RD Question
RD Question
I’m rebuilding an 80s bike. The RD that came off shows wear. I have an identical nicer one in my stash with a sheared stop pin. I might try to remove the broken off stud and rob the stop pin from the worn one. I also have a Shimano 600 RD that could be the replacement. Any thoughts?
Would the derailleur work without that pin?
Thanks.
Thanks.
Mad bike riding scientist
Quoted: 6221 Post(s)
Liked 4,221 Times
The stop pin is needed to keep tension on the spring inside the A knuckle. Without it, the arm doesn’t return to keep tension on the chain. Look at your two derailers above. The arm has to be behind the parallelogram or it just won’t work.
Where the stop pin comes from probably doesn’t make any difference. If it fits in the threads and is long enough, it will work.
Stuart Black
Stuart Black
Quoted: 6196 Post(s)
Liked 4,811 Times
What's worn on the good DR?
Liked 4,221 Times
The stop pin (campy calls it a "grub screw) keeps the cage from unwinding when the wheel is removed. As long as the wheel and chain are mounted, the pin has no function; the chain keeps the tension.
But it's a kludge to use a rear derailleur without its stop pin. I'd use the best derailleur you have. In this case, it's probably the shimano 600.
Stuart Black
Stuart Black
Liked 4,221 Times
Here's a pic of one of my derailleurs. I've circled the grub screw (stop pin). It has zero function when mounted with chain and wheel/cogset. Without chain, cogset and grub screw, the cage would unwind all the way. Without chain but with the grub screw in place, the cage unwinds only to the grub screw, which makes mounting and dismounting the wheel far easier. That's its purpose.
Running a derailer without the stop screw would be inviting disaster on shifts to the lowest ring on a triple as well as wrapping the derailer around the axle if the chain should fall off or making a tangle of the chain if you should ever need to remove the wheel. It would be even worse with modern derailers that have much stronger springs than Sjtaylor is using.
I don’t care how many years you’ve been working on derailers (40+ for me), running a derailer without the stop screw is just inviting disaster and very bad advice.
Stuart Black
Stuart Black
Liked 4,221 Times
So you never make a mistake? Like saying that running a derailer without a stop screw isn’t going to be an issue?
Suntour is the next generation from the Campy and their springs are stronger than the Campy. The derailers in Sjtaylor’s post are a few generations along from the Suntour Vx and are even stronger. As mountain biking got going, they needed stronger springs to keep chain slap down.
Does Sjtaylor say that the chain is laced through the cage? From what I can see the derailer is off the bike so, without the stop screw, the derailer would have to be wound around and held while lacing the chain through. Kind of makes your point moot.
Again, never made a mistake?
But you did advise running the derailer without the stop screw. You said “As long as the wheel and chain are mounted, the pin has no function; the chain keeps the tension.” The wheel and chain aren’t always mounted. Drop a chain in a shift and the whole thing is going to be ripped off. You might be able to get away with riding if the stop screw fell off but anyone who is doing that is flirting with disaster.
They're no weaker than Suntour, although Suntour usually gives you more options for spring tension. Only one time did I run a derailleur without its grub screw; it was with a Suntour ARX.
If removing a wheel to fix a flat, for example, the chain will already be laced through the cage. All that will be needed is to pull back the cage when mounting the wheel.
But not as bad as not knowing how it works in the first place.
And I didn't advise it. You can read post 3 again if you're still confused. I did advise using the Shimano 600.
Stuart Black
Stuart Black
Half way there
Quoted: 987 Post(s)
Liked 880 Times
How does one of these pins shear anyway? I can't tell from the pic, but it looks like the pin hole elongated to the point that the pin couldn't be fixed in the threads. This could happen if the pin wasn't properly tightened.
All in all, the advice to not use it without the pin is absolutely right.
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
SurferRosa is absolutely correct. a stop screw is not needed when the freewheel and chain is in place.
It is only a nice feature for wheel changes. I remember Huret derailleurs without a stop screw. when
reinstalling the wheel you had to rotate the derailleur and then install the chain.
Liked 4,811 Times
I'm still wondering what was wrong with the DR that was called worn, but presumably had the pin or stop that is being hotly debated.
