What's your minimum preferred tire width for gravel riding?
Quoted: 6934 Post(s)
Liked 10,936 Times
There are 2 versions of the GKss. One is the GKss and the other isnthe GKss Plus+.
Apparently they felt it necessary to both spell out and make the image for the plus part.
The Plus+ has the PT shield casing, but I am considering the regular model without the extra protection. Its a handfulnof grams heavier than the Resolute, but smoother tread like you said.
The Conti Terra Speed would be neat to consider, but its 40mm at widest apparently(not really a deal breaker) and I've read it runs narrow.
Likes For Koyote:
Likes For Helldorado:
Quoted: 1079 Post(s)
Liked 1,017 Times
Max size is 38, I grew up in the country surrounded by dirt roads and "paved" roads that every couple of years were resurfaced with a mix of gravel and tar and did it with 27x 1 1/8 and later 700x25s and never had problems with riding them. If I need bigger then a 38 I just take the MTB, that's why I have it and it rides smoothly. Cross will handle a 35 while the gravel will take a 38 and either is fine; as to actual minimum, probably still be quite fine with a 28 for most upstate NY seasonal highways and old dirt roads.
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times
Yeah no no no no - big caveat - not for racing
When you get in to racing things like comfort become less important and things like aero become way more important so yeah, I think we can both say we're both right (?). I think if you're not racing, go huge! The advantages in all day comfort, traction, and fatigue are awesome! Putz around at the party pace all day man! But when you're racing, you have a real decision to make, don't you? Rotational weight, aero, traction, rolling resistance, sponsorship pressure (not trivial, this is a real thing), etc.... I heard the guy who won last year's Dirty Kanza did so on 42mm tires, so I think you know what you're talking about here!
It's true, larger tires do have lower rolling resistance over rough terrain than smaller, narrower ones, but I have also heard that advantage is one you give up with aero drag starting at about 12 MPH or so. I am not a scientist but I believe both these phenomena are true.
I have also learned that a lot of things make sense to competitive riders which make little sense to noncompetitive ones, and vice versa.
Very Slow Rider
Bikes: Jones Plus LWB, 1983 Centurion Japanese CrMo bike
Quoted: 500 Post(s)
Liked 132 Times
Sunshine
Quoted: 10947 Post(s)
Liked 7,473 Times
100% agree. It isnt quite as bad as Schwalbe's g-one offerings or Schwalbe's nearly impossible to sort out Marathon offerings. No model tire should have 25 different tires in varying casings, treads, widths, etc which all seem to also overlap.
Likes For mstateglfr:
Bikes: Kona Kahuna DL Drop Bar - Sensah SRX Pro 1x11 (2012 Frame), Giant Toughroad GX 1 - Shimano Road Hydro + SLX 1x10 (2018), Diamondback Sync'r - SRAM NX 1x12 (2020)
Quoted: 160 Post(s)
Liked 97 Times
700c minimum: 47mm. 650b minimum: 50mm. 40s, 42s, and even 45s in a 700c just wasn't cutting it for me. I run Teravail Rutlands in 47mm width and it feels like a good sweet spot for me.
With 650b, I personally like the feel of 50mm tires. I think the OD is closer to a 32mm tire on a 700c, which is what I find more comfortable than just the 650x47mm "road plus standard". And also considering how it drops the bikes BB height I just want to raise it up to reduce pedal strikes when running 650b.
One more important thing with minimum tire width is minimum rim width. In a perfect world I would run no smaller than 23mm inner width with 700c wheels, and 25mm with 650b wheels.
42 is about the smallest I'll use. Size matters but the tire itself and it's characteristics matter to. Gravel riding is about 1/2 my total miles and on country farm roads that the same road surface varies widely from one day to the next. The other 1/2 is chip seal.
Guest
Quoted: 1346 Post(s)
Liked 3,270 Times
35mm is as skinny as I'd ever choose to go, but 32s will do the job if you're paying attention. Right now, I'm running Gravel King SK 43s and I would marry them if it was legal.
velo-dilettante
Quoted: 1626 Post(s)
Liked 3,112 Times
i only rock '23's and occasionally ride dirt/gravel area up to five miles in length. sometimes my line is better than other times. occasionally hafta hoof it for < 50 yards.
not setting any land speed records but, every so often, you feel like taking a shortcut. not taking the sweet tires out for these excursions but sometimes, you don't wanna turn around
and wanna push thru. if it's too soupy, it's a dismount.
Likes For diphthong:
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
40mm on a 700c is my minimum for dry conditions. I’m m 6’4” 270#.
I’m actually running a WTB 42 Resolute up front and a 44 Byway in back currently for my gravel rides. Run them about 35-40psi and keep trying to go a little lower. I’ve got a separate light road wheel set with 40mm Schwalbe G-ones when I’ll be on Mostly tarmac rides.
I found my setup is great for nominal dry conditions but won’t cut it for anything less with rains, mud, Sand or chunky gravel. I have a fat bike mostly for winter snow but it’s a dog for long rides, even my separate 2.2” wheel set. Looking for N+1 bike that finds the sweet spot for me that will fit 2.2-3” tires. Looking at a rigid 29+ bike like a Surly Krampus or Jones bike.
Quoted: 198 Post(s)
Liked 332 Times
i generally don’t go over 12mph on gravel unless I’m going downhill. So aero isn’t much of a concern.
As I get older comfort = enjoying my ride for longer miles. Speed is for those young kids!
Hi all, jumping in here, but how to do you determine -- based on specs -- what the max width of tire your bike can fit? I'm looking at a Devinci Hatchet 105 Aluminum (carbon forks) that comes with Maxxi-Refuse 700x32 tires; not sure how to tell what max width I can go.
Thanks
Thanks
Quoted: 198 Post(s)
Liked 332 Times
Thanks
Thanks
Manufacturers rarely list such, they like it to be a mystery. I suppose the tire and pressure chosen can vary widely from nominal dimensions. Gotta ask they’re customer service or talk to someone with experience of that frame.
Ah ok. They list 40c as the widest tire in the specs. I'm guessing you guys take the bike in for a test fitment before you commit to new tires/wheels?
Sunshine
Liked 7,473 Times
With a frame that states 40 is the most, I would get a new frame, use 38s if i didn't want to push the envelope, or use a 40mm tire that is reported to inflate true to size.
Quoted: 1455 Post(s)
Liked 1,477 Times
I'm wondering if 32mm would be suitable enough for me and I weigh 124 lbs and planning to use 700c wheels. According to the tire pressure tables, I can run the tires at 50 / 40 psi (rear and front)
My road conditions are mixed gravel with plenty of potholes in the asphalt roads - in the side lanes and I won't be able to dodge all of them in traffic.
I'm looking for a gravel bike locally but are way too expensive for me. However, I found road bikes I can afford with decent groupsets, gravel-friendly compliant frame, and fits 32mm tires.
I ride 32mm GP5000's on smooth and flat gravel/dirt and crushed limestone trails and they work great on those types of conditions. On flat rural gravel roads, the GP5000's are a little dicey unless it's really packed down, but 33mm CX tires work great for me in those conditions. I'm around 165lbs.
I've never run anything larger than 35mm on a gravel bike, but can definitely imagine situations where 40-45mm would be beneficial. I'm super jealous of those that get to ride in these types of conditions. Anything more gnarly than that, and I'd probably just be on an XC MTB.
Likes For msu2001la:
Sums up my situation. I max out on 45 (Riddlers for me). Some of my routes are a coin flip or weather for deciding between that and my XC
Quoted: 184 Post(s)
Liked 36 Times
Wide Tires
If that isn't the truth, lol. When local maintenance crew has been over my gravel roads, or there's been a ton of AG equipment running on them, I frequently have to go with the fat bike running the super lite Jumbo Jims. Very cushy, and rolls over everything, lol.
Pedalin' Erry Day
I'm a little surprised how high the 'minimum' numbers in this thread are. I like wider tires too, but I'd say my minimum is 27mm since I've ridden lots of gravel roads in Colorado and now in California with trusty Parigi-Roubaix tires and always been happy with them. Maybe that's in part because I got used to riding a CX bike with 28mm tires on singletrack? Last week I was out exploring the area around my new home and found a farm road that suddenly turned into loose chunky golf ball gravel with washboard for a couple miles - I was on my go-fast road bike with 23mm tires and plowed through without incident even though it wasn't much fun, so maybe 23mm is my real minimum?
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
Generally my min width is 32mm, and max width is 32...as printed on the sidewall. Some tires inflate bigger, some smaller. Run them tubeless, and run inflation pressure for conditions. 5 bar for hard pack, pavement. 4 bar for cobbles, pave, gravel roads. 3 bar for rough surfaces or loose, and wet. I've been down to 2.5, but worry about burping in that range. This is to say nothing about tread type...slick, files, small blocks, big blocks. Certainly wider would be cushier, but I like the feel and responsiveness of a CX tire, especially when speeding around the forests here. It works for me.
Bikes: Soma Pescadero, Surly Pugsley, Salsa Fargo, Schwinn Klunker, Gravity SS 27.5, Monocog 29er
Quoted: 186 Post(s)
Liked 234 Times
Minimum about 28mm. I've done lots miles on 23's though.
Likes For c_m_shooter:
Bikes: 2016 Surly Cross Check, 2019 Kona Rove ST
Quoted: 284 Post(s)
Liked 313 Times
Totally sold on my 650B x 47s. Wouldn't mind trying 50s at some point. But I ride more rocky fireroads and singletrack than actual "gravel" which we don't really have here, so that's a factor. I have another bike with 700c x 40s and I do enjoy what seems like a "faster" feel with those on smooth hardpack, and certainly on the road, but in anything rough it's a sketchier ride for sure.
