Addiction LXXX
Addiction LXXX
Old 10-02-20, 08:07 AM
  #51
datlas
Beyond Bogus
datlas's Avatar
Quoted: 13334 Post(s)
Liked 2,104 Times in 1,104 Posts
Pretty much. I think my SOP is to start just before the valve, but it's all procedural memory. You're supposed to start after?
News to me. I usually start at the valve and end 180 degrees from it. I think I do that because that's how you do tubes, but for tires I honestly don't know if it matters.
What's the deal?
Addiction is all about class.
datlas is online now
Old 10-02-20, 08:08 AM
  #52
MoAlpha
MoAlpha's Avatar
Bikes: Shmikes
Quoted: 4766 Post(s)
Liked 1,839 Times in 1,033 Posts
What's the deal?
Yeah, what IS the deal?
MoAlpha is online now
Old 10-02-20, 08:09 AM
  #53
LAJ
So it is
LAJ's Avatar
Quoted: 6880 Post(s)
Liked 1,573 Times in 901 Posts
Safer? Guy started a thread here about how he cracked a rim with a lever, but I've never used one of those..
The one I posted followed this one. https://kk.org/cooltools/crank-brothers-1/
It uses the same principle of a car tire type machine.
LAJ is offline
Old 10-02-20, 08:13 AM
  #54
WhyFi
WhyFi's Avatar
Quoted: 14343 Post(s)
Liked 3,414 Times in 1,824 Posts
What's the deal?
It can make all the difference in the world with tubeless compatible rims. You end at the valve because the valve takes up space in the bottom of that center well that runs around the rim; you want the tire beads in that well as much as possible for the little extra bit of slack in getting the last bit of bead over the edge of the rim.
WhyFi is offline
Old 10-02-20, 08:17 AM
  #55
phrantic09
Fat n slow
Bikes: Cervelo R3
Quoted: 662 Post(s)
Liked 429 Times in 185 Posts
I’ve always ended at the valve, that’s how I was taught by the shop I got my first bike from.
phrantic09 is offline
Old 10-02-20, 08:25 AM
  #56
MoAlpha
MoAlpha's Avatar
Bikes: Shmikes
Makes sense.
Old 10-02-20, 08:29 AM
  #57
WhyFi
WhyFi's Avatar
How long ago was this, out of curiosity? I think that the old-school way was to start at the valve, and with the rim bed profiles, I don't know if it made much difference one way or the other. With tighter tolerances and tubeless rims becoming ubiquitous in recent years, ending at the valve is a definite advantage, though.
WhyFi is offline
Old 10-02-20, 08:38 AM
  #58
Velo Vol
VFL For Life
Velo Vol's Avatar
Bikes: Velo Volmobile
Quoted: 15383 Post(s)
Liked 613 Times in 429 Posts
DougRNS
Velo Vol is online now
Old 10-02-20, 08:39 AM
  #59
WhyFi
WhyFi's Avatar
Makes sense.
At this point, the beads on your current tires are probably stretched enough that it wouldn't be fair to use them to assess whether this technique will make life easier on you, but if you like the tires otherwise, I would certainly give them another shot. The first few times that I mounted (tubeless) tires on tubeless rims, it was a wrestling match that left my hands blistered. It's gotten easier every time, though, even when revisiting combinations that were a bear the first time around; that makes me believe that technique is the primary difference. Nothing has been remotely difficult in the last two years or so, not with four wheelsets and a half-dozen makes/models of tire.
WhyFi is offline
Old 10-02-20, 08:49 AM
  #60
MoAlpha
MoAlpha's Avatar
Bikes: Shmikes
Yeah, it's got to be a matter of paying attention and optimizing many little variables, like most other skills.
