New Budget Hardtail vs used High End Hardtail?
Old 08-21-19, 02:22 PM
jrhoneOC
Bikes: 2021 Specialized Chisel
Quoted: 64 Post(s)
Liked 58 Times in 40 Posts
OK...I'm SURE this has been addressed, but I am looking at all my options. I'm 50 and haven't ridden a MTB in 20 years. My last bike was a '96 Rockhopper Comp FS. Loved it. Plan on doing some general riding, some trails, some single tracks. Nothing too crazy. My first thought was to go down to Specialized and buy the current Rockhopper Expert or Comp and be done with it. Then I thought, what about if I bought a used bike thats a few years old but a higher level bike? Then to confuse things...what about a used low end bike for a few hundred, and then spend a few hundred on mods? So the 3 options...
1. $800 for a new mid level bike.
2. $600-900 on a used high end bike.
3. $300 on a used mid level bike and then spend $400 on mods and upgrades.
Option 1...Looking at Rockhopper...What else should I be looking at? 1X vs 2X drivetrain? Other brands and models? Giant? Trek? Cannondale?
Option 2...Used Crave? Used Giant XTC Carbon? Used Rockhopper Expert or other brand equivalents?
Option 3...Used Rockhopper or other brand equivalents (2014-2015ish?) and then upgrade drivetrain, brakes, maybe wheels and fork.
Would an old guy like me really benefit or notice some things like the 1x vs 2x drivetrain? I have read hydraulic brakes vs mechanical brakes is a must. In the past it was common knowledge to stay away from the low end components, weight and functionality were not great. Still the same? Tubeless?
jrhoneOC is offline
Old 08-21-19, 10:31 PM
niknak
Quoted: 120 Post(s)
Liked 43 Times in 35 Posts
Look for a bike with the following:
1. dropper post
2. tubeless compatible rims (get nice tubeless tires)
3. hydro brakes (if you go used avoid Avids)
4. rear derailleur with a clutch (1x or 2x not as important)
I wouldn't want to spend money on a mountain bike that didn't have these components. Others may disagree. I would also look for a slightly used better bike than buy a cheap bike and add upgrades. That'll cost more down the road.
niknak is offline
Old 08-22-19, 07:02 AM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
Liked 70 Times in 63 Posts
how are you with bike maintenance?
Consider year end deals at your LBS
qclabrat is offline
Old 08-22-19, 08:21 AM
freeranger
freeranger's Avatar
Quoted: 426 Post(s)
Liked 699 Times in 436 Posts
I"m still riding my '96 GT (with upgrades) hardtail on the trails, and it sounds to me like you're riding the same type of trails (not too technical) as I. If it was me, I'd look for a good condition mtn.bike with a good frame and wheels, minimum of 2x8, 1x9, or more (and if a late model would probably be more than an 8 spd.cassette anyway). I'm still using v-brakes with no problem, tho sure wouldn't mind having disks. If you're OK with working on your own bike, replacing parts, making adjustments-you can end up with a very nice bike without spending a lot. And you heard right about staying away from lower end components-but usually it's derailleurs and shifters, which are not super expensive and are easily replaced.
freeranger is offline
Old 08-22-19, 10:16 PM
Canker
Quoted: 330 Post(s)
Liked 209 Times in 133 Posts
5. Tapered headtube
If you are looking at older used or new/newer cheaper bikes a lot will have straight steerer tubes which will greatly hinder your ability to upgrade to a new better fork.
Canker is offline
Old 08-22-19, 10:31 PM
Sidewalk
I ride all the bikes
Bikes: Super6 Evo, Enduro, F-Si, and a few others.
Quoted: 9 Post(s)
Liked 2 Times in 1 Post
I would recommend finding something using modern standards. No 26", 142 or 148 rear axle. Tapered head tube, etc. If you don't go with modern standards it may be more expense to repair or update than it is worth. So an older low cost bike might not be a deal.
Buying a cheap used bike, beating on it for a few, then dumping it isn't a bad idea. It gives you some time to decide what kind of mountain biking you actually want to do.
