Saddle height
Quoted: 49 Post(s)
Liked 9 Times
Saddle height
I like to ride upright on commutes and tours. Mtb with smooth tires. Riser bars, tall stem.
I picked up a new old mtb with flat bars that sweep back 13-15 degrees. This bike frame is much larger than my regular bike mentioned above. The previous owner had the saddle on this flat-bar bike way above the bars. It looks much cooler that way, but for me my feet wouldn't touch the floor. Is that okay? I can stand over the top bar just fine with both feet flat on the ground.
just another gosling
Quoted: 3889 Post(s)
Liked 1,938 Times
Google "heel on pedal saddle height.". Read a few of the results, then apply.
No, it should not be possible to reach the ground with your feet while sitting on the saddle.
Results matter
Results matter
Likes For Carbonfiberboy:
Heel on pedals, Inseam x 0.883, 109% of inseam, inseam (in CM) less 10cm, 25 degree at the knee...all produce results that are within 15mm of each other for me. All of these methods are good for finding a starting point, but in the end you will need to explore a bit to find the saddle height that helps you produce the most power, keeps parts from getting numb, and (most importantly) is the most comfortable.
Don't rush the process, it takes time.
Likes For Gary in NJ:
To the OP: Think about it this way. At the bottom of the pedal stroke, your leg should have a slight bend, but the pedal is still 3in off the ground. If you were to straighten your leg the whole way your heel probably can't touch the ground, but your toes might.
Cyclists deal with this issue a variety of ways. Most simply come forward off the saddle when they stop. If you lean the bike to one side, you can put a foot down. You'll also see cyclists with a foot on the curb, which is the right height to reach while seated.
Likes For gsa103:
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
Yep, it depends on a how big your feet are and how high the bottom bracket on the bike is. I can get my toes down on my road bike, my full suspension mountain bike has a much higher bottom bracket and there's no way.
Or they do like I did when first using clipless pedals and come to a stop light, try to put their foot out without unclipping and fall over to the side.
Quoted: 1858 Post(s)
Liked 664 Times
