Can cycling and aspirin be the cause of my ED?
Quoted: 32 Post(s)
Liked 5 Times
Hello guys,
I cycle 30 miles everyday and as a disabled vet I my knees and back are jacked so I take lots of aspirin (Bayer Back & Body). I was with a young lady that im seeing (monogamous) and one night and I could not perform. I also noticed I dont get excited as I once did and iv always had a very strong sex drive. Went to the doctor to see if I could get some advice. After an exam the doctor concluded that my long bike rides and aspirin could be the culprit.
Be the person I am, I came home and did my own research and sure enough I found research that backed what doc is saying.
I ask you guys because this is a cycling forum, have any of you experienced erectile disorder and feeling cycling could be the cause. If so, have you encounter any successful remedies.
FYI, I'm 36.
Flame suit on!
FYI, I'm 36.
Flame suit on!
VFL For Life
Bikes: Velo Volmobile
Quoted: 28629 Post(s)
Liked 1,858 Times
Quoted: 70 Post(s)
Yeah, once I went over about 200 miles a week I started to get a numb dick. It hit me after a 120 mile ride after about 3 months of really aggressive ride lengths. Totally numb dick. I stopped biking until I could feels things again. Took about a month.
If you routinely put in high miles you need a noseless saddle. Holes, cutouts, depressions, etc. don't matter and they make things worse. Notice that this will happen to anyone who has human nerves and blood vessels in their legs. Skill, toughness, and experience will not save you. Age counts against you as well.
The rule seems to be that any nose length over 3 inches (-ish it depends on your body's exact size) will cause the problem.
See:
https://www.cdc.gov/niosh/docs/wp-so...s/2009-131.pdf
https://www.health.harvard.edu/blog/...e-201209145290
https://www.webmd.com/men/features/b...-a-real-risk#1
I then discarded all of my saddles (Sob!) and moved to ISM PR saddles.
https://www.amazon.com/s/ref=nb_sb_s...=3OFL339W2MRDD
I also use a BiSaddle https://www.bisaddle.com on my hybrid.
And I tried a "Spongy Wonder" Home - Spongy Wonder However, they are for VERY upright riding.
So, the bad news is that I use dorky looking saddles. The good news is that my dick and the ladies are happy again.
See:
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
The modern cut-out saddles may be a good idea.
As would be playing with tilt on your own.
If you do not have a properly adjusted center cut out saddle - start there first.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
First, make sure you stand or at least lift your butt off the saddle every couple of miles. Next, be certain you have the right position/adjustment for the saddle. It should be relatively level with a slight bend in your knees and most of your weight over your sit bones. Lastly if those two don’t work, experiment with different saddles.
Casually Deliberate
Hello guys,
FYI, I'm 36.
Flame suit on!
FYI, I'm 36.
Flame suit on!
Good luck to you and the young lady!
Quoted: 18378 Post(s)
Liked 4,512 Times
I believe the nose of the saddle should be pointed at the handlebars. So, if you have a the bars above seat level, then you can have the seat level.
If you have the bars below seat level, then you may need to point the seat downwards a bit.
If you feel weight, or experience pain or numbness in the nether region, then make changes so you don't feel weight, pain, or numbness.
In Real Life
Bikes: Lots
Quoted: 3203 Post(s)
Liked 596 Times
When did Bikeforums become a medical site?
Suggestion: see a doctor!
Rowan
My fave photo threads on BF
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Quoted: 761 Post(s)
My understanding is that he did see a doctor who gave a diagnosis (cycling and aspirin) and he wants feedback from the community as well. Sounds like a good strategy if the Dr doesn't ride or know much about cycling.
In Real Life
Bikes: Lots
Liked 596 Times
Better to get a second opinion from someone in the medical profession.
Rowan
Machka's Website
Photo Gallery
Rowan
Machka's Website
Photo Gallery
Liked 4,512 Times
Or ask for a referral to a doctor in sports medicine.
Still, it doesn't hurt to get an idea of some of the questions to ask.
What is the connection between NSAIDs and erectile dysfunction (ED)? | ISSM
Aspirin, ibuprofen, naproxen and other NSAIDs can cause erectile dysfunction.
I cycle half what you do and I don't need NSAIDs. I'm 52. If I were you I'd figure out what was causing the pain. Too many miles, bad fit, whatever it is, is the source and quit taking aspirin. It's also rough on the stomach.
I would also look for a seat that didn't hurt my junk.
Quoted: 18424 Post(s)
Liked 15,581 Times
Interesting story behind the discovery of Warfarin, the "Warf" of which stands for Wisconsin Alumni Research Foundation:
https://en.wikipedia.org/wiki/Warfarin#History
Catching Smallmouth
Bikes: 1990 Specialized Sirrus Triple, 1985 Trek 460, 2005 Lemond Tourmalet, 1984 Schwinn LeTour 'Luxe, 1988 Trek 400T, 1985 Trek 450, 1997 Lemond Zurich, 1993 Diamond Back Apex, 1988 Schwinn Circuit, 1988 Schwinn Prologue, 1978 Trek TX700, Sannino
Quoted: 88 Post(s)
Liked 134 Times
I am 43 and also a disabled Veteran. When I retired a few years ago I picked up cycling. I needed a new physical outlet and it's been perfect for me.
I went through the same thing. I needed to correct my bike fit, get the right saddle, stand up every couple miles and ease into higher mileage. I have had zero issues since making those adjustments. Lots of good advice above.
Quoted: 119 Post(s)
I didn't see anything from the OP saying he was having problems with numbness which if that were the case might be attributed to the saddle. Given he's talking about ED and lack of libido I'd start by getting a good blood panel done so anything physical can be ruled out.
VFL For Life
Liked 1,858 Times
Quoted: 20810 Post(s)
Liked 9,456 Times
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,982 Times
There was a few years ago, a big flap about cycling and impotence - it was mostly discredited because they studied people who didn't really ride so they didn't know about bike fit and such, but most people just saw the headline and thought "of course"... probably true for a lot of doctors too. So while it's possible your problem is from cycling, it makes a lot sense to get a second opinion from a doctor who understands cycling.
No this isn't a medical site - so my advice is ride more!
Bikes: 2019 Supersix Evo, 2002 Trek 2000
Quoted: 273 Post(s)
Liked 45 Times
also, with regards to the knees, you might consider arnica ointment with belladona -- it can do wonders for localized pain like that.
If it works for you, maybe you can quit the aspirin and avoid the various side effects of that (as discussed above) and concentrate on your seat/bike fit.
If you brake you dont win
Bikes: Santa Cruz Bronson, Trek Remedy 9.8, Cervelo S3, Kona Big Honzo, Cannondale R500, DiamondBack Apex, one storage unit my wife knows nothing about, and one ball crushing unicycle for kicks
Quoted: 25 Post(s)
Liked 6 Times
I hear this every once in a while where I work.
A cut-out saddle and proper tilt can go a long way in waking up the snake.
Unless you are taking aspirin as heart therapy, only use it when really needed and not as some sort of routine.
I'm not a doctor but I work with and personally know several doctors. I really doubt a doctor would just say cycling and aspirin without suggesting any follow up tests or referring the patient to a specialist.
I'm not buying it...
Casually Deliberate
"Blood thinner" is a misnomer. They do not actually make you blood thinner (i.e., less viscous). They inhibit clotting mechanisms. I have been taking Warfarin since 1990 because I had a prosthetic heart valve installed. My blood isn't any "thinner" than the next person's.
