Drop bar to straight bar questions
I’ve always rode drop bars, but as I get older I’ve been thinking about some sort of straight bar with a small riser on my Trucker. For those of you that have done this, how do you like it? What type of bar and shift system do you use? Thanks
Semper fi
Semper fi
Quoted: 3460 Post(s)
Liked 1,466 Times
A friend of mine never used the drops, he finally decided to switch to bull horn bars. Needed different brake levers, may have gotten a different stem with a shorter reach too. He retained his bar end shifters.
If you are comfortable riding on the hoods on drop bars, this could be a good option. But if you want to sit more upright than you do on the hoods, then this is probably a bad idea.
Quoted: 5888 Post(s)
Liked 3,471 Times
For touring on flat bars, I'd take a long hard look at a trekking bar. Unlike many flat bars, they give you lots of hand positions. Just think of them as a dropped bar squished flat. They're popular in Europe on touring bikes. I run one on a 1992 Trek 950 and I like it a lot. It's comfortable on long rides. You'll have to get the levers for flat bars and a pair of thumb shifters. Obviously you can run any shifters you like designed for flat bars but I like thumbies a lot.
Or take a page out of the mountain bike/drop bar conversions. These tend to be done with the bars pretty high for control purposes. But that might work well for your purposes. Guitar Ted has some good write ups on this:
https://g-tedproductions.blogspot.co...s-updated.html
Here's my Trek 950:
Here's my Trek 950:
Likes For bikemig:
Bikeable
Quoted: 173 Post(s)
Liked 104 Times
Hi, I have (road) bikes set up both ways. Because I had thumb surgery about three months ago, I cannot pivot my left STI lever on my drop bar road bike. My favorite (ok, I actually have quite a few bikes) right now is a bike with "ergo bars" that curve forward on the ends. (they take the place of having bar ends, to give me more hand positions) I actually use electrical tape to attach cut up pieces of "flip flops", to add 1/2 inch of padding and then wrap them with handlebar tape. Boy, this set up is comfortable on the hands.
Quoted: 598 Post(s)
Liked 283 Times
I agree with bikemig, trekking bars are imo a better option allowing for more numerous hand positions, which is important in keeping one's hands from becoming numb. If you do use straight bars, at least consider bar ends in order to allow your hands to be positioned at a more anatomically correct position so as not to place hours of compression on the ulnar nerve.
Occasional poster
I have a pair of trekking bars I had on a Trek 4300 for quite a few years. My son wore the bike out when he was in college. I think I want to put the bars on my 2002 520. Sounds like it might be more of a job than I want to take on.
TroyM - bike riding, guitar playing, retired high school agriculture teacher and regular guy.
Bikes: Voodoo Hoodoo, Linus Libertine
Quoted: 106 Post(s)
Liked 15 Times
Generic 700mm riser bar. M310 8 speed shifters.
At age 69 I have experimented with a variety of setups and really still prefer drop bars and set pretty low at that. I have not found raising them to add comfort and find riding with hands on the hoods to be my go to position the large majority of the time.
I have an old rigid mtb (1990 vintage Cannondale) that I also fitted with drop bars. It is nice for mixed on/off road touring and isn't bad even on technical singletrack. One big benefit was that my arthritic thumbs no longer have to deal with the thumb shifters (it now has some old 7 speed brifters). I have it set up with the bars pretty low much like my road bike.
My newer mtb which is used almost exclusively off road has front suspension, flat bars, and the bars are just a little higher, but still lower than the saddle.
Have a look at the bikepacking setups from the 2019 Tour Divide: https://bikepacking.com/bikes/tour-divide-rigs-2019/
Those racers using flat bars typically have short bar ends for placing their hands in the "hoods" position. Almost everyone uses aero bars. You can also make out some Jones Loop bars, which I've used extensively and love.
+1 ... trekking bars : provides accommodation for Magura Brakes & Rohloff Shift grip.
Quoted: 137 Post(s)
Liked 81 Times
When I hit my mid 50’s and acquired a gut the drops were no longer an option but as well brake control on the hoods was pretty bad with a heavy front load at low speeds so I went to a Jones H bar. Straight mtn bike bars and bar end extensions isn’t as comfortable as the various trekking bars. that allow more neutral hand positions similar to the top of the hoods on drop bars.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 992 Times
This
Shimano BL-R780 and SL-R770 driving an Ultegra 6500GS RD. These are Ultegra level shifters and brake levers for flat bars. This bike has a Dura-Ace DT front shifter and derailleur. These shifter are so positive in shifting I almost miss that they shifted. They can be found on eBay and I found 3 sets in the Netherlands and non-fixie facilitated for me.
Liked 1,466 Times
Quoted: 455 Post(s)
Liked 112 Times
Another option is the Velo Orange Crazy Bars. I switched to these after riding across the US and Europe. I really like the hand position options.
Currently touring in Wyoming.
Ergon GR 5 is their longest comfort grip integrated bar end combination... to add to straight/MTB bars..
https://www.ergonbike.com/en/article-gp1.html
Quoted: 56 Post(s)
Liked 14 Times
Having the levers and shifters mounted closer in along with configuring them with an upward angle on the horns would make this a pretty comfortable option for riders who prefer a more upright riding position. It also makes them an attractive alternative to trekking bars for people moving away from drops (or coming from flat bars) as it doesn't require switching to a much longer stem. Yes, you can indeed mount trekking bars in reverse (open ends outwards), which some people do, but since trekking bars do not normally come apart to facilitate grip installation you probably could not pull off Ergons or anything like that.
Here is a pretty common example (albeit just using foam tube lining):
There is even a "comfort" version of these bars with a 25mm riser made by Ergotec to raise things up even higher. Unfortunately, the non-rise mid-bar portion is so narrow (only about 2 inches), you would not be able to fit any of the common handlebar bag quick releases (Klickfix, Arkel's aluminum bag mount, etc.).
Just me but...
One thing I never really understood was why folks seemed to equate drop bars value only with the use of the drops and see a lack of fitness or a gut as a reason to not use them. I have always found the hoods to be more comfortable than the other options that try to duplicate that position, so, I'd use drop bars even if I never used the drop position. If the extra weight was that much of a worry you could always just chop the drops off. Also if you don't want to bend as much drop bars can be mounted higher.
I see trekking bars as a way to almost duplicate drop bar comfort with flat bar levers and shifters.
Quoted: 56 Post(s)
Liked 14 Times
Quoted: 2495 Post(s)
Liked 738 Times
Simply changing to bullhorns without changing anything else, is just time and money wasted IMO. First thing I would do if it were my bike would be to change just the stem to something 20cm shorter than whatever it is now. I would go to a bike co-op and get something from a parts bin. New stems are $30 to $$$$$$. If that didn't work and I was serious about a conversion then my advice is to get what is called a 'riser bar'. Ideally something with a bit of backsweep'. The On one "Mary" bar is a classic example. I have an FSA "Metropolis" bar on our tandem and I love it. Velo Orange has some very nice bars that I forget the name of.
A properly designed dropbar frame will be shorter in the top tube than its flatbar counterpart. You might find you now need a much longer stem for the flatbar which is why I advised going cheap while you experiment. I just can't find love in my heart for Trekking bars. I just bought a bike with Jones 'H' bars (knock-off) and they may be going free to a good home as I am thinking hard about getting another "Metropolis" bar for that bike. Triggers all the way. Thumbshifters if you must, but never Gripshifters <shudder>.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Keep the drops and go to a taller stem from VO.
https://velo-orange.com/collections/...nt=51377886919
Quoted: 56 Post(s)
Liked 14 Times
