Friction shifters with 7 or 8 speed cassette?
I came into a decent wheelset with an 8 speed cassette, and am considering using it on a vintage frame. BUT, I don't want to get into indexed shifting. Will friction shifting work with an 8 speed cassette? Would replacing it with a 7 speed cassette help, and would any particular type of rear derailleur work better with a set up like this?
Am comfortable with spreading the frame, but just don't want to invest in the rest of an indexed drive train at this point. If it all works out I might upgrade it to a "retro roadie" in the future https://www.bikeforums.net/classic-v...ergos-311.html
Quoted: 455 Post(s)
Liked 112 Times
I would think it would work fine. I run a 9 speed and use barcon friction. Love them!!
Likes For Tandem Tom:
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Works fine, almost any derailleur will do the job. Details on component mix would help, though.
Likes For rccardr:
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 532 Post(s)
Liked 1,005 Times
As long as the derailleur has enough travel to span all the cogs, it's not hard to friction shift 8 speeds. I have seen an older derailleur that wouldn't shift to the largest cog because it did not have enough travel, even with the low limit screw backed all the way out. The derailleur was meant for a 5 speed freewheel, which is several mm narrower.
Likes For Pompiere:
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
In principle, friction shifting will work with any number of sprockets on the rear cluster; you just need more finesse the more sprockets you have.
In practice, some shift levers may not have enough lever travel to sweep a large number of sprockets. E.g. Simplex "retrofriction" levers have a smaller diameter barrel than most other friction levers and require more lever travel for a given movement of the derailleur. But I suspect 8 sprockets should be well within the range of any friction lever.
Quoted: 457 Post(s)
Liked 462 Times
My tall bike has a 10 speed rear that I shift with friction thumb shifters, but thumb shifters are better for friction shifting than DT shifters as you have more accurate control over a shift lever that is mounted to the bars as your hand is braced against the bar while you are operating the shifter, this is not so with DT shifters. I think 8 speed would likely be alright though, but bar end shifters would be better than DT shifters IMO.
Likes For jackbombay:
Bikes: 1972 Fuji The Finest | 1990 Bianchi Giro | 1999 LeMond Buenos Aires
Quoted: 151 Post(s)
Liked 303 Times
Been considering this myself. Second to please share what shifting combo you’re thinking of. Some later DT shifters came with bigger barrels that should move more cable. Could look into a JTEK shift mate to move the RD more for a given amount of cable pull, or look to a RD that moves more for a given cable pull (IIRC from Shimergo charts, old index Campy is 1.4, new 1.5, and Shimano 1.7, so Shimano RD moves more for the same amount of cable pull). Pre-index isn’t on those charts, you might have to measure (envision some tape flags measured against a set point on the frame, shifting a few cogs of known spacing, dividing the RD distance by the cable pulled). And as mentioned above the RD itself may not span the full width. Most 7s freewheels are around 32.5mm wide, while an 8s Shimano is 35.4 and 8s Campy 36.9. Good luck!
EDIT: Found an old spreadsheet where I was messing around with the JTEK Shiftmate ratios (using their charts for compatibility, and standard cassette pitch and Shimergo chart RD ratios, what the pull ratio change was - note you can install these in both directions). This would be applicable if the RD moves where you need it, but your shifter doesn't pull enough cable to move it there. All numbers fairly approximate, but should be good enough for friction. Never tried this myself, YMMV.
- Shiftmate 1: 1.05
- Shiftmate 2: 1.10
- Shiftmate 3: 1.19
- Shiftmate 4: 1.26
- Shiftmate 5: 1.36
- Shiftmate 6: 1.55
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
As noted, the two possible issues are the derailleur lacks range of motion to span between the outer cogs of an 8 speed and/or the shifter can’t pull enough cable.
If you are trying to do 8 speed, make sure to trim all slack from the shift cable when shifted down to the stop. That way, all of the shifter range is actually moving the derailleur.
If you have trouble with 8 speed, 7 speed should be easier because you would be spacing the cluster closer to the derailleur hanger on the dropout. So it lowers the required travel for both derailleur and shifter.
Otto
Otto
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
This is only tangentially related to the OP's questions, but I have learned to make every effort to provide any friction-shifted setup with the smoothest cabling possible.
