Why are there more patches than cement?
I remember buying Rema patch kits in these convenient green plastic boxes. Overtime, I’d see different brands, at the LSB cash register, sitting there like candy at the grocery store checkout. Needless to say, I’d pick up a patch kit, knowing that the cement was probably dried out In my current kit.
Well with time on my hands I decided to repair a few punctured tubes. I discovered I had stashed a bunch of patches in a little Tupperware container and repurposed the little boxes for small parts. I figure I typically have 4-5 patches left over per box with dried out cement, and a current surplus of 40 patches
I searched the Forum, and the cement issue has been discussed. I don’t think my leftovers are excessive, instead it’s a conspiracy. I think I‘m getting a value, but the manufacturer is stiffing me on the cement. An extra tube of cement is 20 cent less then the price for kit with 7 patches (on Amazon).
Anyways, any recommendations on alternative uses for these patch or toss them?
Likes For jlmonte:
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times
If you use it before it dries out you will have plenty. I have extra from my patch kit. And it should not dry out if you put it away promptly and seal it tightly.
You obviously aren't getting enough punctures. I suggest you go out and get some more to even things out.
Actually, I'm pretty sure that you can get the tubes of cement by themselves. Also, I'm not sure if the formulation has changed but I'm finding it less of an issue. I've got one kit in particular where I expect to find the cement dried out every time I use it and it just keeps going. In fact I had to order some more patches recently.
Likes For jgwilliams:
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
I haven't had to patch a tube out on the road in ages but carry a Rema kit with me. I only carry new, unopened "glue" and have often found that even that will dry out. A while back I bought a fairly large can of Slime glue and store it upside down (a tip I picked up here on BF).
Likes For Eric S.:
Quoted: 4559 Post(s)
Liked 2,802 Times
Try the self-sticking patches. I've used 'em for the past three years. No problems. No worries about glue drying in the tube.
I've used Lezyne, Park and a couple other brands. They all work fine. I replace them about every year, but even some older patches worked well when I needed them.
Likes For canklecat:
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Expired Member
Quoted: 3665 Post(s)
Liked 5,416 Times
The Slime cement works well for me. It's cheap and readily available at Walmart in the auto section. For home use I buy the small Rema patches in a box of 100. For on the road I carry the self stick Park patches. On these patch threads there is often discussion that nothing other than Rema cement works to properly create a permanent bond. I would not dispute this but IME the Slime works well enough. I've never had a patch fail.
Quoted: 2604 Post(s)
Liked 1,928 Times
Quoted: 336 Post(s)
Liked 309 Times
My guess is that if the glue is running out, too much is being used. Only a thin film of cement is necessary.
Even the small tube covers about a dozen patches for me.
Quoted: 581 Post(s)
Liked 921 Times
My experience with traditional glue-and-patch patch kits is that, properly applied, are as good as a new tube.
Likes For ClydeClydeson:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
So my advise would be to buy a couple more tubes.
Likes For ThermionicScott:
Mad bike riding scientist
Quoted: 6218 Post(s)
Liked 4,217 Times
No, they won’t. Damaged, “unopened” tubes of cement may dry out. I have tubes of cement that are nearly 10 years old that are unopened and have not dried out. As long as the metal tube is unmanaged, there is no way the solvent can evaporate.
Stuart Black
Stuart Black
Quoted: 836 Post(s)
Liked 1,061 Times
To make your vulcanizing fluid tubes last longer roll up the tube as you use it and make sure the fluid reaches the opening so no air is in the tube and make sure the cap is on snug. I always run out of patches before fluid.
Liked 4,217 Times
It’s a balancing act. Don’t put on too little and don’t put on too much. Too little and the bond is weak. Too much fluid and you run out of fluid before the patches.
Stuart Black
Stuart Black
Liked 4,217 Times
Air in the tube is not a problem. Having the solvent evaporate is the problem. Keep the tube tightly capped but you don’t have to worry about air. Cans of fluid have far more air over the fluid than you can ever get in a tube. As long as the can is closed, evaporation isn’t a problem.
Stuart Black
Stuart Black
Liked 4,217 Times
To illustrate my technique here’s a photo montage.
I mark my tubes with a silver Sharpie. It shows up better than other markers. I also make the X super large so that I don’t have to search too hard to find it.
I sand off the marker to make sure that the tube doesn’t have any mold release on it.
This is a 5g tube of fluid that is nearly 10 years old and has been opened for about 6 months. The patch is an F0 which is smaller than the normal Rema patches.
This is how much fluid I usually use. It’s hard to see but it is a fair amount of fluid.
After the solvent evaporates.
Peel off the foil and avoid touching the back of the patch. Then stick it down on the dried vulcanizing fluid.
I fold over the patch to break the plastic cover and then peel it off from the middle to avoid pulling up the patch. You can see the split on the patch above.
The completed job.
I, like many others, save this job so that I can do a bunch of patches at once. The wait time on letting the fluid dry is not critical as long as it is long enough to allow the solvent to evaporate. I’ve forgotten about patching jobs in the past and have gone as long as 2 weeks and still make a good bond. 5 minutes is usually too little...hence the reason to do this job in batches...but I really haven’t found a time that is too much. I wouldn’t wait a year but a couple of weeks is basically “forever”.
The completed job.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,217 Times
Applied right and a good glued patch will last a lot longer than 3 years. I have tubes with up to 30 patches that are probably dragging 20 years of use. Even in the geographic center of goat head country, it takes quite a while to get 30 flats.
Stuart Black
Stuart Black
Yesterday’s work complete. They are from my niece’s and sister in-law‘s Beach Cruisers (I normally keep low stock of 26 in. schrader).
Plastic patch kit boxes and Park sticks-ons.
The tube drawer. And, 4 unopened cement tubes, I already know are dried out. I just saying $2.20 for just the cement, and $2.40 for the kit on Amazon, makes no sense. While, if they said, “Free patches with the purchase on cement!”, I’m on board.
Likes For jlmonte:
Quoted: 4806 Post(s)
Liked 3,927 Times
(Aside: I have two tubes hanging in the bathroom by the garage/shop. Slow leak issues. Tiny, for 23c which I no longer ride. They've got slow leaks. Yesterday I counted the patches on them, 8 and 5. My next bungee cord.)
Ben
Like all bike geeks, eventually you have to ask, why? And I’m glad no one mention tubeless! I thank you all for you comments.
@ThermionicScott
Exactly, and for my rides I have plenty of tubes. I was doing a favor for my brother’s family, who knows how to get freebies from me.🤔
@jgwilliams
I don’t want to jinx myself. I used to get my share of snake bites, when I was young and lazy (poor and stupid). I’d either over or under inflate, ride through glass, and skid flat spots on my tires. Now, I help the young and lazy. These were my niece and sister in-law’s tubes, but they are just unlucky. 😉
@ThermionicScott
@jgwilliams
Likes For jlmonte:
Liked 2,568 Times
Liked 3,927 Times
I'm gonna steal that. Thanks cyccommute !
Likes For 79pmooney:
Liked 4,217 Times
Stuart Black
Stuart Black
