Converting MTB to Touring...shifter problems!
Old 06-28-19, 08:28 PM
Flyboy718
Bikes: 1986 Univega Gran Rally 1993 Univega Gran Premio 1995 Univega Alpina 501 Univega Nuovo Sport Univega Viva Sport
Quoted: 36 Post(s)
Liked 3 Times in 2 Posts
So basically the only option I have for shifters are bar end shifters? I have changed out the original MTB handlebar and installed a vintage roadbike drop bar. My MTB had grip shifters on it but they don't fit on the roadbike bar. Any other options other than the barend shifters. I have heard of hubbubs but I don't want to go that route.
Flyboy718 is offline
Old 06-28-19, 08:52 PM
katsup
katsup's Avatar
Bikes: 1995 ParkPre Pro 825 2021 Soma Fog Cutter v2 and 2021 Cotic SolarisMax
Quoted: 607 Post(s)
Liked 560 Times in 318 Posts
What is the mountain bike? How many speeds?
I've used Microshift STI shifters with my 3x7 mountain bikes before and they worked well.
katsup is offline
Old 06-28-19, 09:39 PM
Flyboy718
Quoted: 36 Post(s)
It's a Univega Alpina 501. It's 3x7. What is the cheaper route? Thanks!
Old 06-28-19, 10:02 PM
Cycle Tourist
Quoted: 195 Post(s)
Liked 207 Times in 126 Posts
There are some Chinese made brake lever shifters at around $47. The barends cost about the same. You can find a cheaper set every once in awhile. I've got a set of Suntour bar ends. What freewheel or cassette have you?
Cycle Tourist is offline
Old 06-28-19, 10:05 PM
Flyboy718
Quoted: 36 Post(s)
Can you show me a link to a place to get them for that price? I am confused as to which I need. I see a lot of 8 and 9 speed index shifting but I see 7 speed friction shifting bar end. What do I need? I have a 3x7.
Old 06-28-19, 10:09 PM
Cycle Tourist
Quoted: 195 Post(s)
I use eBay a lot. Search "Microshift" or micronew.
Old 06-28-19, 10:27 PM
Flyboy718
Quoted: 36 Post(s)
I found some bar end shifters on Amazon and it says that they will work with friction or index. They are 8 speed though, will that work with a 3x7 drivetrain?
Old 06-28-19, 10:38 PM
Cycle Tourist
Quoted: 195 Post(s)
Not sure. I think they have the same spacing and you'll just have a click you won't use. There was a thread recently about that but I'm not positive.
Old 06-28-19, 11:32 PM
Pompiere
Pompiere's Avatar
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 523 Post(s)
Liked 968 Times in 507 Posts
There is a slight difference between 7 speed and 8 speed, but if you adjust so the middle cog is perfect, the inner and outer cogs will shift okay. I put 8 speed brifters on my son's bike with a 7 speed hub with no issues. There is an extra click on the shifter, but the derailleur limit screw prevents you from reaching it. I have also used 7 speed indexed shifters on an 8 speed hub by adjusting the derailleur limit screw to lock out the 11 tooth cog. With a 53 tooth chain wheel, it wasn't going to get much use anyhow.
Pompiere is offline
Old 06-28-19, 11:59 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1560 Post(s)
Liked 1,282 Times in 853 Posts
What model of SRAM rear derailer?
ESP (i.e. 1:1) series derailers will not work with any Shimano or "clone" shifter.
Not all 7s SRAM rear derailers are Shimano-compatible, some are.
But, you could get a good, used Shimano rear derailer for very little money, to work with most road shifters of the same number of speeds.
Does Dallas have a convenient bike co-op where you can buy parts for next to nothing?
Visually check any used derailer that you consider buying (look for the flat end of the mounting bolt to be parallel with the "cage" that holds the two pulleys). Don't buy a bent derailer!
I wouldn't kluge together 7s and 8s Shifters, derailers and freewheels. It adversely affects shifting performance, and most definitely affects how long of a service interval that the adjustments will last. In some cases (using STI shifters), a setup with a "locked-out" 8th gear position results in an inadvertant over-tensioning of the cable, with the shifter then stuck (mechanically locked-up) in the "beyond-lowest" gear position until cable tension can be manually relieved. Not good for the cable, or for the shifter!
"Finicky" 7s shifters/derailers are a big part of why SunTour went out of business, and you don't want anything to do with that. Stick with compatible components!
dddd is offline
Old 06-29-19, 04:24 AM
randyjawa
randyjawa's Avatar
Quoted: 1372 Post(s)
Liked 1,747 Times in 937 Posts
I am going through this same search right now, seeking a set of these Suntour Barcons, the same kind that I use on my Bianchi in Jamaica. A few people on the for sale forum have already offeredd sets and I am in offering stage right now with one seller. So, check there first, then Ebay (good luck right now, nothing there for my interest or yours). You will get lucky and, who knows, even for a good price. I should add that a set of trigger shifters will also get the job done assuming that you can get them around the drop curves.
