Home repair stand - D-shaped Carbon Seatpost
Canadian eh?
Bikes: 2020 Specialized Roubaix Expert
Quoted: 131 Post(s)
Liked 96 Times
Hi There,
For basic home repairs, would I be best to use a Euro style stand (like the Feedback Sports Sprint) that holds the axle, or would a more traditional style clamp mount do?
Thanks!
Edit
Thanks!
Edit
Quoted: 608 Post(s)
Liked 352 Times
For the bike you have now, the Sprint is a great choice. Park Tool also make a version. The other option though ends up costing more is to by a traditional stand and the purchase the Hirobel from Silca. That way you can leave the front wheel on the bike which is useful when doing front brake work. You never want to clamp a carbon frame. Another option is the Pro Elite style and hang the bike from the saddle but it is very stable that way.
I own the Sprint for my carbon bike and the Pro Elite for my custom steel bike and a heavier duty Cinelli stand for my Rivendell (The Pro Elite doesn't handle bikes in the 30 pound rage very well.)
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
I don't see a problem using a traditional stand with a seatpost clamp, just don't over tighten it.
The worst that can happen is you damage the seatpost which is better than the frame.
Clark W. Griswold
Quoted: 4355 Post(s)
Liked 3,994 Times
Seatposts are designed to be clamped.
Quoted: 608 Post(s)
Liked 352 Times
I have never looked at that way but it makes perfect sense, thanks for pointing that out. I don't know how well the Pro Elite clamping system works on D shaped posts like the OP has, do you have experience with this you can share?
Likes For blakcloud:
Quoted: 766 Post(s)
Liked 1,739 Times
I use the same Hirobel others have mentioned on my Trek Domane carbo bike. On my work stand I would normally clamp to the top tube before I had a carbon bike.
I have a Jamis Renegade steel gravel bike that has a carbon seat post. I just had that seat post fracture while riding, after under 2k miles of riding. Jamis replaced it for free, and I had never clamped onto it or exceeded the torque spec on the seat post clamp, but I definitely recommend not assuming weakening a carbon seat post is not a big deal!
Quoted: 6193 Post(s)
Liked 4,809 Times
You've been around here since 2002 and still haven't realized the issue with double posting?
Quoted: 1814 Post(s)
Liked 923 Times
90% of the time I just hang the saddle nose over the stand's clamp arm.
The other 10%, I clamp the seat tube, which has the seatpost inside it which, we hear, is designed to be clamped.
If I had a D shaped seatpost, would likely do the same.
I have a Feedback stand and clamp my wife's Liv Brava with a D-shaped post all the time.
Clark W. Griswold
Liked 3,994 Times
I don't have any real experience with Feedback stands but I have put D-shaped posts in Park Stands with no real issue. A lot of people are scared of their seatposts but you have it clamped in the frame all the time so if you are going to clamp somewhere that is the place but if you do have an odd shaped post you may need some sort of adapter for that stand.
Likes For veganbikes:
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
I ended up getting the Park PCS 10.2. So far so good and I am able to fully control how tight the clamp is around the D-shaped seatpost!
Likes For WorldIRC:
Method to My Madness
Bikes: Trek FX 2, Cannondale Synapse, Cannondale CAAD4, Santa Cruz Stigmata GRX
Quoted: 1948 Post(s)
Liked 1,469 Times
This is what I do too. Although I wouldn't attempt any high torque load work like bottom bracket removal -- not that I have the skills or tools to do so.
Obsessed with Eddington
Bikes: '16 Spesh Diverge, '14 Spesh Fatboy, '18 Spesh Epic, '18 Spesh SL6, '21 Spesh SL7, '21 Spesh Diverge...and maybe n+1?
Quoted: 532 Post(s)
Liked 621 Times
I clamp the d-shaped posts on my SL6 and SL7, I've done BB work on both while hanging from the stand. No issues. Carbon posts are strong. As stated above, they are designed to be clamped.
Likes For Badger6:
Liked 1,469 Times
Both my LBS (pre-pandemic) and I (nowadays) clamp my carbon fiber seat post for maintenance, and so far (touch wood) no issues. Like many said above, seat posts are designed to be clamped. To add to that, the seat post clamp that holds up your seat post has a smaller clamping surface area and higher clamping force than what you would use on the work stand.
Likes For SoSmellyAir:
The Sprint Stand works great. We have one that we take for travel.
That, or Silca has a nifty gadget that would work well too and may be the smart way to go about it anyhow.
https://silca.cc/collections/hirobel.../hirobel-clamp
I use the Park 10.2 and it worked fine for my recent BB removal. For a precaution I had my wife hold the frame while I hammered out the pressfit but it seemed unnecessary.
Likes For RandomDesign:
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
https://www.bmc-switzerland.com/intl_en/carbon-care
BMC actually recommends clamping by the seatpost! That solves that
Likes For ARPRINCE:
Liked 1,469 Times
Good to know. Perhaps this is stating the obvious, but asking my wife to hold my bike defeats the purpose of owning a work stand. Also, a work stand never questions why I am working on my bike again when "it seems fine."
Canadian eh?
Quoted: 131 Post(s)
Liked 96 Times
Bumping this back up. I ended up with the Hirobel in addition to my Park repair stand. Working great so far!
