Can I adjust my Look pedals....
Bikes: Felt AR1, Cervelo S2
Quoted: 17 Post(s)
...to somehow reduce the amount of time I spend flat on my face?
specifically is there a trick to get them to automatically rotate right side up?
I got the look classic pedals as my first clipless...I'm trying them out on rollers. I keep falling because the pedals are upside down and I can't get my second foot in. the bottom of my shoe, being slick and hard, prevents me from feeling the pedal to flip it.
other than the whole falling thing they feel good.
practice makes perfect. it is really tricky at first and you will get the hang of it after awhile.
i use the toe of my shoe to make sure the pedal is facing the right way, then i use the front lip of the cleat to push up under the front groove of the pedal, once that tip is under that lip/ groove, then all you have to do is press hard on the pedal and the back clips in
Bikes: '09 BMC roadracer, CAAD3, CAAD4,'88 Steel Custom, F moser track bike
Just like WR3K said. The cleat will wear a little bit as it's used, this will also make clipping in and out easier. But mostly just practice and getting a feel for it. Good luck.
Jon
Jon
No matches
Bikes: two wheeled ones
Quoted: 1398 Post(s)
Liked 444 Times
Why did you think learning to use a new clipless pedal on rollers would be a good idea? That's probably the worst possible place to practice.
Quoted: 140 Post(s)
Liked 163 Times
Very bad idea. Terrible idea. Good way to insure you will spend a lot of time flat on your face. Why would you try clipless for the first time on rollers? I can't believe you're even attempting that. Horrible idea.
Quoted: 17 Post(s)
you're absolutely right. I know this would be easier if I could coast. but it's been brutally cold here in NYC the past few days.
ka maté ka maté ka ora
Bikes: breezer venturi - red novo bosberg - red, pedal force cg1 - red, neuvation f-100 - da, devinci phantom - xt, miele piste - miche/campy, bianchi reparto corse sbx, concorde squadra tsx - da, miele team issue sl - ultegra
Quoted: 25 Post(s)
here's your roller tip. put them in a doorway. lean on the doorway until you are clipped in. start pedaling before you let go of the door jambs.
Despite all my rage, I am
Bikes: LeMond Zurich, Colnago C-50
Bikes: Colnago Master XL, Bianchi Via Nirone 7, Marinoni Fango
Bikes: Custom Custom Custom
Rollers in the door jam. I'm pretty good at the rollers, even being able to ride no handed, but I still set my rollers in the door jam. Get both feet clipped in then start pedaling. I love watching those videos of roller newbs just trying to ride rollers in the middle of the room with no support
Quoted: 17 Post(s)
Bikes: Scott CR 1
Has anyone tried an adhesive weight added to the pedals to change their weight distribution so they would be in a different position?
imho the "Weighted for easiest engagement" reasoning is false. When the cranks rotate, the pedals flop around making the rider wait for them to settle down and then engage. Kinda fanatical about quick&predictable engagement being a commuter/rider who stops at signs and lights more than is typical. Racing doesn't really matter for engagement too much.
Also they only have back-to-front engagement. Speedplays are back-to-front or front-to-back.
claudred
Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs
4
09-17-17 08:20 PM
JustinNY
Road Cycling
11
04-26-12 09:10 AM