MTB is my primary sport.
Sidewalk is offline
Old 08-23-19, 06:15 AM
JonathanGennick
JonathanGennick's Avatar
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times in 37 Posts
Avoid this ^^^ option. Spend more up front on something you'll enjoy. Immediately upgrading is not cost effective.
If buying used, don't go too far back in time because recent thinking around geometry has been good for the sport by making bikes more fun to ride and riders less likely to crash.
I personally don't feel strongly on the drivetrain question. Either 1x or 2x is good by me. Hydro brakes are nice, but I wouldn't use the word "must". What you'll notice about brakes is that these days mechanical brakes are mainly spec'd on low-end bikes. Tubeless gets pushed harder than it deserves.
JonathanGennick is offline
Old 08-23-19, 07:56 AM
Sidewalk
Quoted: 9 Post(s)
Tubeless is pushed harder than it deserves? That's like saying "these shifter things on your brake levers are over rated, downtube is all you need".
Tubes on MTB need to die, now.
Sidewalk is offline
Old 08-23-19, 11:37 AM
hig4s
hig4s's Avatar
Bikes: Evil Insurgent, Giant Stance, Wife has Liv Cypress, son has Motobecane HT529
Quoted: 93 Post(s)
Liked 7 Times in 6 Posts
Unless your riding style causes lots of pinch flats, or you ride in a area with lots of thorns causing flats, I don't see why the recreational rider would care.
Both my bikes are tubeless ready, yet I have had only three flats in four years with tubes. I see no reason to go through the hassle of changing. Besides, even if you are running tubeless, you need to carry a spare tube if you have tire problems on the trail.
to the OP, 6. full air fork.
hig4s is offline
Old 08-23-19, 11:46 AM
Sidewalk
Quoted: 9 Post(s)
You also gain the added traction and comfort advantage of lower air pressures. Besides the virtually no flats thing.
Maybe it's a roadie thing to suggest tubes?
Sidewalk is offline
Old 08-25-19, 09:13 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
your prices are a bit off
New entry bikes are about 800, mid range models are at least double
used highend hardtail bikes, good examples are 2-3 times what you are estimating
you asked about Giants, some new prices:
entry level: Talon $750
mid level: Fathom $1500
high level: XTC $4000
qclabrat is offline
Old 09-01-19, 02:05 PM
hig4s
hig4s's Avatar
Quoted: 93 Post(s)
Just spent four days at Snowshow resort riding down hill. While I am slow and don't do hardly any jumping, ran as low as 20psi on smooth trails, and ran 25psi on M and O tech trails, not one issue with my tubes. Did see one tubeless rider burp a tire and have to walk out of a technical trail.
hig4s is offline
Old 09-01-19, 04:28 PM
jrhoneOC
Quoted: 64 Post(s)
OP here...so just picked up a brand new 2020 Rockhopper Comp 1x. Its got hydraulic brakes, a 1x9 drivetrain and a basic shock. I got it at a no tax sale saving me a few bucks. It was the only 1x drivetrain bike i saw under $1000. Yes its a microshift system but everyone seems to think its a pretty good system and it was by far smoother than the other low end 2x and 3x drivetrains i test rode. Now to get on some trails!! I will look into a few things down the road. Tubeless (not sure if these are tubeless compatible wheels? I think they are), upgraded shock, maybe going to a 1x12 (microshift makes an inexpensive system that maybe i can swap out some parts and easily get an even wiser gear range if needed.)
Here is a pic....
jrhoneOC is offline
Likes For jrhoneOC:
Old 09-04-19, 01:44 PM
qclabrat
qclabrat's Avatar
Quoted: 257 Post(s)
nice, congrats
qclabrat is offline
breeze14
Mountain Biking
4
02-12-19 07:59 AM
rosefarts
Mountain Biking
33
08-10-17 08:10 AM
deevee
Mountain Biking
15
05-12-15 07:24 AM
supercooper
General Cycling Discussion
3
06-24-14 12:59 PM
formula4speed
Mountain Biking
3
03-05-13 08:19 AM
