Derailleur limit screws should just be Left and Right
For something so simple, I've had to Google it every time I adjust a derailleur. Is L the low gear? What does low mean here? Low as in low tooth count or low as in lower effort? Is H high gear? High tooth count?
And generally is the L screw on the left or the right? Which screw am I turning? Sometimes the light isn't great so I have to turn the light on my phone and peer in really close at the indentations which are the same black color as the rest of the derailleur.
Crikes.
Crikes.
Likes For adlai:
Pennylane Splitter
Bikes: Yes
Quoted: 1810 Post(s)
Liked 1,450 Times
I can't remember either. I just figure it out by moving the shifter lever (I don't have brifters) and see what moves, then adjust the proper screw to put the RD over the proper gear on the cassette. Not something to worry about.
Quoted: 3518 Post(s)
Liked 2,932 Times
L= low gear. The gear you use to start the bike. The easiest gear. Biggest gear in back, smallest in front.
H=high gear. The gear you use to make the bike go as fast as possible. The hardest gear. Smallest gear in back, largest in front.
Likes For smd4:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12799 Post(s)
Liked 7,717 Times
L is the cog/ring closest to the frame
H is the cog/ring furthest from the frame
Works on both derailleurs.
Sorry I don't have a mnemonic device for it.
Likes For LesterOfPuppets:
Quoted: 1463 Post(s)
Liked 1,487 Times
Left and Right would make a lot more sense to me as well.
On cars, using "low and high" to describe gears makes more sense, because they're numbered from low to high. The smaller the number the lower the gear. No one knows or cares how many teeth the cogs have, and no one can see the physical size of the gears.
There's no such numbering on a bike - and in fact people usually refer to gearing by the number of cogs so an 11t gear is a lower number and physically smaller than a 12t gear, but the 11t is the "bigger" or "taller" gear. People use the phrase "pushing a big gear" all the time to mean using the smallest physical size of gear on the cassette. It breaks my brain...
aged to perfection
Quoted: 840 Post(s)
Liked 1,270 Times
"Low" is left
"High" is right
Again applies for both front and rear detailleurs
but a close look at the mechanism should tell you
/markp
"High" is right
/markp
Likes For mpetry912:
Quoted: 1104 Post(s)
Liked 1,825 Times
So then derailleurs should be right normal for the rear and the front should be left normal? If you're gonna visit, learn the language and customs.
Likes For nomadmax:
LR÷P=HR
Quoted: 868 Post(s)
Liked 1,205 Times
“L” is for LOUD, the noise made by the chain hitting the spokes
”H” is for the HARM the chain will do to your frame
Barry
Barry
Likes For Barry2:
Liked 2,989 Times
L = Lazy
H = Hurting
H = Hurting
-Oh Hey!
-Oh Hey!
Likes For Troul:
Mad bike riding scientist
Quoted: 6222 Post(s)
Liked 4,224 Times
Crikes.
Crikes.
Stuart Black
Stuart Black
Quoted: 2607 Post(s)
Liked 1,944 Times
I'd be happy if I could just find the "L" and "H" on half my derailers.
Likes For pdlamb:
Liked 4,224 Times
Well, there is that too. And Shimano can be a bit loosey goosey about which screw on the front derailer is low and which is high. They switch them often on different models.
Stuart Black
Stuart Black
Quoted: 427 Post(s)
Liked 700 Times
Had to go out in the garage to see if my derailleurs were marked L or H. If they are, I couldn't see it. Are all derailleurs marked?
Bikes: yes, i have one
Quoted: 1144 Post(s)
Liked 1,187 Times
no. not on my old Sora, only the RD was labeled, FD not. upgraded to Tiagra and same deal. on my new ride with ultegra Di2 they aren't labeled either.
Quoted: 6216 Post(s)
Liked 4,826 Times
Limit screws should only need to be adjusted at time of installation. If you are adjusting them after the install, and there hasn't been any physical damage to the bike and drivetrain, then you are doing something wrong. They aren't for adjusting indexing issues or other common problems with gear shifting.
Likes For Iride01:
Quoted: 545 Post(s)
Liked 417 Times
Crikes.
Crikes.
Lighting problems are easily solved. Get a brighter lamp. Work outdoors in the daytime.
Liked 2,932 Times
Bikes: everywhere
Liked 7,717 Times
Same with my olde Sora FD. Luckily it's really easy to see the stop on those, with a quick glance I can see that the outside screw works on the outside chainring.
Quoted: 2984 Post(s)
Liked 1,189 Times
If you don't which is which (it's not that difficult) then maybe you are candidate for bringing your bike to the bike shop to be worked on.
Likes For prj71:
Quoted: 4812 Post(s)
Liked 3,940 Times
Granted that was long before indexing, shaped teeth, etc. Still, the blanket statement that limit screws should never be touched after installation - well maybe for modern index systems but with friction shifted systems, both limit screws affect how quickly and easily you can get to the extreme cogs. Especially before ramped teeth. Low gear may be taking the RD cage quite close to the spokes. I've had more than a few bikes where I've juggled the ease of shifting with the sound of the idler pulley nut brushing the spokes. (Yes, I've mixed and matched Italian hubs and Japanese FWs where the low cog can get quite close to the hub. And yes, the hangers were straight.)
Quoted: 7653 Post(s)
Liked 3,488 Times
"Left" and "right"/ Wait left and right on the bike? From the front or the back? On my 105 the screws are vertical .... so which way do I lay the bike down?
I have seen that in the back "L" is almost always closest to the derailleur body and "H" farther away in the back. I sometimes forget ... so I pop off the headlight and check before I do harm. But .... "L" is always closer the hub, even if vertical .... and "H" is always farther ... which is sort of the way the derailleur swings. Still ... I check periodically. No desire to put the derailleur into the spokes.
Up front I have never seen "H" not be on the outside, which is the way the derailleur swings.
Also ... if you are making small adjustments, you should be able to actually See the effect of your adjustment before you break something. If you are turning one screw and the derailleur's range of motion isn't limited, turn the other screw.
Sorry, but your "left" and "right" seems a lot less universal than ""L" for Low gear (and we all know what low gear is, if we actually ride bikes) and "H" for High gear.
With a mighty wind
Quoted: 1091 Post(s)
Liked 880 Times
I can’t remember the last time I looked at the letters. Just eyeball whether the screw is physically touching the stop or is pretty close. The rest can be sorted out from there.
Liked 4,224 Times
That’s possible on some derailers, especially old ones or cheaper new ones but many derailers don’t really let you see the stops.
Stuart Black
Stuart Black
