded frame bikes!!
Here's my Raleigh Dyna Tech SP1000. Titanium tubes to Alum lugs. It's on the way back together and should be ready for spring. As it sits, it's together as a mock up for measurements. Frame still needs a couple more decals and clear coat.
Likes For macstuff:
I technically own a bonded frame bike, a late 2000's BMC (about the only manufacturer still doing carbon tubes bonded to aluminum lugs at that point), but that's not terribly old and hasn't had any issues. My brother once owned a late 80's Vitus and the only issue with that was one of the dropouts on the fork came unglued. JB Weld fixed that and lasted up until it got stolen. I'd image it's still holding up today, if it hasn't been stripped of its parts yet.
If one of those older bonded frames comes into my ownership, I personally wouldn't be afraid to ride it. I rather like them and will probably eventually have a vintage one.
Likes For Pantah:
Blamester
I got a pretty much nos tvt 92 6 months ago. I have no fear of it. No amount of normal riding riding will break it.
Likes For blamester:
Groupetto Dragon-Ass
Quoted: 415 Post(s)
Liked 787 Times
I like bonded frames.
Seems to me that it was an answer to how to assemble frames without skilled (brazing / welding) labor.
Miyata, Bridgestone and Panasonic all sold them (I think the Panasonics were built by Araya. and were only one year in the U.S.
1991 Miyata Elevation 5000
1990 Bridgestone Radac 2100
Quoted: 65 Post(s)
Liked 60 Times
Pretty much most carbon fiber frames are bonded frames. The main triangle is made in one piece and bonded to the seatstay/chainstay. Trek still makes their frames pretty much like the 90's OCLV frames of bonding tubes to lugs. Colnago bonds carbon tubes to carbon lugs. Now there's also 3D printed titanium lugs bonded to carbon tubes.
Likes For Retoocs:
Insane Bicycle Mechanic
Quoted: 809 Post(s)
Liked 712 Times
You would do well to look at the previous generation of bonded frames, the Vituses (Vitii?) and Alans. While the bonded aluminum frames held up well, the carbon-fiber tube/aluminum lug frames had a nasty habit of coming apart at the lugs. This was usually due to galvanic corrosion and/or poor preparation of the bonded surfaces. By the '90's the production processes had been worked out. They should be bulletproof.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Original owner of a (97ish?) Trek 2120, carbon fiber tubes bonded to Alu lugs and rear triangle.
No problems! But I ride a lot less than many here.
I do try to give it an inspection and wiggle. I worry most about corrosion from sweat. I swear a lot, sometimes use the bike inside, and my sweat is apparently very corrosive. As in, multiple digital wristwatches of various brands had the back of the body corroding away inside the plating (anodizing?).
It's a nice ride. Not fabulous.
Likes For tgot:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
I had a Bridgestone RADAC, and it's only issue was a shift boss that I recall having to rivet back on.
And then on New Years Day, at Goodwill, for $14.95, I found this one below, a Bridgestone Submariner.
Looked like a brazed or possibly bonded steel frame having normal tubing dimensions, but turns out that all of the lugs, head tube, fork crown and BB shell are aluminum bits, cast directly onto the butted steel main tubes, fork legs, forward ends of the chainstays, and upper ends of the seatstays.
Offered in just two frame sizes, and a Mixte (die-casting molds apparently aren't cheap).
My understanding is that this was a low-cost method of mass-production for these 1970's, very heavy road bikes (mine is the lowest level that they offered) and was re-branded as SuperCycle, distributed by Canadian Tire.
With upgraded (wider/longer) bars and stem, and with a bigger (now 6s) freewheel and clipless pedals, it's currently serving as my daily winter beater, for on- and off-road riding. Yeah, the tires are overdue, I believe that the front "tyre" is original. Rear axle spacing is oddly a full 140mm, with heavily-offset chainline to match, and the seatpost is the internal expanding "quill" type (which is no bueno in terms of the prospects of upgrading to a micro-adjusting saddle clamp).
Frame geometry is roughly 72x72 for a decent off-road riding experience, chainstays seem short enough for decent climbing traction.
Likes For dddd:
Quoted: 835 Post(s)
Liked 2,157 Times
I have an '86 LOOK KG86 - bonded carbon to alloy lugs. I was very excited to get the frame (here from another forum member) as it made a pair with my steel LOOK 753 from the same year in the La Vie Claire livery from Lemond's Tour victory. I rode it for a couple months with "ghost shifting" issues with the front derailleur when pedaling hard or out of the saddle before I realized the BB shell was not attached to the seat tube. (With about 80-100 lbs. of force, the BB shell moves about 2-3mm downward on the seat tube.) I do hope to get it repaired at some point, but I am now reluctant to purchase bonded frames from that era. I'm more open to an ALAN frame which is has a better construction, being both screwed & glued.
Likes For gaucho777:
Bikes: Trek 400 Elance, Losa Winner, 1994 Schwinn Paramount, Specialized Tarmac Pro, Miele SLX, Ibis Ripley, Colnago Oval CX, 84 Masi GC, 1986 Schwinn Voyageur, 1988 Schwinn Tempo, 1998 Schwinn Peloton, 1991 Paramount Ser3
Quoted: 150 Post(s)
Liked 90 Times
Nothing wrong with bonded. The adhesive were very high tech, really coming from the airplane industry I think. There was the sort of early wave of straight bonded tubes, Look, Alan, etc, and then during the heyday of high end aluminum frames, bikes with carbon fiber "rear forks" starting showing up, and LOTS of bike companies got in on that. Failures were not common as far as I know, and those were the years I was riding most.
Likes For AngryFrankie:
Quoted: 175 Post(s)
Liked 452 Times
Rather pre 90's and going to 1987. Still in use, Trek 8000 bonded 7000 series aluminum hardtail mtb. Believe their first series of this type. Super robust, ones body will break before these frames will.
Contrary to Treks first gen of road bikes bonded ally lugs and carbon tubes. Trek admitted defeat and I personally knew a few whom were warranted replaced frames though in all aluminum. And those individuals acquired their carbon bikes, used. Factory rep signed off and all the dealer had to do was cut the old frame in half.
I forget all the details but apparently the tolerance of male lug to carbon tube was too tight and the bonding agent was squeezed out. Then came improved lugs with grooves for the glue. Shortly Bevil Hogg with Brent Trimble's early experience had moved towards monocoque.
With caution I still dig the early survivors carbon tubed bonded lugged bikes. Can't overlook enough and do consider its history, what climate its been in, potential hard life, etc.. Plenty of modern components and wheelsets, gearing and great cranks to have a mid 17 lbs. considered vintage carbon bike that fly.
Likes For chain_whipped:
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1298 Post(s)
Liked 940 Times
I, personally, have never even seen a photo of a compromised lug on a Raleigh Technium. I get 600-700 miles in on mine every summer. The technology had advanced a lot by the time the Techniums/Dynatechs came out: over-sized tubes, better aluminum, better quality control, etc. The technium lug relied on three different ways to keep the lug intact; 1.) the flux itself, 2.) the contraction of the steel lug onto the tubing after it had been heated and 3.) a "lock-ring" that snapped the tube into place when it was inserted to the lug.
Unless you climb the rungs strategically, you’re not going to build the muscle you need to stay at the top.
Likes For 1989Pre:
Quoted: 415 Post(s)
Liked 787 Times
Specialized sold their Epic line. I think they were built by Giant.
The second generation (painted lugs) is quite a bit lighter and a real sleeper.
1990 Specialized Allez Epic
1994 Specialized Epic
Likes For Chuckk:
Quoted: 569 Post(s)
Liked 590 Times
I love my '91 (grub screw model) and now 73 with osteoarthritis it is one of my vintage bikes I still put a lot of miles on due to the ride. Being much lighter than my steel frames, 25-35%, it is under 19lbs, has aggressive geometry with 74º seat and head tube angles yet I regularly ride it with my newer titaniums. What many call a noodly frame back in the day my arthritis appreciates the vertical compliance.
Quoted: 75 Post(s)
Liked 195 Times
I'm glad to hear that these bikes aren't beleaguered and are still being ridden.
There was a vid on YouTube about the resto of a Dyna Tech and during the first test ride, the head popped off. Can't get any replies but I'm thinking the glue failed from the respray and subsequent "stoving" of the paint.
(Heat is how you get glues to release. 300+ F)
The techniums are a bit different animal than the dynas. I've heard from a former spd Raleigh employee that mentioned the aerospace adhesives used on the dyna's but the techniques are put together differently and are Raleigh US bikes, not sold in the UK.
Mine was brought into the co-op and was claimed for a year before being disassembled and readied for scrap.
