Height Lost Over Aging
I was wondering if any of you old timers have any experience losing height over time or not fitting your favourite frame? The reason I ask is because I have a wonderful touring bike one size larger than what I would normally ride, but it's still great and comfortable. I'm early 20s, 5'10, and the bike is a 60cm with a 58 top tube from seat tube to head tube.
I haven't had any issues with sizing or fit. Normally I would ride a 57-58cm frame.
Anywho, I have this fear that at some point the frame might not fit me anymore, which would then lead me to having to trade the frame with a fellow C&V member for the desired 57cm.
Have any of you experienced not fitting on a frame as you age?
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3870 Post(s)
Liked 6,461 Times
I have lost some height (half inch or so) without having to adjust the bike as a result. I wouldn't worry about it. Especially at your age.
I.C.
I.C.
Likes For aland2:
Quoted: 4792 Post(s)
Liked 3,918 Times
I've lost most of an inch, all torso (I'm soon to be 67). Yes my reach has gotten longer. I always rode really long stems so now they are just not quite so long or set a cm higher. Not a big deal. (All but one of my bikes qualifies as C&V with quill stems, so raising the stem is so easy! The one threadless is 1" steel steerer so when the time comes, I'll just have it threaded and drop in a sweet Nitto Pearl.
Ben
Ben
ambulatory senior
Quoted: 1954 Post(s)
Liked 3,658 Times
since it is a touring bike I wouldnt worry. At 63 I dont bend that well but I do like a larger frame. Just shorten and raise the stem as needed. If things get really awful like they have for my neck you can put upright or even north road bars on your touring bike. I know I do.
Likes For 52telecaster:
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
While I agree with @SurferRosa that you are too young to worry about this, I will add that while I can easily ride a 58cm frame, I am more comfortable on a 56. Most of your "shrinking" with age happens in the vertebrae. The spine compresses and becomes less flexible. At that point its not so much the seat-tube height as it is the top-tube length, which has everything to do with your diminishing reach. Shorter stems and bars with rise and setback will help. Take up yoga and stretching now, and you'll never have to worry about it!
Likes For J.Higgins:
Old fart
Quoted: 3583 Post(s)
Liked 3,395 Times
Height loss with age is a result of loss of inter-vertebral space in the spinal column and kyphosis. Leg length doesn't change, so standover height will stay the same. A shorter torso can be accommodated by using a shorter reach stem.
Likes For JohnDThompson:
Not lost wanderer.
Quoted: 885 Post(s)
Liked 987 Times
I was 5'9" at my height in my 20s, 30s and into my 40s but have lost 3/4" over the past 20 years now I am 63. and just over 5'8".
Freewheel Medic
Quoted: 1452 Post(s)
Liked 2,186 Times
YMMV
Every person looses height with age at different rates and for many different reasons. Your best predictor might be to see what other men or women have experienced in your same genetic family.
Bob
Bob
Quoted: 3804 Post(s)
Liked 6,643 Times
Shrinkage happens. Just stay out of the pool.
Likes For nlerner:
Veteran, Pacifist
Quoted: 3897 Post(s)
Liked 4,829 Times
I have a range of sizes. 58 - 62cm. Cover all bases.
At age 69, I ride them all.
If I've shrunk, it's less than 1/4" on my 73" frame
Don't sweat the small stuff, just ride.
Quoted: 567 Post(s)
Liked 563 Times
People typically lose almost one-half inch every 10 years after age 40. Height loss is even more rapid after age 70 as I can attest. As JD Thompson said shorter stem, compact bars, etc. are your friends.
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Bikes: Still have a few left!
Quoted: 466 Post(s)
Liked 529 Times
Like ^^ they all said, vertebral shrinkage is from the waist up. We all have some. A larger problem for me (at 79 yrs) is curvature of the upper spine. "Old man stoop" caused most of my height and reach loss. So far adjusting or replacement of stem solved the problem. I also went with upright bars on a few I use for gravel and off road. Don
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
At 60, I'm fortunate to have not lost height so far. However, I am not as flexible as I was in my youth, and I do expect that a little bit of height loss could occur as I age further. There are lots of factors for both losing height and flexibility. Staying active, stretching, eating sensibly... three things you have some control over that will hopefully reduce the effects. Genetics is (for the time being at least) beyond our control. Not a bad thing to be aware of, but in and of itself, it's only one one factor. Changing equipment always remains a remedy, but considering it your first resort could set you on a path of compromise and is likely to shorten your riding days.
Stretching, yoga, being upright if it does happen, and the ineveitable. Gotcha
It's good to ask these questions because at some point it will happen to me, I like to know how you guys manage, and what strategies I may pursue to reduce strain on my body. I'll have to enjoy my back for the tike being 😁
Thanks fellas!
Thanks fellas!
Enjoy your bike! Live your life and don't sweat the small stuff! You will have so many things in your life to worry about in the FUTURE!
Sorry I'm sure this is important to you, I'ver just always worried a bit more then I should and it really does nothing good for you!
Quoted: 7346 Post(s)
Liked 2,453 Times
It may be extraneous thinking, as others have pointed out, but maybe it's a good sign that you can plan for more important things. If you haven't started saving for retirement yet, start now. Compounded interest is most powerful when you start early. Save at least 5% of your take-home if you can, and later, you can build a habit of saving even more.
Liked 2,446 Times
Back to the issue of health and flexibility, one of my plans for aging is a suitable ride for my older self. I have a 23" men's Raleigh Sports and I expect that one day I will not be able to swing a leg over that diamond frame in order to ride, so I got a 23" ladies' bike that is waiting in the wings for just such a time.
I may also get a mixte frame for the same needs in a road bike.
Likes For thumpism:
Bikes: ‘84 Alan sprint, Rocky Mountain Altitude 799, Trek fuel ex 9.9, Gardin/Battaglin’84, Nishiki international ‘83, ‘86 panasonic dx5000, 93 mongoose amplifier
Quoted: 14 Post(s)
Liked 30 Times
I was 5-10” in my twenties and rode a bike that was at the top of my limit for size. At 64 and barely 5-9” this bike is no longer comfortable to ride.
shrinkage happens.
B
shrinkage happens.
B
Quoted: 500 Post(s)
Liked 466 Times
I lost about 1-1/2” in height during my 50’s (70 YO now). Thankfully the ‘79 Miyata 912 purchased new back then still fits, albeit with a taller and shorter reach stem. Notably, I’m very long-legged for my now 72” height, and that 912 is a 25”/62cm frame. So if there’d been leg length loss, I certainly would have noticed.
The other surprising physical change was my shoe size, or at least fit, changing rather suddenly at age 65. I’d been very happy with the same pair of Sidi Dominators for 14 years, with of Shoe Goo and other methods over the years to rebuild worn soles. Riding over those years included several multi-week tours and plenty of long (50+ mile) rides. Then when training for the 2015 200-mile Seattle-to-Portland (2 days for me) ride, my feet decided to become quite painful on anything longer than 40 miles. Apparently my feet, already more squarish than many, spread out below the metatarsal area, necessitating a wider and longer toe box.
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,696 Times
Commence to jigglin’ huh?!?!
Quoted: 350 Post(s)
Liked 276 Times
My BMI has been creeping upwards the past few years. Unknowingly I attributed it to weight gain. Glad to know it's just old age height loss..
Now I can return those new, larger waist pants and go back to wearing the old tight ones..
Likes For tyler_fred:
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
I hate to argue with my elders, lol, but leg length “can” change, with certain medical procedures. 😉 When I was younger, I wore 33x36 in Levi’s. Now, at 58, a 35x34 fits about right. My brain is dead right now, but that procedure is a Major (something in your knee) Reconstruction, which shortens one leg a smidge. 🙂
