New Rivendell/Nitto Lugged Quill Stem - 87.5mm
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
New Rivendell/Nitto Lugged Quill Stem - 90mm
SOLD覧覧覧覧覧
Brand new, never used lugged cro-mo Nitto stem from Rivendell in 90mm length.
Minimum insertion to cl of bar approx 110mm, so this allows for much flexibility with bar height.
Gorgeous lugged cro-mo construction and satin finish.
$210 plus $10 flat rate shipping
Quoted: 4806 Post(s)
Liked 3,928 Times
That looks like their lugged seatpost. I've got that post on my Mooney. It's gorgeous, very well made, very well thought out and a joy to install and adjust. (And a very healthy setback; my reason for the purchase.) The post might outlive the Mooney. (I won't live long enough to see either die of natural causes.)
The mega ultra stem. The lugs are way cool, but somehow it's the centered "fin" on the top of the bar clamp section that just kills me. And you do have more horizontally upward adjustability than most stems.
Is the 87.5mm an actual measurement you took, or are you extrapolating from the (0.875) stamped on the stem? Because the (0.875) stamped in the stem is telling us that the 22.2mm diameter is 0.875 inches. It's not connected to the extension length.
This stem is made in 90/100/110/120mm extensions, and I'm thinking by the looks of this it's a 90mm? Which is very close to 87.5mm, so that might have been what you measured, and the 0.875 engraving might just be a cowinky-dink.
I try not to overthink this stuff, but there are things my brain forces me to do..........
Fuggedaboutit!
Fuggedaboutit!
Oh, sorry, "cowinky-dinky" is dumb old man humor for "coincidence." Can't remember where it came from, either some stupid cartoon or some stupid tv show that burrowed into my brain back when I was a yout. Sometimes shortened to cowinky-dink. Or maybe that last "y" isn't supposed to be there, and I just stuck it in. Hmmm....
Fuggedaboutit!
Fuggedaboutit!
Quoted: 174 Post(s)
Liked 157 Times
Sold
The stem has sold.