I took it home and stripped the paint to see the conditions underneath. It seemed ok, it had paint loss only on the lugs so the shop was wary of it. After paint removal and inspection of the joints, I think it will be ok but I'm still a bit nervous abt. it.
It won't be ridden hard by me, but how long it will last is a concern for the amount of effort and money I'll put into it.
Paramount Fan
Bikes: Paramounts, Raleigh Pros, Colnago, DeRosa, Gios, Masis, Pinarello, R. Sachs, Look, D. Moulton, Witcomb, Motobecane, Bianchis, Fat City, Frejus, Follis, Waterford, Litespeed, d'Autremont, others, mostly '70s-'80s
Quoted: 123 Post(s)
Liked 242 Times
I remember a magazine ad for these in which they touted how the ends of the tubes were swaged to provide a mechanical lock inside the "lug." I recall that the bikes were so ugly we foolishly thought the Japanese were not going to be much competition, not realizing that they were just finding their range, walking the tracers to the target.
Paramount Fan
Quoted: 123 Post(s)
Liked 242 Times
Likes For sbarner:
Quoted: 2326 Post(s)
Liked 5,012 Times
I've got a Raleigh Technium SuperCourse that is quite lovely and surprisingly nice to ride. Upgraded the heavy RX parts to a Dura Ace/Ultegra 10 speed setup.
Hard to capture but the paint on these is really quite lovely with a deep shine to it.
Steel is real...and comfy.
Likes For jamesdak:
Quoted: 2364 Post(s)
Liked 1,751 Times
Back on topic - Yes, I'd say the bonded "thing" really took off in the late '80s. I've read somewhere here on BF that this 1988 Ironman "Carbon" is actually carbon-fiber-clad aluminum. It certainly appears so, peering down the seat tube:
Makes me wonder if some of its contemporaries (Allez Epic, etc), aren't actually constructed the same way.
I recall reading at least one thread referencing the bonds on one of these frames coming loose, rendering it a wall queen. I wondered about mine the first couple times I rode it, but I'm quite certain now that it's just the squirrely nature of the frame material that I'm feeling in the handling, not any reflection on the bonds. It was an impulse buy/build, completed with parts-bin parts, so I'm just going to ride it until... I can't.
Bikes: '87 Serotta Colorado,'96 Moots VaMoots, Bertoni MAX, Eddy Merckx Grand Prix Team USA
Quoted: 171 Post(s)
Liked 339 Times
Glad to hear so many have had good luck with their bonded frames, but I would recommend caution when buying/riding these frames. I purchased an old Vitus Carbon fiber bonded frame some time ago. I purchased it for the groupset really, but while checking the frame once I removed all the components, I was amazed to find I was able to pull the frame apart with my bare hands with not much force at all. Not saying they will all fail, but that glue from the 90's isn't going to last forever, especially if your bike lives in a harsh climate.
Check out this video from youtuber Bike-it.
Likes For velomateo:
Quoted: 2490 Post(s)
Liked 2,961 Times
The Raleigh Technium factory was located in Kent, Washington, making it easy to hire away some of the aerospace engineers who were working in Boeing's headquarters.
I wouldn't be surprised if a joint or two on a handful of Technium frames failed, because it's always possible for, e.g., an aluminum tube to miss a QC step and develop an oxide layer before glue was applied.
But reports of such failures are rare compared to the apparent failure rates of the European bonded frames, to say nothing of the number of cracked brazed or welded steel, aluminum, and titanium frames that have been cited on Bike Forums and elsewhere over the years.
Likes For Trakhak:
Quoted: 1641 Post(s)
Liked 831 Times
Just don't put them away wet and they will last a long time.
Better yet, just designate a wet weather, all metal bike that have a welded or brazed construction.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Bikes: 1993 Diamond Back Sorrento, 1965 Schwinn Racer 3-speed, 1987 Schwinn High Sierra, 1990 Specialized Sirrus, 2020 Specialized Sirrus 3.0, 2013 Giant Seek 1
Quoted: 87 Post(s)
Liked 776 Times
My Technium Tri-Lite is a smooth riding bike. One of my favorites!
Liked 2,961 Times
Likes For Trakhak:
Quoted: 576 Post(s)
Liked 1,003 Times
FWIW, this is what it looks like when you saw through the top tube of a bonded Trek frame.
Pretty much what you'd expect to see: carbon over an Al lug with bonding agent squeezed through.