This means clean cable housing with silicone-Teflon based lubricant and NO metal-on-metal contact along the cable's path.
The difference in shifting ease and accuracy makes quite a difference, and in some cases can even allow a shift lever with marginal cable travel to move certain derailers fully to their limits.
I ride in ever-rolling terrain around here, so shifting speed and accuracy tends to be more important.
Also, keeping the shift lever pivot and friction washers well lubricated can make another big difference in shifting performance.
Quoted: 2952 Post(s)
Liked 3,106 Times
No problem. I have 9-speed DA barcons set to friction on my TT bike. With a DA 7800 RD. I've run 9 and 10 speed Shimano wheels *and* 10 speed Campy wheels without any change.
As others mentioned, you have to be a little finer in your adjustments, but after a couple of shifts, it's second nature.
Likes For caloso:
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Otto
Easy peasy. I’ve been doing it for a long time. You get pretty automatic and you shift right into gear just like an index shifter.
Likes For Bogester:
feros ferio
Quoted: 1393 Post(s)
Liked 1,326 Times
My only index shift bike is my Schwinn, and I have always operated its thumb shift in friction mode. I currently run an 8-speed cassette on a 7-speed thumb shifter, and I have a 6-speed thumbie in reserve if the 7-speed wears out. (I found a 6-speed set at a very good price when the ratchet in my front shifter wore out.)
My equipment: 8-speed Shimano cassette, SunTour XC derailleurs and thumb shifters.
Liked 1,296 Times
But the plastic noodle material comes in all sizes and is easy to pre-curve, just a short section is needed so can be invisible.
Needs to be glued in place, I've used epoxy or silicone glue here on different builds.
Quoted: 4806 Post(s)
Liked 3,929 Times
I have bikes set up 7-speed with the SunTour auto-trimming DT shifter (never can remember its name) and my best bike has 9-speed and Superbe DT shifters. I'm pretty certain the auto-trimmer would run 8-speed. The rear derailleur plays a real part here. Some require considerably more cable pull than others. My 9-speed Campy Mirage has the DT lever folded nearly all the way back for low gear. My previous SunTours required a lot less pull.
Only issue . stroke width of RD to span a stack of 8+ cogs exceeds the amount of cable pull the lever drum winds up..
Cheerfully low end
Quoted: 646 Post(s)
Liked 1,044 Times
Otto
Partially Sane.
Bikes: Soma Saga, pre-disc
Quoted: 972 Post(s)
Liked 643 Times
Groupetto Dragon-Ass
Quoted: 415 Post(s)
Liked 786 Times
I remember close to two decades ago I got my first 9 speed cassette and was friction shifting with it.
I thought it SHIFTED LIKE BUTTER, thanks to the tooth shape working with the new chains, and said that we wouldn't ever have had click shifting if the old friction shifters worked like that.
And a bunch of really advanced bikers told me I was wrong, and I was just asking for missed shifts.
Glad to see that perception has changed.
However, I do think that clickity shifting will catch on, someday.
Likes For Chuckk:
Used to be Conspiratemus
Quoted: 297 Post(s)
Liked 245 Times
I have one bike whose Shimano derailer friction-shifts an 8-speed Shimano cassette with standard SunTour down-tube shifters (from the 6-7 sp freewheel era) without any modification at all. In the inner-most sprocket, the shifter lever is still comfortably short of parallel to the down tube. So this works flawlessly right out of the box. It is not at all difficult or finicky to shift and the modern ramped cogs make shifting really smooth, even under pedaling load. (Out of long habit, I still ease off a bit during shifting.) If you like friction-shifting an old six- or seven- speed freewheel, you will love friction-shifting an 8-speed cassette.
If your cassette is Campagnolo, you may run into more problems because Campag 8-speed spacing is wider than Shimano and so the cassettes are "fatter." One kludge I've used here is to replace the spacers with narrower spacers, salvaged from a worn-out 9-speed cassette, say. This is actually the easiest, cheapest solution that will work with all the parts you have, if you have (or can scrounge) the spacers, ...and you should use a 9-speed chain. It takes some ingenuity and trial-and-error to make sure your now-thinner cassette will still sit high enough on the freehub body to allow the lock ring to engage most of the threads in the freehub body without bottoming against it.
