School me on spoke nipples
Old 07-16-19, 10:07 AM
speedy25
Bikes: Specialized, Trek, Diamondback, Schwinn, Peugeot
Quoted: 160 Post(s)
Liked 53 Times in 43 Posts
I have wheels on a bike that was transported through Ohio's salty slushy roads and never washed off in FL when the customer arrived there. That salt dissolved the stock nipples.
Spoke diameter is 2.0 mm. I see all kinds of nipples made from 3 kinds of metals. Brass, "alloy," and steel. What exactly is the alloy? Its not in the disrtibutors description.
I think I only see 2 sizes for the threads, but once again descriptions are vague. I also know that spokes are typically picked by gauge.
I'm hoping you guys can straighten me out so I can get the right ones the first time.
TIA,
-SP
speedy25 is offline
Old 07-16-19, 10:09 AM
ThermionicScott
working on my sandal tan
ThermionicScott's Avatar
Quoted: 3871 Post(s)
Liked 2,568 Times in 1,579 Posts
"Alloy" is generations-old shorthand for "aluminum alloy."
Originally Posted by chandltp
Originally Posted by noglider
RUSA #7498
ThermionicScott is offline
Old 07-16-19, 10:13 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
Brass and steel are obvious. "Alloy" means aluminum alloy and it was probably the material the ruined nipples were made of since salt corrodes aluminum badly.
Brass nipples are most commonly used and are strong and durable. Steel nipples are almost never used on decent wheels. Alluminum nipples are used to save a small amount of weight but are weaker than brass and more prone to corrosion as you have discovered. Buy brass.
A 2.0 mm spoke is also known as 14 gauge so buy matching nipples.
HillRider is offline
Likes For HillRider:
Old 07-16-19, 10:17 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
Some newer alloy is 7000 series and strong. But for Ohio, Florida...... many like brass
I can get away with alloy in So. CA.
2.0 spoke would have thread size of 2.3 I believe...... threads are rolled and larger diameter.
All you need to ask for is 2.0 spokes..... 2.0 nipples.......etc.
trailangel is offline
Old 07-16-19, 10:28 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
Quoted: 1795 Post(s)
Liked 1,271 Times in 877 Posts
2.0mm will be the far most common size.
Bill Kapaun is offline
Old 07-16-19, 10:29 AM
Retro Grouch
Retro Grouch's Avatar
Quoted: 1572 Post(s)
Liked 643 Times in 364 Posts
One of my pet peeves but I assume that you're right. If they were iron alloy they would probably call them steel.
Retro Grouch is offline
Old 07-16-19, 10:30 AM
DiabloScott
It's MY mountain
DiabloScott's Avatar
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times in 1,617 Posts
Aluminum nipples are fine and nice if you're building lightweight wheels that won't see corrosive wet service.
Brass will last much longer if you ride in the rain or slop.
As to your case, if the nipples are that far gone, there's a good chance your spoke threads and maybe the rims are also compromised... at least inspect the threads after you take off a few nipples, and inspect the grommets in the rim spoke holes before you decide to rebuild; might make sense to get new wheels.
DiabloScott is offline
Likes For DiabloScott:
Old 07-16-19, 12:55 PM
Metaluna
Bikes: Niner RLT 9 RDO, Gunnar Sport, Soma Saga, Workswell WCBR-146
Quoted: 114 Post(s)
Liked 19 Times in 19 Posts
Yeah but if you call them "aluminum alloy" someone else is probably going to be peeved that you didn't spell it "aluminium" or vice versa, and you're going to get groused at by someone sooner or later. So there's no winning on this one, either way
Metaluna is offline
Old 07-17-19, 12:00 PM
Drew Eckhardt
Drew Eckhardt's Avatar
Quoted: 550 Post(s)
Liked 325 Times in 226 Posts
You can get away with alloy in Colorado provided you have the foresight to lubricate spoke threads and sockets with zinc anti-seize or at least grease and don't use them to extend spokes which are too short.
Don't address galvanic corrosion and you can have seized nipples even in the San Francisco Bay Area.
Drew Eckhardt is offline
Old 07-17-19, 12:39 PM
Koyote
Quoted: 6972 Post(s)
Liked 10,971 Times in 4,692 Posts
If the nipples are all corroded to hell, it's a safe bet that the hubs and/or rims have problems, too. Inspect carefully before replacing the nipples.
Koyote is offline
Likes For Koyote:
Old 07-17-19, 03:39 PM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 6221 Post(s)
Liked 4,221 Times in 2,367 Posts
Realistically, almost all metals used are "alloys". Even iron in all but the purest of forms is an alloy. The process of reducing iron oxide (ore which is really just rust) to "iron" leaves behind a small amount of carbon. That's what makes the difference between "iron" and "steel". But every other metal we commonly use is an alloy.
But the problem here is that we don't have a common name an aluminum alloy like we do for iron and carbon mixtures other then to call it "alloy". It's not really proper to call it "aluminum" either. It's a mixture of elements. It's just a short hand and shouldn't really bother you.
If you really want to be bothered check out the meaning of the word "salt". Hint: it's not just sodium ions and chlorine ions that form "salt".
Or the difference between a "balance" and a "scale". One measures mass and can be used anywhere in the Universe. The other measures weight and is only valid on the surface of Earth.
Or the difference between weight and mass.
Stuart Black
cyccommute is offline
Old 07-17-19, 04:07 PM
HTupolev
Quoted: 1979 Post(s)
Liked 1,298 Times in 630 Posts
Depends on the conversation. In a culinary context, "salt" generally means an edible substance consisting almost entirely of sodium chloride. In a chemistry context, salts are a much broader category.
A similar situation exists for, say, "ice." In most circumstances it refers to frozen water, but if an astronomer tells you about "ices" on the surface of some distant moon, you should check what it's actually composed of before you try to make snow cones out of the stuff.
HTupolev is offline
Old 07-17-19, 04:27 PM
Metaluna
Quoted: 114 Post(s)
I believe "concrete" actually refers to any substance that has aggregates held together by some kind of binder. What we commonly think of as concrete is actually portland cement mixed with sand, gravel, etc. Asphalt (aka tar macadam) is another kind of concrete. Or so I've read anyway.
Ketchup is actually a generic style of sauce preparation and can be made with lots of stuff besides tomatoes (strawberries, bananas, even oysters). Same for salsa, relish, etc.
Metaluna is offline
Old 07-17-19, 05:15 PM
alcjphil
alcjphil's Avatar
Quoted: 1821 Post(s)
Liked 1,696 Times in 976 Posts
TIA,
-SP
Generally speaking, unless you are willing to donate the labour and material needed to replace all of the nipples of that wheel, it may well be more cost effective to buy a new replacement wheel
alcjphil is offline
Old 07-17-19, 05:59 PM
DOS
DOS's Avatar
Quoted: 253 Post(s)
Liked 69 Times in 56 Posts
Originally Posted by HillRider
. Buy brass.
This ^
DOS is offline
Old 07-20-19, 07:46 AM
mynewnchome
Bikes: Cannondale CAAD8 Raleigh Revenio 1.0
Quoted: 70 Post(s)
Liked 30 Times in 13 Posts
TIA,
-SP
Definition:
A metal that is made by mixing two or more metals, or a metal and anothersubstance:
Brass is an alloy of copper and zinc.
mynewnchome is offline
Old 07-20-19, 08:25 AM
cyccommute
cyccommute's Avatar
Originally Posted by mynewnchome
Definition:
A better definition would be that an alloy is a solid, ****geneous mixture of metals. It’s a solid solution.
Just a note on brass vs aluminum: Both are susceptible to corrosion by the salts (sodium and magnesium) used for ice melting. Aluminum is more reactive but both will corrode.
