Convert BB from cup&cone to cartridge
Really Old Senior Member
Without getting really expensive (Phil's BB's) it sounds like your best bet is a 127mm BB.
I've not seen longer than that in a cartridge.
Spindle length might be a bit nebulous.
Imagine cutting 3mm off the DS. You cranks will still be in the same place.
Actual measurement is at a specified ref point on the taper where the taper is a certain size.
Some spindles may not adhere to common specs.
You're pretty much stuck with trying a 127 and hoping.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Yep. And if your chain-line is not quite right, you can add a few spacers between the cartridge and the drive side shell to move the spindle out a bit. Moving it in would require machining the shell, which you probably don't want to do.
The bottom line is for a triple crank, a chain-line off a few mm one way or the other is not a big deal.
Good luck on this project. Let us know how it works out.
It's probably cheaper to "eat" the 1st BB then pay the cost of having the shell faced.
SE Wis
Quoted: 2742 Post(s)
Liked 3,389 Times
70mm English threaded BB are not unheard of in 80's Asian built frames.
https://www.bikeforums.net/bicycle-m...sh-thread.html
https://www.bikeforums.net/classic-v...et-i-need.html
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
Yeah, considering the root words axis and spin, that'd be a valid distinction.
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
Don't know how they work but could that get me the 2mm I need to get to 70mm?
Someone suggested I could thread the non drive side end of the cartridge further beyond flush to eat the 2mm space.
No problems with crank on the NDS.
Any comments?
SE Wis
Liked 3,389 Times
I went to velo-orange site and found that they have spacers for 68mm cartridges.
Any comments?
Any comments?
68mm cartridge in a 70mm shell NDS buried.
Likes For dedhed:
