Fixie for lefties
Fixie for lefties
A couple of things I've always wanted to experiment with but didn't have the time........a left hand drive and an elliptical chainring on fixed gear. The Super Le Tour was abandoned at a local college. No wheels or cables and the wear from winter weather. I was able to utilize the headset, stem, bars, brakes and seatpost. The rest was found in my basement.
Be where your feet are.......Lisa Bluder
Likes For r0ckh0und:
Quoted: 4722 Post(s)
Liked 3,036 Times
The pedals are a concern for left hand drive fixies. Pedals will want to self-extract, unless you use some sort of thread locking compound. Polarized pedals, with a definite front and back, such as some clipless models, can't be used. Even on quill pedals, the toe clip mounting holes and flip tab will be on the wrong side.
Likes For T-Mar:
Realizing that it's not an ideal scenario.........I did snug the pedal threads, set the chain tension with the rotation of the elliptical in mind. I did orient the chainring the same as it would be on the normal drive side. Conditions on the fixed cog and lock ring are probably not ideal either. It does have a little slop in the drive train. Cartridge BB should not be an issue. I can assure you, it will not be ridden very aggressively by me. We have a quarter mile paved loop at our Quarantine Compound for test rides and such experimentation.
Quoted: 2337 Post(s)
Liked 2,819 Times
curious: why other than to see if it can be done?
Just for fun. The LHD and fixed elliptical are a couple of things I remember reading about some years ago on Sheldon Browns page and just wanted to try for the fun of it.
Bikes: 82 Trek 710, 90 Trek 750, 86 Vitus, Nishiki Cervino, 1989 Bianchi CdI, 2 Nashbars, an Italian Steel MTB, Sears Spaceliner, and a 74 Schwinn Speedster. I also manage a fleet of Volcanic Patrol bikes, 83 of them.
Quoted: 109 Post(s)
Liked 234 Times
I knew a guy that did that years ago. I think he used the crank set up for a tandem's stroker.
Likes For Jmpierce:
Veteran, Pacifist
Quoted: 3898 Post(s)
Liked 4,830 Times
I believe the track bikes for some USA Olympic teams (at least in ‘16) were lefty. Had to do with aerodynamics in the track.
Mel Pino had a track bike at the Nationals, mid 70s, with left drive crank. Had to do with COG and centripetal force, and angular momentum. Not that I understand that stuff. Was supposed to be faster. In the end, you need a rider who is up to the task.
Quoted: 7348 Post(s)
Liked 2,461 Times
Now you need some mirror-image decals.
Likes For noglider:
feros ferio
Quoted: 1392 Post(s)
Liked 1,324 Times
The benefit of LH drive with RH threading is that your cog won't unscrew during hard deceleration, leaving you with braking, although you fortunately do have a separate front wheel braking system. Some people use questionable judgment and ride brakeless track bikes on the street, in traffic, or around college campuses.
Quoted: 2363 Post(s)
Liked 1,749 Times
Not sure what a stroker is, but a tandem stoker crank would have a timing chainring on the left side, and one or more drive chainrings on the right side. That would look silly. You'd want a tandem pilot crankset, and just use a larger chainring than a typical timing ring.
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,103 Times
Going to add a Lefty “fork”?
Genesis 49:16-17
Genesis 49:16-17
Quoted: 3464 Post(s)
Liked 2,828 Times
Q
Quoted: 887 Post(s)
Liked 335 Times
As an old Commie, I fully endorse left hand drive.
Likes For dweenk:
Liked 2,828 Times
plenty of ways to set up a tandem.
Liked 1,749 Times
That's what I said (well, wrote). The pilot crank has the timing chainring only, and usually on the left. That's what would work for the OP, NOT a stoker crankset.
Liked 2,461 Times
Is it really necessary for the threads to resist precession? Can't you compensate with extra tightening? That's what we do with right-threaded fixed cups.
Extraordinary Magnitude
Quoted: 2607 Post(s)
Liked 1,699 Times
could be a winner boy, you move quite well...
Commence to jigglin’ huh?!?!
Quoted: 3357 Post(s)
Liked 3,636 Times
But lo and behold, it's there, and not satirical!
Liked 1,749 Times
Quoted: 1627 Post(s)
Liked 630 Times
I had a lefty, once. I liked to think of it as the Worlds Ugliest Fixie (and that's saying something!) Mid-70s Univega Viva Sport with faded and peeling-off woodgrain vinyl shelf paper wrapped around the tubes, handlebars and seatpost, saddle slathered with about an inch thickness of black duct tape, dried out knobby tires, and enough thread lock to keep the pedals in place. I think I remember the guy I bought it from ($50) telling me to keep an eye on the pedals if I was actually going to ride it.
After I put together a proper fixie in my size, I built the old one up as a decent commuter bike for my sister, replacing her badly bent Motobecane.
Quoted: 830 Post(s)
Liked 2,123 Times
This build deserves a right-handed front brake.
The things COVID hath wrought!
Not lost wanderer.
Quoted: 885 Post(s)
Liked 989 Times
This is such a stupid thing I want one so badly.
Liked 2,461 Times
I have an advisor at college who is severely dyslexic. On his office wall is a backwards clock, so I asked him about it. He said he actually doesn't notice it. Left and right mean virtually nothing to him. Amazing to me.
Likes For gearbasher:
