Go Back  Bike Forums > Bike Forums > Winter Cycling
Mechanical Discs
Winter Cycling Don't let snow and ice discourage you this winter. The key element to year-round cycling is proper attire! Check out this winter cycling forum to chat with other ice bike fanatics.
Mechanical Discs
Old 07-28-23, 06:29 PM
Noonievut
Quoted: 286 Post(s)
Liked 262 Times in 129 Posts
Mechanical Discs
Anyone experienced problems braking in snowy conditions with mechanical disc brakes? I have a Salsa Fargo with TRP Spyre brakes and was thinking of putting some 2.6-3.0 studded tires for winter riding, but not sure how the brake (cables) will hold up if exposed to snow.
Noonievut is offline
Old 07-28-23, 06:49 PM
base2
I am potato.
base2's Avatar
Quoted: 1790 Post(s)
Liked 1,631 Times in 934 Posts
I've never experienced any braking issues with TRP Spyres, or indeed any braking system with temperatures down into the low teens. The only real potential issue I can think of would arise from water in the cable housing freezing and seizing up the cable inside.
base2 is offline
Old 07-28-23, 07:05 PM
Noonievut
Quoted: 286 Post(s)
That’s specifically what I was thinking about. I rented a fatbike last year and came across a guy with this issue with mechanical discs.
Old 07-29-23, 12:08 PM
wolfchild
Quoted: 4227 Post(s)
Liked 2,488 Times in 1,286 Posts
I've been using Avid BB7s on two of my bikes for the past 16 years. Cables can get a little tight if moisture gets in and starts to freeze but I never actually lost braking power. I keep the cables well lubed make it a habit to just squeeze brake levers regularly to keep them loose. The brake calipers itself should be rinsed with clean water after the winter season to get all the road salt out or else they can start to seize up and get very tight. Other than that I love mechanical brakes, simple and easy to set up and maintain. Never have to worry about brake bleeding or replacing leaking piston seals like I had to do on my shimano hydraulic brakes.
wolfchild is offline
Old 07-30-23, 11:13 PM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6221 Post(s)
Liked 4,221 Times in 2,367 Posts
Getting water into the cable housing is far more difficult than it sounds. It can happen as evidenced by corroded cables but it’s not highly likely. Even with corroded cables, the water is probably following some salt that gets past the ferrules and, being hygroscopic, the salt actually pulls small amounts of water out of the air. Flooding of enough water to freeze the cables is not all that likely.
I’ve used cable brakes of many different flavors…cantilever, linear, and disc…over more than 40 years of commuting and never had a brake of any kind freeze. Mechanical discs aren’t any more (or less) delicate than those other brakes.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 08-07-23, 12:25 PM
rumrunn6
rumrunn6's Avatar
Quoted: 5224 Post(s)
Liked 3,585 Times in 2,344 Posts
you'll be fine
only winter cable issue I ever came across, was the rear derailer, on my commuter. I made the mistake of using a little water to clean the bike, after getting home, then left it outside overnight. by the next morning I couldn't shift. only discovered it, 1/2 mile from home, in the dark. PITA to disassemble it, clean out that little housing loop & put it all back together, roadside, in the dark, in very cold temps
rumrunn6 is offline
Old 10-09-23, 03:18 PM
MinnMan
MinnMan's Avatar
Bikes: 2022 Salsa Beargrease Carbon Deore 11, 2020 Salsa Warbird GRX 600, 2020 Canyon Ultimate CF SLX disc 9.0 Di2, 2020 Catrike Eola, 2016 Masi cxgr, 2011, Felt F3 Ltd, 2010 Trek 2.1, 2009 KHS Flite 220
Quoted: 4393 Post(s)
Liked 3,017 Times in 1,866 Posts
I think it depends on the cable routing on your particular bike.
I have used my Masi for winter riding, with mechanical disks (Avid BB7s). I never had a problem with the cables freezing. BUT, the derailleur cables for the same bike are routed, bare, directly under the bottom bracket. So there have been quite a few times when I lost shifting owing to ice buildup on those cables.
MinnMan is offline
