Road bike stem needed
Anyone know where to find a 12 degree stem? Got a 12 degree stem now, and that gives me a stem that is parallel to the ground. I need one that is about 100mm long. It has been a few years since I build my road bike, and the 110mm stem is just too long and not comfortable anymore.
Here's what i've found so far:
Specialized s-works SL stem $125
Zipp SL sprint carbon $265
Looking for a stem around 100g, and suggestions would be appreciated. These prices are pretty high to me too.
Dave
Dave
Should Be More Popular
Quoted: 22598 Post(s)
Liked 8,925 Times
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
If you can handle a -17, a Kalloy Uno stem runs about 25 bucks and weighs around 110 grams. I spent an extra 12 bucks or so on titanium bolts ang got mine sub 100. I had one on my climbing bike. Very nice for the price and weight.
Dave
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Dave
Dave
- you don't need to spend this much money on a good stem.
-saving grams of weight will not do anything. You can shave your pubes to account for something if you really wanted to.
Likes For Moisture:
Senior Guest
Bikes: Jamis Endura, Cannondale CAAD, Raleigh Cross, Fausto Coppi.
Quoted: 80 Post(s)
Liked 47 Times
I always thought that -17 degree stems are parallel to the ground. I have several bikes with -17 degree stems.
(Maybe I need to measure it...visually they look parallel)
Quoted: 6193 Post(s)
Liked 4,809 Times
Head tube angle changes a lot on some bike models as you go from the smaller sizes to the larger sizes. Also the specific genre of road bike (or any bike) and the trends of the time period it was manufactured give differing head tube angles.
Senior Guest
Quoted: 80 Post(s)
Liked 47 Times
Sunshine
Quoted: 10963 Post(s)
Liked 7,490 Times
A -12 stem gives you a level stem? So your HTA is 78 degrees?
This costs $50 across the internet. 12deg and 100mm
https://www.jensonusa.com/Specialized-Comp-Multi-Stem
Likes For mstateglfr:
You do need a -17 stem to be parallel to the ground. A -12 would raise the bars by 8-9mm. I've got a -17 x 100mm zipp SL on eBay for $65 delivered, like new.
Quoted: 6963 Post(s)
Liked 10,963 Times
Dave
Dave
A -17 degree stem will be parallel to the ground if the bike's headtube angle is 73 degrees. (17 + 73 = 90)
Likes For Koyote:
Not trying to give you a hard time, but its a matter of simple math, 90-HT angle = stem to get horizontal. Perhaps the lower portion of your stem is angled from the actual centerline of the stem which makes it look likes not level.
Likes For xseal:
Sunshine
Liked 7,490 Times
Regardless, good luck on the search. If you get a 17 degree stem and just set it higher with a couple millimeter spacers, itll be the same effective height as you have now, and you will have access to more stem options.
Advocatus Diaboli
Quoted: 4733 Post(s)
Liked 1,532 Times
Ok, here you go. Not likely though at 100g weight:
https://www.bike24.com/search?searchTerm=12+degree+stem
Liked 10,963 Times
A couple years ago, I built up a bike and used a high-end Zipp stem (100mm) which came with ti bolts. I think the claimed weight was 125 grams.
After seeing the big spacer stack, I'd get a -6 and get rid of 10mm of spacer.
Likes For DaveSSS:
