What Model Peugeot Did I Find?
Quoted: 659 Post(s)
Liked 595 Times
Picked up for cheap tonight. Peugeot Mangalite Double Butted frame, Peugeot branded derailleurs, Suntour bar end shifters, Mafac Racer centerpulls, weinmann concave 27” wheelset with Helicomatic rear hub, 2x6, rd has peugeot branding with long cage.
Here are a few pics:
Quoted: 5888 Post(s)
Liked 3,471 Times
UO 14
nice bike, end of the line for the UO 8; 9; and 10
its a sturdy bike, good lock up bike, decent tourer with the strong light 99 crank as well
Likes For bikemig:
Quoted: 4722 Post(s)
Liked 3,036 Times
+1, it appears to be a circa 1983 UO14 converted to bar end shift levers. Unlike the lightweight hi-tensile steel used in the other UO-series models, the UO14 used double butted carbon-manganese steel. Serial number?
Quoted: 1639 Post(s)
Liked 829 Times
My 1982 PH10S had it.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Likes For Chombi1:
Quoted: 659 Post(s)
Liked 595 Times
I found an’82 date code on the Maillard front hub. Still looking this over. I may do a build with it using lighter parts. The Stronglight crankset is a nifty 50/38. Can’t find a date on the nice Lyotard pedals.
Quoted: 659 Post(s)
Liked 595 Times
Fork tube is Tange 2K made in Japan (nothing strange about that ). I may restore, clean up this frame and build to my specs. Pretty sure with my parts bin I can preserve era and bring weight into the low 22lb range, which for me is a good rider. This is the only French bike I have presently and first Peugeot.
Liked 3,036 Times
I committed a typographical error in my previous post. 1984 should have been 1983 - now corrected. While that's not the actual frame serial number, it still indicates the bicycle is from 1983. That actual frame serial number will start with a B or Y. A 1983 date code would not be unusual on a 1983 model. Plus, it has the Mangalite tubing decal indicative of a UO14, which was only catalogued in 1983.
Likes For T-Mar:
Liked 3,471 Times
It might be tough getting this at 22 lbs given the frame tubing and rims. It's a fine bike but not designed to be a lightweight.
Is that one of those Simplex rear derailleurs with a Peugeot brand? Probably a decent working derailleur and no Delrin. Looks like the spokes in the rear may need some attention.
Quoted: 659 Post(s)
Liked 595 Times
Problem with replacing that rear derailleur is that the bike appears to have decent dropouts with, probably, a Simplex derailleur hanger which, if it's like the one on my Peugeot PR10, is unthreaded and without a pivot stop. The hole can be tapped and some people suggest filing the dropout to fashion a pivot stop. You might consider giving the old Simplex derailleur a try. They didn't shift bad, in my experience.
edit: Simplex derailleurs are held onto the hanger with a hex head screw on the back. You probably already know that, but thought it was worth mentioning.
Likes For desconhecido:
Quoted: 659 Post(s)
Liked 595 Times
Well, it's not a terrible bicycle and looks worthy of being repaired and ridden. I'd guess that being 82 or 83 that it might not have the French standard dimensions on things.
Liked 3,471 Times
SE Wis
Quoted: 2747 Post(s)
Liked 3,394 Times
You're going to want one of these from your local homebrew supply for the "aero" headset lock nut.
https://www.kegworks.com/spanner-wrench
Likes For dedhed:
Quoted: 659 Post(s)
Liked 595 Times
Quoted: 659 Post(s)
Liked 595 Times
Here is the UO-14 on a shakedown cruise last night. There was some mention of overall weight. It weighs 23.15 (digital) with the terrible Bontrager B Sport 25’s. With a decent set of Michelins it will be in the 22# range similar to my old 85 Trek 460. It fits and rides just perfectly. Surprised me being a lower level bike than I’m used to.
Components:
-Suntour bar end shifters
-Suntour Cyclone RD (1st gen)
-Suntour Superbe Brakes (levers and calipers)
Stronglight Crankset
Components:
Likes For OldsCOOL:
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
I didn't like the look of the rear wheel in the frame. maybe it was just the camera angle
or just a dishing/truing thing. but it wouldn't hurt to do the string trick to check your
stays alignment
stays alignment
Quoted: 796 Post(s)
Liked 522 Times
The French really had the make gaspipe frames ride like a Cadillac thing down Nice job on the rehab
Likes For ryansu:
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
Whether it's my 1979 U09 Super Sport (first year of Carbolite) or my 1984 PH501 (Reynolds 501 tubes, Carbolite fork), these lesser-tier models give a great ride out on the road at low weight levels for their price points.
Both of these bikes I bought just to clean up and flip, but after riding them, their ride and their style both grew on me.
