Frame cracks here!
Uruguay
Frame cracks here!
Made this post for us to post cracked frames we saw. The other day i was looking for a GT where we recycle bikes for people and that poor GT was ruined. Disc brakes and front suspension but two awful cracks.
Every day a winding road
There ws a good reason someone tossed it out. Not worth saving.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1237 Post(s)
Liked 324 Times
That chain is rusty, so it's been outside a while.
Plus that appears to be one of those gawd awful bikes with a TT so sloped it merges with the seat stay in an almost straight line. What a STUPID plan. The triangle has ZERO strength. Durability has NO relevance to these braindead companies.
And yet millions are mindlessly buying these garbage bikes.
Uruguay
Quoted: 3450 Post(s)
Liked 420 Times
Who knows. It may have been some teenager trying out a radical stunt in a skate park or urban setting. The frame may look bad but doesn't compare to the riders broken arm.
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 942 Times
Lots of (most?) BMX bikes have top tubes almost in line with the seat stays. Doesn't seem to be a weak design or they'd be cracking up all over the tracks.
Professional amateur
Bikes: Does a Big Wheel count ?
Quoted: 302 Post(s)
Liked 136 Times
Coincidentally (I assume), the only frame I ever had crack was also black GT mtn frame. The bike was near-new, and set up with road-friendly tires and used as a road bike, so it didn't see ANY rough use. Then one day, I find a crack at a weld.
I believe I got it from Cambria, who I contacted, but they left me high and dry, and I've been turned off to them ever since..
Old fart
Quoted: 3591 Post(s)
Liked 3,401 Times
Failure at the disk brake mount suggests that the stays were not sufficiently robust to handle the brake torque. Thicker tubing and/or gussets may have prevented this.
I doubt that the brake torque alone is sufficient to break a frame. More likely the bike has seen jumps and landings too harsh for it to handle.
Likes For subgrade:
Cycleway town
I've seen a 90's GT rear frame cracked around both rear brake mounts. 7005, thin wall.
The one in the picture is missing a vital brace link between the seat stay and chain stay. So fatigue was inevitably going into the metal on braking alone, without even seeing the frame design. The weld is stronger than the tube because it's thicker, the tube spreads the stress everywhere along it except where it meets the weld, so metal will almost always fatigue/crack at the edge of a weld, where flex meets rigidity.
Absolutely no surprise this frame has snapped there. One will have cracked first, the rider not detected it, then when the other cracked they both went completely.
Uruguay
The bike was donated a year ago maybe so some pieces may be used in another bike before i saw this bike. Is a GT Chucker. On tuesday i'll be parting out it.
RFC
Classic & Vintage
40
04-10-24 01:20 PM
mwalsh5757
Mountain Biking
5
05-10-17 09:39 AM
freebyrd1904
19
07-13-11 09:26 PM
