When the best chain lube is none!
Tortoise Wins by a Hare!
Quoted: 1549 Post(s)
Liked 941 Times
This chain was degreased and "installed" 6 months ago. It has never been lubed. Performance has not suffered one bit, in fact, I believe it looks better now! *
*Disclaimer: Do not attempt on running bikes.
Likes For AlmostTrick:
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 336 Times
How did you attach the chain to the post? Did you drill small holes for the nails? The chain's steel must be quite hard. Otherwise very cool!
Likes For 2_i:
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
You won't shift right with a chain like that. Someone might skip over your house because you are running an 8 speed chain on a 339 speed house.
Likes For veganbikes:
Quoted: 1943 Post(s)
Liked 2,164 Times
I like that. I recently replaced the house numbers on our facia.
But I’m not sure the boss would have approved of using my old bike chain.
But... “I’ve gotta go ride. Only a thousand more miles and I’ll be done.”
John
John
Liked 941 Times
Nail through a couple links with the pin pushed out. I also had to go through each link and "tighten" it with the breaker tool so chain would hold shape.
Likes For dsbrantjr:
Quoted: 6178 Post(s)
Liked 4,795 Times
You should wax it. And how do you expect to be able to check it for wear? <grin>
