What's your minimum preferred tire width for gravel riding?
Old 09-02-20, 06:48 PM
Helldorado
Bikes: Cervelo Aspero Apex1x 2020; Giant Escape Disc modified commuter 2021
Quoted: 127 Post(s)
Liked 80 Times in 44 Posts
I'm riding on a set of 42mm-wide 700C tires, because that's as wide as my bike frame will allow. How many of you prefer wider rubber for dry conditions gravel grinding?
Helldorado is offline
Old 09-02-20, 09:47 PM
pipeliner
Quoted: 43 Post(s)
Liked 72 Times in 40 Posts
40mmm is the minimum for me, ride 45s most of the time. I also weigh 240 and deal with dry conditions regularly. If I weighed 100lbs less i would consider running 38s...
pipeliner is offline
Likes For pipeliner:
Old 09-03-20, 01:21 AM
l3m4nt
Quoted: 12 Post(s)
Liked 38 Times in 12 Posts
42 mm tubeless, I usually ride some easy MTB-tracks in the neighborhood
l3m4nt is offline
Old 09-03-20, 01:33 AM
stevel610
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 457 Times in 240 Posts
I don't ride smaller than 32's which work well enough on gravel bike paths. Prefer 40's.
stevel610 is offline
Old 09-03-20, 05:19 AM
mack_turtle
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times in 273 Posts
I have 700x35 because that's all my frame will allow. It sucks so badly on the local terrain that I ride that I've been saving for months and searching for a new frame or new bike.
mack_turtle is offline
Old 09-03-20, 06:30 AM
Koyote
Quoted: 6963 Post(s)
Liked 10,961 Times in 4,687 Posts
Dry conditions? It depends entirely on the terrain. Smooth, hard-packed roads will be fine with 35s or even 32s. Lots of potholes, rocks, tree roots coming up through the road, etc, and 40+ is good.
At any rate, 42s are really pretty good all-rounders. That's what I run (they actually puff out to about 43-44mm), and they are sufficient for everything I encounter short of mud bogs and such. And remember that tire width (and tread, and psi) is always a balancing act in gravel riding: on a good long ride or race, you'll have, at some points, too much tire...And at other points, too little tire.
Koyote is offline
Old 09-03-20, 06:39 AM
Rides4Beer
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times in 414 Posts
I've been fine on 38mm (actual), but I'm def enjoying the extra volume from my new tires that measure out over 44mm.
Rides4Beer is offline
Old 09-03-20, 07:36 AM
mstateglfr
Sunshine
mstateglfr's Avatar
Quoted: 10955 Post(s)
Liked 7,484 Times in 4,186 Posts
min would be 40mm i guess since thats what i used to use.
currently i have tires that measure 43 actual. i need to replace them soon and half want to try a new tire and half want to get the same tire again since I know I like it. The new ones will be 43 as well, regardless of which way i decide.
my frame can fit 47mm officially and over 2" 29er unofficially. i dont have interest in that for how/where I ride.
mstateglfr is offline
Old 09-03-20, 08:34 AM
chas58
chas58's Avatar
Bikes: too many of all kinds
Quoted: 1147 Post(s)
Liked 415 Times in 335 Posts
I spend most of the summer on 32's, as our summer gravel is smoother than our summer asphalt.
But really, I chose a tire whose casing is 1.5x the size of the gravel (rocks, roots) I'll be riding on. Sometimes its 32, sometimes its 40, sometimes its 54mm
chas58 is offline
Old 09-03-20, 08:37 AM
danmyersmn
Quoted: 103 Post(s)
Liked 28 Times in 15 Posts
650bx47 and it works excellent.
danmyersmn is offline
Likes For danmyersmn:
Old 09-03-20, 08:40 AM
unterhausen
Randomhead
Liked 3,696 Times in 2,517 Posts
I run 700x38mm Prior to this bike, I rode 700x30mm, but had too many flats. We have big, fast descents with loose gravel, so 38 is probably the smallest I would use around here.
unterhausen is offline
Old 09-03-20, 09:24 AM
DorkDisk
Quoted: 576 Post(s)
Liked 1,001 Times in 488 Posts
32 minimum, 38 max frame clearance, 40 ideal round number and good balance.
DorkDisk is offline
Old 09-03-20, 10:10 AM
Koyote
I’m gonna guess: WTB Resolute?
Koyote is offline
Old 09-03-20, 10:19 AM
mstateglfr
Sunshine
mstateglfr's Avatar
thats the one. Its been a great tire so far. It doesn't feel sluggish, it feels good on pavement, and I've ridden a ton of flat river bottom singletrack this year on it.
But trying something new is intriguing and the 43mm gravelking SS looks perfect for how I usually use the bike, which is 2/3 gravel 1/3 pavement.
Old 09-03-20, 10:22 AM
Koyote
i’ve been running the same tires on my main gravel rig for about 1 & 1/2 years now. No complaints at all, no problems, and I get good tread life. But still… There is that curiosity about other tires.
Koyote is offline
Old 09-03-20, 11:10 AM
pipeliner
Quoted: 43 Post(s)
Super dry and fluffy in west NE right now. Roads vary from somewhat OK to 4” deep dried flour. Been on 700c45s at 35/28 psi, helps a lot.
Old 09-03-20, 11:35 AM
Bob the Mech
Bob the Mech's Avatar
Bikes: 2016 Trek Emonda S6 frameset, custom build (road). 1995 Dawes Genesis Reynolds 531 Competition frameset, custom build (road). 1996 Orange C16R frameset, custom build (retro MTB). Coyote Dual hard-tail, custom build (MTB).
Quoted: 61 Post(s)
Liked 76 Times in 55 Posts
I converted a 1996 full rigid XC MTB to a drop bar gravel grinder...I can run 32c 'slicks' on the black top, 35c CX tyres on hard pack and light cravel and up to 53c knobblies for pretty much any other surface you care to mention. Even have a set of studded ice tyres for deep winter riding...
Bob the Mech is offline
Old 09-03-20, 03:37 PM
Koyote
I just had a look at the Gravelking SS tire at the Panaracer website. I'm thinking that it may be a wash vs the Resolute. They're about the same weight, and while the GK has a smooth center tread (which should make it faster), it also has a puncture prevention belt (which should make it slower and less supple). 'Course, if you have puncture issues, you may benefit...But (knock on wood), my Resolutes have only punctured a couple times and have always sealed up nicely (Orange Seal).
Koyote is offline
Old 09-03-20, 04:10 PM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
Currently experimenting with 700x36mm (about 37mm IRL) Challenge Gravel Grinder tires...very fast/smooth rolling on improved surfaces, but ofc no tread. As small as I will go. I've gone as large as 700x50mm, slow but very comfortable.
Marcus_Ti is offline
Old 09-03-20, 04:13 PM
davei1980
Very Slow Rider
davei1980's Avatar
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times in 101 Posts
3" - Don't listen to folks who say wider is slower on gravel, all those vibrations transferring to your body from narrow tires will wear you out way more quickly than the power it takes to kick over a wider tire.
Wide tire, < 10psi, you'll thank me later!
davei1980 is offline
Likes For davei1980:
Old 09-03-20, 04:19 PM
tyrion
tyrion's Avatar
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times in 972 Posts
50mm. Everytime I increase tire size, I like it better. I'm up to 50mm now (Gravelking SK).
tyrion is offline
Likes For tyrion:
Old 09-03-20, 05:05 PM
mstateglfr
Sunshine
mstateglfr's Avatar
There are 2 versions of the GKss. One is the GKss and the other isnthe GKss Plus+.
Apparently they felt it necessary to both spell out and make the image for the plus part.
The Plus+ has the PT shield casing, but I am considering the regular model without the extra protection. Its a handfulnof grams heavier than the Resolute, but smoother tread like you said.
The Conti Terra Speed would be neat to consider, but its 40mm at widest apparently(not really a deal breaker) and I've read it runs narrow.
Old 09-03-20, 05:08 PM
davei1980
Very Slow Rider
davei1980's Avatar
Quoted: 500 Post(s)
I want to build a bike around that exact tire.
Old 09-03-20, 05:27 PM
Rides4Beer
Quoted: 733 Post(s)
Depends on your gravel, and your speed. No one is winning races around here on a tire that big, not even with some pretty chunky sections. I'm racing on Sat and my 42mm Pathfinders (44+mm actual) will probably be the biggest tires at the front of the pack (I'm also one of the bigger guys up front, so I guess it makes sense lol).
Old 09-03-20, 05:42 PM
davei1980
Very Slow Rider
davei1980's Avatar
Quoted: 500 Post(s)
Yeah no no no no - big caveat - not for racing
When you get in to racing things like comfort become less important and things like aero become way more important so yeah, I think we can both say we're both right (?). I think if you're not racing, go huge! The advantages in all day comfort, traction, and fatigue are awesome! Putz around at the party pace all day man! But when you're racing, you have a real decision to make, don't you? Rotational weight, aero, traction, rolling resistance, sponsorship pressure (not trivial, this is a real thing), etc.... I heard the guy who won last year's Dirty Kanza did so on 42mm tires, so I think you know what you're talking about here!
It's true, larger tires do have lower rolling resistance over rough terrain than smaller, narrower ones, but I have also heard that advantage is one you give up with aero drag starting at about 12 MPH or so. I am not a scientist but I believe both these phenomena are true.
I have also learned that a lot of things make sense to competitive riders which make little sense to noncompetitive ones, and vice versa.
