Will any friction downtube shifters work with 9-speed cassette?
Quoted: 7 Post(s)
I'm putting a bike together that will be using downtube shifters. My title sort if says it all... Can I buy any set of old downtube levers from eBay and use them with a 9-speed cassette? Do older levers that were originally for 7-speed or less not have enough range to reach all the cogs on an 8, 9 or 10-speed cassette?
Really Old Senior Member
Friction shifters will shift anything.
Quoted: 581 Post(s)
Liked 921 Times
Yes. The only potential exception is Sram 1:1 ratio derailleurs, which may require more cable pull to cross the whole cassette than some shifters can accommodate.
I have a 9 sp cassette and chain, and a Shimano 9 sp rear derailleur connected to a 7 sp bar end shifter set to 'friction' mode. It works perfectly 100% of the time. I might switch to indexed 9 speed shifters at some point, but there is no urgent need.
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Generally speaking, yes, almost any older friction shifter will move across a larger 8-9-10 speed cassette.
I would caution against using some of the 70’s friction shifters with smaller barrels, however. Originally intended for five speed and may not be able to'pull enough cable.
I have some older Suntour friction shifters and the barrel is noticably smaller than the Shimano 6207’s that are my faves.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
I have 9-speed DA downtube shifters but when I put them in friction mode they won't hold the gear and the derailleur creeps and eventually upshifts.
They work great in index mode. The friction tightening thing is a regular screw and I really cranked down on it and it just won't tighten enough.
I recommend looking for shifters that have the ratcheting feature for extra hold.
Quoted: 4806 Post(s)
Liked 3,928 Times
I use a SunTour Superbe DT friction on my 9-speed. It has a relatively small drum diameter so it is folded all the way back in low gear but it shifts beautifully.
Quoted: 325 Post(s)
Liked 109 Times
Maybe if you can find a good set of friction shifters you can make it work, but given the amount of NOS 9-speed parts still on ebay, I would just go for the indexed version.