My favorite indexed Barcon...
randyjawa is offline
Old 06-29-19, 06:05 AM
Classtime
Classtime's Avatar
Quoted: 1946 Post(s)
Liked 2,004 Times in 1,105 Posts
Just maybe your new tourer would be perfectly happy with bars that fit the shifters? I know they are not drop bars, but Soma Oxfords get me pretty aero with multiple hand positions and fit MTB levers and shifters.
Classtime is offline
Old 06-29-19, 07:51 AM
dgodave
Behold my avatar:
dgodave's Avatar
Bikes: 2019 Gorilla Monsoon, 2013 Surly Krampus, Brompton folder
Quoted: 6941 Post(s)
Liked 444 Times in 289 Posts
Love them. But its a totally different position than drop bars. You can compensate somewhat with stem length. Plus, some older MTBs have such long top tubes that drop bars would feel too stretched-out.
dgodave is offline
Old 06-29-19, 08:37 AM
Flyboy718
Quoted: 36 Post(s)
My rear derailer is Shimano STX
It slipped my mind that this is totally another option! I am not married to drop bars and I agree that its seems to make me a little streteched out so what other options of handlebars are good that will fit MTB grip shifters and brakes other than the Soma Oxford?
Old 06-29-19, 08:46 AM
bargainguy
bargainguy's Avatar
Quoted: 516 Post(s)
Liked 303 Times in 187 Posts
https://tribebicycles.com/products/drop-bars
Tribe makes a 22.2 mm drop bar with a 25.4 mm stem diameter. This lets you run MTB shifters and brake levers on a drop bar with 25.4mm stem compatibility. Not sure if this is the type of bar you're looking for, but it's an option.
bargainguy is offline
Old 06-29-19, 08:47 AM
wesmamyke
Quoted: 196 Post(s)
Liked 86 Times in 76 Posts
Soma Sparrow bar takes mountain bike controls, or bar end shifters as it's drilled out for those too. I run one flipped over as a sorta drop bar. Comes in different widths as well.
wesmamyke is offline
Likes For wesmamyke:
Old 06-29-19, 08:56 AM
Flyboy718
Quoted: 36 Post(s)
My original stem is 22.2 mm (1" quill) type stem. Will this bar just slide into my original stem or do I need to look for another stem?
Old 06-29-19, 09:01 AM
bargainguy
bargainguy's Avatar
Quoted: 516 Post(s)
Yup, that's the idea, you can run your original stem. Just replace the bars, remount your original MTB components, and you're good to go. All for a $20 set of bars - not bad.
Old 06-29-19, 09:03 AM
Flyboy718
Quoted: 36 Post(s)
Damn! That's what I need! Although I do like the look of the trekking bars. Thanks!
Old 06-29-19, 11:02 AM
Korina
Happy banana slug
Korina's Avatar
Quoted: 1530 Post(s)
Liked 1,527 Times in 915 Posts
My vintage mtb. is wearing some north road bars, and they feel great! Got my ratcheting thumbies, and all is good.
Korina is offline
Old 06-29-19, 11:35 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Hubbub adapters... you can put your grip shifter on the end of the (drop) handle bar extension, on those..
you can put the grip shifter vertically on that 22.2 mm quill shaft, others have done that..
I have trekking bars on one bike , Rohloff Gripshifter.. it has 26" MTB wheels..
fietsbob is offline
Old 06-30-19, 07:17 AM
Classtime
Classtime's Avatar
The 22.2 refers to the part that fits in the fork steerer tube. The 25.4 refers to the clamp and handlebar diameter.
Likes For Classtime:
Old 07-03-19, 09:06 AM
Flyboy718
Quoted: 36 Post(s)
Then you just use road bike brake handles instead of the original MTB? I would like to see a picture of those shifters mounted vertically.
Old 07-03-19, 09:21 AM
fietsbob
Bikes: 8
NO you continue to use the MTB levers .. the sides of trekking bar's bends
can offer a hand hold somewhat like the ramps behind the brake lever on road bars..
want drop bars ? go for it , no hand holding.. see if it works... by trying it.
Self Discovery.. Go..
Nitto JP has extra long quill stems for 1" & 26mm bar centers..
fietsbob is offline
Old 07-03-19, 09:22 AM
Flyboy718
Quoted: 36 Post(s)
Unfortunately, these people seem to not be in business anymore. The "cart" is disabled and the phone number is disconnected.
