How about a toe clip swap thread?
Bikes: many
Quoted: 1444 Post(s)
Liked 1,392 Times
i find myself with a bunch of toe clips that are too short. Most of what I have are in the 50-55mm depth range. I put together a Flickr album of what I have. The pix there show how I measured them. In theory, I'd be open to selling one or more if you have nothing to trade. Still, I'd prefer to just trade if possible.
Here's what I have:
Here's what I have:
- Christophe - 55mm
- Christophe - 55mm
- Campagnolo - 55-60mm
- Cycle Pro - 75-80mm
- Christophe - 50mm
- Christophe D - 50mm
- Cycle Pro - 55mm
Last edited by smontanaro; 04-10-21 at 12:53 PM. Reason: Replaced Christophe Special with Cycle Pro
Quoted: 1829 Post(s)
Liked 3,376 Times
By chance, I've been sorting through my stock of toe clips too. I wear size 46 shoes, and gravitate towards the Christophe Specials, as the clip extends about 65mm forward of the pedal cage...
Is there any standard way of measuring or quantifying toe clip size?
I'm amazed at how much variation that I find in my various large or extra-large clips.
I've got some Minoura alloy clips marked "LL" that have an extension of only 52mm....
Steve in Peoria
(planning to post some of my extra clips on CR list someday)
Steve in Peoria
Bikes: many
Liked 1,392 Times
I don't think so. I think that flange-to-tip measurement is the closest you'll get to a reproducible measurement. I can't explain your "large" 50mm clips.
Liked 3,376 Times
Likes For steelbikeguy:
Disraeli Gears
Who would want the ones under 60 mm? Mine are 62 mm per your measuring technique and I have rather short (though wide) feet: 9-1/2 US, 42.5 Euro. Possibly the style (how pointed the toes) of one's preferred cycling shoe comes into play, but still . . .
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,700 Times
I've got a couple of Large cage sets that are too big for me- an old Avocet and a new-ish MKS wire cage.
If anyone's got a set medium MKS or King cage that are too small...
Commence to jigglin’ huh?!?!
Bikes: many
Liked 1,392 Times
I decided a pair of Cycle Pro clips I was using was simply too big, even for me. I replaced it this morning with the 65mm Christophe Special from my original list and added it in.
Bikes: many
Liked 1,392 Times
Likes For smontanaro:
Likes For mgermca:
Quoted: 4806 Post(s)
Liked 3,928 Times
Two reasons for shorter clips (assuming they fit your shoes/cleats). Tire/fender clearance and do they don't get crunched and shortened by the road when you pedal hard at a startup. (Car's coming. I think I'm not going to do this pretty.) I do a lot of fix gear riding with fenders. Have large feet and like my cleats back. I experience those issues a fair amount.
Bikes: many
Liked 1,392 Times
A post on the what came for you thread by non-fixie made me aware that Christophe toe clips are still in production. This surprised me a bit, so I began poking around. I discovered some sizing charts:
With several modern manufacturers/resellers, perhaps a toe clip swap isn't really necessary, and toe clips which don't fit belong in the Box O' Crap.
- Zefal/Christophe
- MKS (and a broader selection here)
- Velo-Orange
Shifting is fun!
Bikes: Yes, please.
Quoted: 2198 Post(s)
Liked 4,601 Times
This is what you get when you order new Christophe clips. I paid about €10 a pair, got them from a German supplier:
I ordered the L/XL version, and I'd say they are indeed 70mm. Should be comfy!
feros ferio
Quoted: 1393 Post(s)
Liked 1,325 Times
I am pleased to see other BFers who still use toeclips and straps, as I have for more than 50 years now.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
The DynaDrive pedals used the same three-bolt mounting pattern as later Dura-Ace, 600, and Deore pedals. Unfortunately, that pattern was proprietary to Shimano and only in production for a few years, before clipless took over the market. The 600 and Dura-Ace versions were chromed steel; the Deore version was plastic, quite light but with a tendency to break. You can find them fairly often on eBay, sometimes for outrageous prices, especially the steel versions. Be aware that although some forward and back adjustment is possible with these clips, the sizes tend to run pretty small. I found that a "medium" size clip had to be set at maximum extension to fit my size 41 shoes, and even then jammed a bit on the end of the shoe. It's safest to err on the larger size if you're not sure what size you need.
Quoted: 637 Post(s)
Liked 1,285 Times
Still have the Cycle Pro set?
Liked 1,700 Times
The Golden Boy would you be interested in selling the large MKS wire cage set? I've been looking for a pair and they appear to be sold out everywhere. Darn Suez Canal...
Shoot me a PM!
MKS Wire Toe Clips by Dave The Golden Boy, on Flickr
Only marked with MKS and JAPAN
Compared to the MKS Medium
Likes For The Golden Boy:
