Stuck square taper crank - can't remove using crank puller.
Hi
I'm trying to remove my crank and it just won't budge. I'm worried about doing damage to the bike. Is there anything I can do to loosen it up - lubrication points? WD-40 etc? I have the right tool as far as I know.
Cheers.
Cheers.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,218 Times
Well at least you removed the bolt. A more common mistake than you’d think
Get some PB Blaster or Kroil and allow it to sit overnight. Some say that Kroil works better. Then try again. You might need a cheater bar.
Stuart Black
Stuart Black
Likes For cyccommute:
Quoted: 4806 Post(s)
Liked 3,928 Times
Take your remover out and make dead sure that when you replace it, the "plunger" of the tool is hitting the end of the spindle and nothing else; that any washer in there has been removed. If the tool is contacting the crank instead of the spindle, you are just doing your best to destroy the crank. It that is all good and the crank is still stuck, hang around. I am sure there are tricks using penetrating oils, temperature changes, etc. I'm not that source.
Likes For 79pmooney:
Really Old Senior Member
You've got a stuck crank. Do you want to screw around with a substitute for penetrating oil?
Lean the bike on its side and load that baby up with Kroil or PB Blaster.
Let it soak. After awhile, take a box end wrench or similar and tap the area. You want to "ring" it so the vibrations/capillary action helps get the oil into the tiniest places. No mashing.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
After you have applied Kroil or PB Blaster a suggested, when you get the crank remover as tight as you dare, hit the end of the puller a sharp blow with a hand sledge, in line with the puller axis. This shock may get the taper to release.
Likes For dsbrantjr:
Likes For flyagaricus:
Bikes: lots
Liked 2,932 Times
Huh...well, it's not ...not like proper penetrating oils. Get some of you'll be trying to get that thing off for a week.
Cheers.
Bikes: jamis 2002 komodo, univega aplina uno, miele toscana 300, 1972 puch brigadier, Marin Sausalito
Quoted: 18 Post(s)
Liked 17 Times
back in the day i did a lot of motorcycle work. to get a stuck magneto rotor off a tapered crank, we would put a load on the puller tool and give the the end of the tool a wrap with a hammer.
Likes For dr1445:
SE Wis
Quoted: 2746 Post(s)
Liked 3,391 Times
Yrep, small engine flywheels too. Pound a couple wood wedges under it, run the nut to the top of the crank, a tap on the crank and pop.
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
After you remove the bolt, you start riding, but gently. At the moment you sense that the crank starts to loosen, you stop and walk the bike back. It works 100% of time. Yes, you always hear advice never to do it warning of a damage. If you do it gently the damage occurs in 0% of cases.
Likes For 2_i:
Quoted: 206 Post(s)
Liked 460 Times
Just take it for a spin around the block. Stay sitting down. If that doesn't budge it, maybe take it up a slight incline. It'll come off eventually.
Likes For krakhaus:
Droid on a mission
Quoted: 317 Post(s)
Liked 280 Times
If all else fails there is always the Jacob wedges or a ball joint pickle fork, just use them carefully as to not damage the frame
Likes For JoeTBM:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Came across such a crank yesterday. Reluctant to put too much muscle on the remover and risk stripping out the threads in the crankarm, I kept that tension on it and did a few taps on the remover with a hammer, some heat from a propane torch, a few more taps with some energy behind them, and it came loose. The other side did the same thing so got the same treatment.
Quoted: 836 Post(s)
Liked 1,061 Times
Likes For Pop N Wood:
Quoted: 6193 Post(s)
Liked 4,809 Times
Does the ram end of the puller fit in the square hole of the crank? Hard to tell. Probably does but maybe not.
If not, then you are pushing against the crank and not the shaft. That won't work.
Quoted: 1609 Post(s)
Liked 2,590 Times
It almost looks like its traveling down on the threads. Find a small bolt that drops in with out contacting the threads but still fits inside the square taper. Then try your puller.
Half way there
Quoted: 986 Post(s)
Liked 880 Times
Triflow's thin enough so it may work. Heat up the crank a bit with a hair dryer or heat gun to improve penetration. Have patience and resist the urge to use a cheater bar (unless it's only a foot long).
Likes For Moe Zhoost:
Yup - had the TriFlow on it over night, then gave 'er. Crank is off. Maybe I just need a night's rest too.
Now that I saw it your way, it's hard to un-see it. haha.