Stuart Black
Old 07-21-19, 07:37 AM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3590 Post(s)
Liked 3,401 Times in 1,935 Posts
Steel nipples offer no advantage.
Use aluminum nipples only if your weight-weenie tendencies are enough to outweigh the inevitable problems.
Brass has no disadvantage beyond being slightly heavier than aluminum.
JohnDThompson is offline
Old 07-21-19, 02:05 PM
Arthur Peabody
Quoted: 250 Post(s)
Liked 110 Times in 66 Posts
The brass for nipples is an alloy of copper & zinc? Brass generically is thousands of alloys of copper + zinc + /tin/lead/iron/alumin(i)um . When we finally got wise to lead states limited the lead content of brass for plumbing or other uses that end up in our stomachs.
Brass disinfects itself through the oligodynamic effect: bacteria and fungus that land on it die eventually (about an hour for untarnished brass, as long as 7 for tarnished brass). Shower heads harbor bacteria, as a microbiologist found when he sent all his students home for Christmas break with kits to collect what was on them there. (https://scienceblog.com/25118/daily-...boulder-study/ ) I switched to a raw brass shower head. Copper's even better (silver better yet); some organizations provide copper water vessels to people who live in poor areas, fetch their drinking water and store it at home. Copper's too soft for plumbing fixtures, though I did see a copper spigot in the kitchen at Monet's home in Giverny - worth a trip if you're in Paris. There's a commuter train to Vernon; it's a mile walk to Giverny.
Arthur Peabody is offline
Old 07-21-19, 02:12 PM
79pmooney
79pmooney's Avatar
Quoted: 4806 Post(s)
Liked 3,932 Times in 2,557 Posts
Bring one of the spokes to the shop and try on the nipples. Not all threads are alike. You didn't say how old this bike is but the old French and Japanese spokes used different threading.
Ben
79pmooney is offline
Old 07-21-19, 04:22 PM
JohnDThompson
Old fart
Modern spoke threads have pretty much standardized at 56tpi, but still must match the spoke gauge. Older spokes may use different thread.
Source: Sutherland's 4th Edition
Old 07-22-19, 02:45 PM
Last ride 76
1/2 as far in 2x the time
Last ride 76's Avatar
Bikes: Yes, Please.
Quoted: 499 Post(s)
Liked 285 Times in 222 Posts
Generations, you had to say it.
Jeezus, I'm squinting at the screen cause I just ran in from the thunder shower, and my reading glasses are all steamed up... for this? I'm gonna go back out and hold my Vitus 979 forks over my head
Last ride 76 is offline
Old 07-23-19, 10:29 AM
Wilfred Laurier
Señor Member
Wilfred Laurier's Avatar
Quoted: 649 Post(s)
Liked 293 Times in 216 Posts
Please keep the disrespectful remarks about the LGBT community out of your responses!
Wilfred Laurier is offline
Old 07-23-19, 11:02 AM
speedy25
Quoted: 160 Post(s)
Its hilarious how a thread can get so many odd replies as well as correct info. I am appreciative of all who participated.
Take it to the shop?? I AM THE SHOP!!
There are so many strange alloys out there, with the scariest being low quality zinc mixes. They should just say ALUMINUM, instead of alloy. I just had to make sure what I suspected was correct.
The salt appears to have only attacked the nipples. I can unscrew whats left by hand easily.
Time to order parts and get to work on this job too.
-SP
speedy25 is offline
_ForceD_
Bicycle Mechanics
8
11-17-16 02:56 PM
damo010
Touring
21
12-24-15 08:51 AM
Shamrock
Fifty Plus (50+)
19
07-02-14 06:30 PM
jan nikolajsen
Classic & Vintage
34
01-29-12 07:50 PM
BikeToWork
Bicycle Mechanics
27
04-09-11 06:36 PM
