Full fenders with rim brakes and road calipers
Quoted: 1465 Post(s)
Liked 1,491 Times
I have a newly acquired rim brake bike with regular road style brake calipers. It currently has 25mm tires installed, with around 10mm of clearance between a 25mm tire and the brake caliper, and about 5mm of clearance between the tires and rear seat stays on each side. The front tire has more clearance than the rear. I'd love to bump up to 28mm tires on this bike, which would squeeze that rear seat stay clearance down to around 3mm on each side and maybe drop the brake caliper clearance down to around 8mm. I haven't tried this yet, but assuming it'll fit based on my observed clearances.
I am wondering if/how I could attach full-length fenders (mud guards for the non-USA crowd) to this bike? My bike has eyelets for mounting, and I've installed full fenders on disc brake frames before and understand how they attach, but I'm not sure how full-length fenders work with rim brakes. Do the fenders slide between the caliper and tire? Any idea how much room these take up and how that would affect available clearance for tires?
I've tried googling this, but most photos online show bikes with touring style cantilever brakes, or v-brakes. I can't find any good photos of full fenders on traditional road caliper rim brake bikes and am wondering if anyone has examples or suggestions on how this works.
Thanks.
Thanks.
Quoted: 816 Post(s)
Liked 1,037 Times
Yes, older bikes tend to fit fenders better than newer bikes/frames.
Many newer frames leave little room for fenders/mudgaurds. It is on a bike or frame by frame basis. I had a Trek 1000 that I liked however, the clerances were so tight that wouldn't fit wider tires let alone tires and fenders. If it is a "racy" geometry it could be that it won't fit.
These are Plantet Bike Cascadia feners. They can made to have a pretty tight fender line. I showed a picture of this bike becuse of the tight fender to tire clearance I was able to achive. But of couse that comes with it's own perils. Sticks can get caught. My bike stays cleaner with fenders though.
Likes For Velo Mule:
Expired Member
Quoted: 3752 Post(s)
Liked 5,674 Times
I ran full fenders on a Gunnar Sport with 28mm tires. 32mm+ would fit w/o fenders. But the calipers were longer reach than your normal short reach road. The fenders take up quite a bit of space, both height and width. And yes, they have to go between the calipers and tire. I don't think there is any possibility of full fenders and 25mm tires on the bike as described.
Quoted: 4546 Post(s)
Liked 1,693 Times
Regular fenders - no. There are specialty fenders designed for short reach road bike brakes
Quoted: 4852 Post(s)
Liked 3,990 Times
It isn't hard to cut the fenders and simply install River City Bicycles' Reacharound Fender Brackets. ($15) I'm guessing most modern bikes will also need Sheldon Fender Nuts. ($15.99) This will give you a fender that is simply deleted at the fork crown and brake bridge and now extends a touch farther forward and back (both a plus if you and those behind you staying dry and clean is important). It sounds like that would leave those areas of the bike a mess but it doesn't. Seems that muddy water is traveling fast enough that most just shoots forward to where it would go anyway.
Portland, River City's home, has enough of those Reacharounds out there that they area completely proven product.
https://www.rivercitybicycles.com/pr...ckets-4486.htm
https://problemsolversbike.com/produ...on-fender-nuts
Liked 1,491 Times
I just installed 28mm tires to see how they would fit. Turns out they fit great, but it seems like my expectations for 28s + full fenders may not be realistic. I don't think I'm willing to ride 25mm just to fit fenders, so I'll have to look into some other options - maybe a clip-on type of design that avoids the brake areas and provides some-but-not-full coverage.
Liked 1,491 Times
https://www.rei.com/product/102249/s...ong-fender-set
These look like a solid option. I think I'll swing by my LBS to see if they sell anything similar or have other suggestions.
Thread Killer
Quoted: 3200 Post(s)
Liked 1,739 Times
Based on the provided info, it’s impossible to answer anthing with certainty here other than the basic question of where the fenders go, which is, yes, between the tire and the brake calipers. Other than that, the clearances do sound tight, but I’d bet there’s a full coverage (or nearly full; depends on definitions) fender that would work.
Personally, I’m a big fan of the Crud RoadRacer Mk3 guards, both because they’re simple and light, but also because they’re easily removed/installed. I’ve been running them for nearly 9 years, I think, and the preceeding model for years before that. They’re among the slimmest fitting fenders out there, so if anything is going to fit, I’d wager it’s RR Mk3s.
Crud RoadRacer Mk3 on Kinesis Racelight 4S with Panaracer GravelKing 28 slicks
Likes For chaadster:
Liked 3,990 Times
Is this basically the same design?
Liked 1,491 Times
Just ordered a set - thanks.
Thread Killer
Liked 1,739 Times
Post a pic once you’ve got ‘em on!
It's carbon dontcha know.
I was going to suggest the Crud Roadracers, but I see we've worked out that solution already
Quoted: 444 Post(s)
Liked 476 Times
+1 for Crud but mine are the older version. Not very quick to install/remove. But yeah, 25mm with fenders, 27mm tires without - that was my compromise.
Thread Killer
Liked 1,739 Times
Wow, you’ve still got the “long tail” option for the rear! I kept ripping mine off every time I popped the bike up on the rear wheel to walk it in somewhere. I’ve since decided that I don’t care, because something is better than nothing, and absolutely nothing is the level of consideration most of my clubmates give to fender courtesy.
Quoted: 444 Post(s)
Liked 476 Times
chaadster yes I absolutely hate how the rear tail drags when I'm wheeling it vertically through my cars in the garage! Both the rear and front tails have come off at least once - I'm on my last set of spare tails and nylon nuts. I'm assuming they've fixed the design with the newer versions. Functionally it won't matter much but it triggers the OCD in me when I lose a tail or screw. I will say I enjoy the bike much more with the fenders gone, but they've gotten me thru this past winter pretty well.
Thread Killer
Liked 1,739 Times
*I may have a used set of Mk2's with all parts still included sitting on my parts shelf if anyone has an interest for the cost of postage in the US.
Likes For 6thElement:
Fredly Fredster
I added some Fenders to my backup bike.... a 2013 Trek 1.1. Cool to see bikes with fenders.........
