Is it OK to hang bike on wall hook by front wheel?
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
Yes
Likes For Homebrew01:
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
Yes. Absolutely. 100x Yes.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
Quoted: 6193 Post(s)
Liked 4,810 Times
It doesn't work, I tried to put a couple bike hooks by the fireplace in my living room. The wife said NO!
Likes For Iride01:
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
You can also use the back wheel
pan y agua
Quoted: 1447 Post(s)
Liked 727 Times
To explain why the answer is a unequivocal yes. You’re putting a static load of 20 pounds or less on the wheel. On the road, you’re asking the wheel to hold up under loads that are orders of magnitude higher. The front wheel is being asked to hold up 100 pounds or so constantly on the road, and subjected to loads from impacts such as potholes much much higher than that
You could get lost and die.
You could hit a tree and die.
Quoted: 4806 Post(s)
Liked 3,928 Times
I'd wrap the hook with duct tape, inner tube or something else to prevent scratches.
If you want to hang several bikes and save space, stagger the heights 16-18". If they are dropped handlebar bikes, you can get them as close as 11" apart and still have no issue at all hanging or taking down the bikes. (I can hang a heavy bike easily dead tired on the high hook,)
Ben
Ben
Likes For 79pmooney:
Liked 3,928 Times
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Klaatu..Verata..Necktie?
Quoted: 10425 Post(s)
Liked 11,899 Times
Ben
Ben
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
Wheel hooks became a pain once I got 58mm wheels. Very tight squeeze to get the bike on. I got daHanger DANs which uses the pedal to hang on to with two platforms for the wheels. Very nice setup, though you'd be stacking multiple bikes vertically in the same space it'd take horizontally, which might be an issue if it's difficult to lift a bike overhead.
Likes For rubiksoval:
Liked 11,899 Times
Likes For Pirkaus:
Bikes: bikes
Liked 1,429 Times
No, I don't get blown around at all. I'd ride 80mm if I had them. Newer wheel designs are significantly better in crosswinds and higher yaw angles than the v-shaped designs of the 90s/early 00s.
Quoted: 3952 Post(s)
Liked 7,297 Times
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I hang by the rear or both wheels.
Just easier to hang it when the wheel doesn't flop around.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Super Moderator
Liked 927 Times
I ride 50mm wheels. I only get head winds.
Likes For Zaskar:
Advocatus Diaboli
Quoted: 4735 Post(s)
Liked 1,532 Times
So, is the whole air bubbles or whatnot if with hydraulic disc brakes thing a non-issue?
Bikes: Too many.
Quoted: 92 Post(s)
Liked 174 Times
If there is air in the system so that air bubbles form, bleed your brakes. If air is entering the system because of how the bike is hanging, there are issues beyond the hanging of the bike.
On Your Left
Liked 2,433 Times
I can understand that a carbon fairing can be very thin since it's not structural
BTW, alternating front and rear wheels allows them to be closer since the bars are also alternating..
Good question - I should have been more specific. Do not hang the HEDs that have a carbon fairing (thin carbon aero structure). Full carbon should be fine to hang. If one isn't sure, just squeeze the sides of the carbon wheel in the middle. If there is give, that's a fairing and not structural carbon.
