Advice - are there bikes with "Endurance" geometry that are ALSO relatively light???
Quoted: 25 Post(s)
Liked 21 Times
Don’t limit yourself to “ endurance “ bikes. I have a 2018 Cannondale Synapse. It is a great bike but I felt there was something missing. I got a 2020 Cannondale SuperSix and found the missing something. Handles more responsively, climbs better. If you can test ride both it would be worth trying. The Synapse was a great descender but is like a pair of GS skis, meant for carving longer arcs. The SuperSix is like slalom skis but not at all a twitchy descender, more like an amusement park on wheels!
[To be clear: I realize that some people may not have the flexibility to be on a standard road bike with no headset spacers. I also think that being able to comfortably ride is more important than whether the bike looks better with fewer spacers. But all other things being equal, see above, and try to avoid buying a bike the requires an excessive amount of spacers when other satisfactory options are available.]
Quoted: 6193 Post(s)
Liked 4,808 Times
I think you are making a mistake by limiting yourself to bikes marketed as "endurance". Unless you truly need a more relaxed position and want to be more upright.
The terms race and endurance are more about the position you want to be than it is a bike for racing or enduring long rides. Race fit bikes are more than comfortable enough to go on long 100 or 200 mile or even further rides.
Likes For Iride01:
I also like the handling of these bikes (I own a CAAD10 which has identical geometry to the SuperSix). Though I like the stable handling of my gravel bike on rough terrain. So different horses for different courses. That said, I'm guessing the OP doesn't want to have a huge stack of spacers on top of this stem due to the short headtube of such bikes. The consequences of this big stack of spacers range from mild (not pretty) to problematic (not considered safe by the bike maker). I personally think a frame is a better fit if it can be ridden without an enormous stack of spacers. If I were ordering a custom bike it would be designed to fit me with no spacers at all.
I also don’t think Cannondale would sell a bike like the Supersix that CAN accommodate stack height if it did not intend people to utilize that possibility.
Try it. You will like it!
Quoted: 1067 Post(s)
Liked 259 Times
I am a bit the same and can easily get 4"+ of saddle/handlebar drop on an endurance frame.
Liked 4,808 Times
The issue with the OP is that he is fairly tall with long legs. On an "endurance" bike with more stack than a typical race frame his saddle height is such that he can still get a "race" fit.
With a 73cm saddle height, I get about a 10cm saddle to bar drop with a stack of 527mm, a 15mm headset top, no spacers and a -17 stem. I use a 100mm stem and 80mm reach bars, with a 383mm reach. If I want, just changing to a -6 stem would raise the bars by 2cm. Endurance franes with adequate seat tube length and about the same reach have 2-4cm more stack, so just changing the same stem angle would match some endurance frame's stack and 2cm of spacer would match the tallest stacks, without looking stupid. If I need less than an 8cm saddle to bar drop, I might someday look at an endurance frame. At age 67, I'm not there yet.
The super six does not have the extra stack height of an endurance bike. If that's needed, then you'd end up with lots of spacers and a higher rise stem.
https://www.cannondale.com/en-us/bik...force-etap-axs
Quoted: 25 Post(s)
Liked 21 Times
The geometry differences between the CAAD 10 and 2020 Supersix make them not “ identical “ Cannondale changed the frame geometry in the new Supersix, pushing it slightly towards “ endurance “. On my Synapse I had a low stack height, as I wanted to mimic my ‘92 Merckx Century. I had the Supersix set up to be similar to the Synapse, so no “ enormous “ stack of spacers. They are both more “ upright “ than my Merckx but at age 60 that is not a bad thing. It is quite possible to have a 2020 Supersix, be in “ endurance “ territory and enjoy a bike that simply handles better. You don’t need an “ enormous “ stack height to do it. It is the most stable descending bike I have owned in my 45 years of riding.
I just looked at the geometry chart for the new SuperSix (2020), my CAAD10, and the Canyon Endurace ("endurance" bike). The new SuperSix is marginally more slack than my CAAD10, but we are only talking 5 - 10 mm in stack height for a comparable size or reach. Contrast that the the Canyon Endurace, which at similar reach measurements to the SuperSix has about 2.5-3 cm more stack height. That is what the OP is looking for in a bike, due to his dimensions. The SuperSix would require another 3cm of spacers on the bike (on top of the number he would need for the "endurance" frames that have taller stack height). That might be more that is safely recommended. And it wouldn't add to the sleek looks of the bike either.
[EDIT: Also, yeah, I clearly second the comment right above which I hadn't seen yet.]
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Also, fun to play with if you have a few models you want to compare:
https://99spokes.com/compare?bikes=f...dvanced-1-2021
If not already mentioned, you could check out the Felt VR models, if you're looking for a high stack to reach ratio. Their 105 model is listed at 18.5 lbs, their Ultegra at 17.2 lbs.
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
My Cervelo C3 weighs just under 18 lbs out the door minus water bottle. It has 8cm of saddle to bar drop.
My Canyon Ultimate weighs about half a pound less, at 17.5 lbs out the door minus water bottle. It has 17cm of bar drop.
The weight difference is not really significant. Everything else on the bikes matters a whole lot more.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
I do believe that to a degree - 17.5 vs 18, meh - 18 vs 20, yes. Does anyone know if there is somewhere that tracks and records frame weights? If one wanted to start with a frame (or buy, strip, and start over), that would be good information.
As for frame weights, keep in mind that the largest sizes will always weigh more. My cheapest model Colnago frame in the third from smallest size weighs about 1200 grams and fork about 400. Since I have rim brakes, the whole bike comes in at 7.3Kg, with no pedal or cages and Campy Chorus or SRAM Force AXS. Disc would probably add 400 grams. I can't imagine any decent frame weighing in over 1500. That would put a large frame with discs real close to 8kg, or under 18 lbs.
Let's say you have 9cm more saddle height than I do. That means a frame stack height around 600, with a 15mm headset top like I use and a -6 stem should give you about a 10cm saddle to bar drop, with NO spacers. A 580 frame stack would require about 20mm of spacer. A little more stem angle would reduce the drop a little more.
I measure the drop from the floor to top of saddle and bars. If the bike's on a level floor, a carpenter's level can be placed on the saddle and extended above the bars.
Likes For Plainsman:
Don't forget stem angle when adjusting bar height. Adding spacers is not the only option. I need no spacers with a -17 stem. Changing to a -6 raises the bars by 2cm. Flipping that stem to a +6 would add another 2cm. The flipped up stem isn't real pretty, but I now see some top level aerodynamic frames with one piece bar/stem combinations with a substantial upward rise being used in this year's tour.
Likes For DaveSSS:
Quoted: 25 Post(s)
Liked 21 Times
I really appreciate the feedback everyone has given me on this thread so far. Just to close the loop - I've since had a professional bike fit in order to determine what type of frame geometry best fits my physiology and level of flexibility. When it was all said and done, it turns out I can get plenty aggressive in what most would consider endurance geometry, and would need a lot of spacers on most race geometry bikes just to avoid being "too" aggressive. Using the data for a Giant Defy for example, I can use 20mm of spacers under the stem and I still get a not-to-shabby saddle to bar drop of roughly 13 and a half cm. Achieving a good aggressive position on an endurance geometry will be pretty easy, with room to get lower if I want, or to be less aggressive for longer and rougher rides. With the race geometry we tried (Like a TCR), I get very low from the starting position, and the only way to lessen that is to stack spacers to the point they aren't very pleasing to the eye. Based on body type, endurance geo doesn't = "relaxed" fit for me, but rather a good riding position for the type of events I want to do, with the ability to get into a more aggressive position similar to what others would have on race geo frames. I sort of think branding frames as endurance vs race is a disservice, as the proportions of the rider have as much or more to do with the fit as does the frame itself. Now, to find an endurance frame that looks good and doesn't weigh a ton! Light, attractive, affordable - pick 2! ;-)
I think the folks who kept talking about race-style frames seemed to forget that different proportions = very different fits on the same bike. When you told us already that you were running the maximum number of spacers on your semi-endurance frame and still had 10cm of drop, it was pretty obvious that a bike with a super-short headtube would not be the best choice to match your desired bike position. Sure, you can run lots of spacers and a positive-rise stems on a "race" frame, but why would you do this if you can find a frame that can be made to fit without such extreme measures (and have it look sleeker, too)?
Enjoy your time bike shopping! Next year's models should be around the corner, so inventory on all the sizes will hopefully be easier to come by soon.
Likes For TrackSmart:
