Swapping rims the lazy way
Likes For sloar:
Quoted: 809 Post(s)
Liked 1,022 Times
That works. Nothing wrong with that. I think this is similar to how Seth from "Seth's Bike Hacks" did it. I have loosened all the spokes, taped the two rims together and then moved the spokes to the new rim one at a time.
It looks good. Did you true the wheel yet?
Likes For Velo Mule:
Quoted: 834 Post(s)
Liked 2,125 Times
Another method is to de-tension the spokes on the original wheel, fix the new rim to the old rim (masking tape, zip tie) side to side, and then transfer one spoke over at a time to the new rim. Edit: Velo Mule beat me to it while I was typing.
Likes For gaucho777:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,481 Times
Neat idea.
Quoted: 2588 Post(s)
Liked 4,824 Times
I just bookmarked my first Bike Forums page; what a fantastic idea!
DD
DD
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,024 Times
I tape the spokes near the hub on both sides--same idea as zip ties but to me it holds things in the correct place more easily. Whichever way, I don't consider it cheating and guess what? I'm going to be doing it again in about a week! Did it at least once several years ago and it worked well. As much as building wheels up from zero is neat, swapping rims is much preferred.
Yep this works well. I'm somewhat surprised some people hadn't heard of this. It was pretty much SOP for replacing a rim if the wheel still had relatively new spokes. Like if you just hit a curb and cracked the rim on a wheel that was built fairly recently. I've always done it with tape, cuz that's how I learned it. Zip ties weren't something that used to be around, at least not in large quantities.
señor miembro
Liked 6,481 Times
Likes For SurferRosa:
Edumacator
Quoted: 2439 Post(s)
Liked 3,122 Times
This may have just moved me closer to building my first rim...still panicked about dishing and calculating needed dish.
Might be less stressful to me than gluing my first set of tubulars...
Likes For jdawginsc:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Likes For ThermionicScott:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4679 Post(s)
Liked 5,797 Times
Likes For gugie:
Quoted: 964 Post(s)
Liked 1,451 Times
Yeah fond memories. I learned the tape thing when I was 14, my dad did it on tour after I cracked my first Mavic MA3 in France. Little did I know at that juncture, I'd be cracking another two MA3s and replacing them myself before the 6-month tour was over!
When I laced my first wheel I messed up where I put the valve hole, so you couldn't get a pump in there, so I taped the spokes themselves together and undid everything and moved the rim a few spokes over. I still have that wheel.
Likes For scarlson:
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
If you're replacing the same size rim this is the best and quickest way.
Sugar "Kane" Kowalczyk
Likes For Bianchigirll:
Groupetto Dragon-Ass
Quoted: 414 Post(s)
Liked 783 Times
Another benefit of the tape-them-together style is that it's almost impossible to misalign the tire stem hole or have the graphics facing the wrong direction.
Likes For Chuckk:
Bikes: Numerous
Quoted: 1677 Post(s)
Liked 3,097 Times
Taping is sensible and efficient but you miss out on the "Zen of Lacing"
Liked 5,797 Times
At my age I don't need any more character building experiences, I'm looking for shortcuts.
Likes For gugie:
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
If your spoke lengths are correct, dishing mostly takes care of itself
Quoted: 2363 Post(s)
Liked 1,749 Times
Rather than zip ties, I usu tape the spokes at the third cross.
jdawginsc , centering the rim isn't a big deal. I use a centering gauge I bought decades ago, but RJ has a simple trick using two stacks of books (or whatever). You set the wheel on one side of the rim on the two stacks, then slide some spacer (another book, for example) under the axle in between. Get a sense of the distance from the axle to the spacer, then flip the wheel over. If there's a difference, loosen one side and tighten the other to compensate. Lather rinse repeat. At that point, it becomes a three-way dance between lateral true, radial true and centering. RJ's video will explain it better than anything written.
Quoted: 2482 Post(s)
Liked 2,953 Times
I might have used tape once, back in the '60s, but since then I never bothered with tape, having figured out that it's unnecessary. Loosen (but do not disconnect) all the spokes in the old rim, and then, starting at the valve hole, move over the spokes on the side facing the new rim and then the spokes on the other side.
Liked 2,953 Times
Centering the rim isn't a big deal. I use a centering gauge I bought decades ago, but RJ has a simple trick using two stacks of books (or whatever). You set the wheel on one side of the rim on the two stacks, then slide some spacer (another book, for example) under the axle in between. Get a sense of the distance from the axle to the spacer, then flip the wheel over. If there's a difference, loosen one side and tighten the other to compensate. Lather rinse repeat. At that point, it becomes a three-way dance between lateral true, radial true and centering. RJ's video will explain it better than anything written.
Edumacator
Liked 3,122 Times
I might try my hand at in the nearish future.
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times
Dunno - I've done it both ways, and I think I prefer taking the spokes out and starting fresh. You can replace stripped nipples, swap out bad spokes, adjust crossing patterns for better tension, etc. The disadvantage is that the rear wheel has to settle in again after dishing and truing.
Helps if you have a truing stand and a dishing tool, though.
The tape and swap over thing was, like I said, for relatively new wheels that got damaged, or for when you just wanted a different rim for some reason (assuming it used the same spoke lengths).
I realize this goes against the advice in "The Bicycle Wheel", but while I understand the logic of that argument, I don't really agree, at least I didn't BITD. Nowadays it holds more true. Spokes are better and less likely to break, especially if you spring for DB. I"m on my second rim with the same spokes on my main road wheels.