  #61
rydabent
Quoted: 1945 Post(s)
Liked 399 Times in 239 Posts
Very pretty picture. But wet leaves on the ground can be dangerous, because they slip and slide. They will put you on the ground before you can say oh ****!!!!!! Be careful.
rydabent is offline
Old 10-02-20, 08:52 AM
  #62
phrantic09
Fat n slow
Bikes: Cervelo R3
Quoted: 662 Post(s)
it was 2013
Old 10-02-20, 08:56 AM
  #63
Velo Vol
VFL For Life
Velo Vol's Avatar
Autumn is dangerous. Leaves, yellow jackets, walnuts, acorns, cold.
Old 10-02-20, 08:57 AM
  #64
datlas
Beyond Bogus
datlas's Avatar
Thanks for the clarification. I will try to remember this for when I am forced to use tubeless-compatible rims. Of course by then, I will have forgotten.
Old 10-02-20, 08:58 AM
  #65
datlas
Beyond Bogus
datlas's Avatar
Did Bah Humbug snap?
Why do you ask? He is still atop the leaderboard for the week. I do have a chance to take it as I am riding on Saturday and Sunday.
Old 10-02-20, 09:00 AM
  #66
LAJ
So it is
LAJ's Avatar
Why do you ask?
I second that. Why do you ask, and why would you ask in that manner?
LAJ is offline
Old 10-02-20, 09:04 AM
  #67
Velo Vol
VFL For Life
Velo Vol's Avatar
A few days ago he made a post implying that he was dealing with issues. To be clear, we all have issues, and deal with them differently. "Snap" may not have been the best word choice.
Old 10-02-20, 09:07 AM
  #68
bampilot06
Bikes: Cervélo C2
Quoted: 1929 Post(s)
Liked 884 Times in 387 Posts
I had my fitting today, aside from cleat position, shims, saddle position, angle, height and stem height, I had the bike set up pretty well....
It will be interesting to see when ever I get mine done.
bampilot06 is offline
Old 10-02-20, 09:09 AM
  #69
LAJ
So it is
LAJ's Avatar
The written word on the internet is forever.
LAJ is offline
Old 10-02-20, 09:15 AM
  #70
big john
big john's Avatar
Quoted: 1780 Post(s)
Liked 1,154 Times in 695 Posts
wut
big john is offline
Old 10-02-20, 09:30 AM
  #71
datlas
Beyond Bogus
datlas's Avatar
wut
Commentary on the cover page, I reckon.
Old 10-02-20, 09:39 AM
  #72
seedsbelize
smelling the roses
Quoted: 6492 Post(s)
Liked 665 Times in 436 Posts
I did only half a ride because the sky to the north is dark. And we've got another tropical storm incoming, from that direction this time. I had heavy rain inside my room last time and, as luck would have it, I've since stumbled across that half can of crack sealer I knew was here somewhere. So up to the roof I go, shortly. Who would have thought there would be two in the same season? Not me.
seedsbelize is offline
Old 10-02-20, 09:41 AM
  #73
seedsbelize
smelling the roses
I believe it's raining
Reading the directions, it says it can be used on surfaces wet or dry, but they must be asphalt based. I doubt there is an asphalt based roof within 100 miles of where I sit. Possibly within 200 miles though. It comes highly recommended though, and I've used it successfully before. So, when it stops raining, I will go up and give it a go.
Old 10-02-20, 09:53 AM
  #74
bampilot06
Bikes: Cervélo C2
I may regret this but I don’t think they can be worse than my last tire.
Old 10-02-20, 10:00 AM
  #75
Bah Humbug
runner
Bah Humbug's Avatar
Bikes: S1, R2, P2
Quoted: 6452 Post(s)
Liked 1,870 Times in 1,023 Posts
It's pretty accurate. And I feel like crap today, which often goes together with emotional troughs. Don't know if it's a delayed reaction to the flu shot or something else and that sapped all my energy, but right now I can't deal with anything. Tried riding, couldn't warm up, and couldn't wait to get home and curl up on the couch. Sick day.
Bah Humbug is offline
