Reynolds Carbon Wheels - Brake Pads Recommendations?
Old 10-28-20, 11:30 AM
speedyspaghetti
Bikes: VeloBuild VB-R-022 // '89 Specialized Allez Full Dura-Ace 7400
Quoted: 27 Post(s)
Liked 10 Times in 8 Posts
Hey guys -
So I recently picked up a set of Reynolds Thirty-Two full carbon wheels with a Powertap G3 hub for a friggin steal. I finally mounted them yesterday (along with Kool Stop Dura 2 Carbon Pads) and these things rip uphill like nobody's business. However, braking on a steep descent is poop-in-pants-inducing. It seems like after a few hard brakes, the pads are already deteriorating significantly, and, beyond that, braking performance is less than ideal. I have to really yank on the brakes to get a good hard stop (for example when coming down a hill with a stop-sign at the bottom)
I put the Kool Stops on there because I've had good luck with their regular pads on my alloy rims, but I'm not so sure that these are the best. I know that Reynolds has their own blue pads, but a lot of reviews aren't great. There's the Swiss Stop Black Princes for like $40 a set, which others have recommended, but people also say that these wear quickly.
What suggestions do you guys have for pads? Or is this just part and parcel of carbon wheels with rim brakes?
Thanks!
speedyspaghetti is offline
Old 10-28-20, 12:36 PM
datlas
Beyond Bogus
datlas's Avatar
Quoted: 13324 Post(s)
Liked 2,099 Times in 1,101 Posts
I have only used the Reynolds pads. My sense is they stop ok when dry, but you have to squeeze harder/apply more pressure compared to an alloy rim. That’s the price you pay for speed.
Unless, of course, you make the jump to disc brakes.
Addiction is all about class.
datlas is offline
Old 10-28-20, 12:46 PM
mvnsnd
mvnsnd's Avatar
Bikes: Caad10, Caad2
Quoted: 276 Post(s)
Liked 41 Times in 31 Posts
Agreed. I use the Reynolds blue pads with my Reynolds carbon wheels. Ok in dry, need more effort to stop in wet.
mvnsnd is offline
Old 10-28-20, 01:58 PM
wheelingmike
Quoted: 8 Post(s)
Liked 2 Times in 1 Post
I bought a new set of Reynolds Assault wheels about 3 years ago and they came with the blue pads. They worked fine - decent stopping power when dry. Not really ideal for wet. Since I try not to ride when it's wet, it's not a big issue. Once they needed replacement, I bought a new set of Reynolds cryo blue pads and they were not the same! I hated them! They must've changed the formula because there was almost no modulations - it's either on or off. So I got a set of Black Prince on right now and the modulation is so much better. Stopping power is very good, even better than the original blue set. And yes, they do wear pretty quickly. When I need new pads again, I will give the Yellow King a try.
wheelingmike is offline
Old 10-28-20, 03:32 PM
msu2001la
msu2001la's Avatar
Quoted: 300 Post(s)
Liked 165 Times in 116 Posts
Carbon rim brakes and steep descents are a particularly terrifying combo. The only pads I've used that work reasonably well (Swiss Stop Black Prince) have worn very quickly.
msu2001la is online now
Old 10-28-20, 03:42 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 3237 Post(s)
Liked 551 Times in 398 Posts
Nobody ever mentions the campy red pads. Reason? just curious
Sy Reene is offline
Old 10-28-20, 05:46 PM
TrojanHorse
SuperGimp
TrojanHorse's Avatar
Bikes: Specialized Roubaix
Quoted: 1106 Post(s)
Liked 61 Times in 45 Posts
I use the Black Prince pads too. My blue ones squealed like the dickens. Yeah, they wear out but they work well.
TrojanHorse is offline
Old 10-28-20, 07:26 PM
Princess_Allez
Quoted: 150 Post(s)
Liked 45 Times in 29 Posts
Yellow king user here. They work well for me. I only ride in fair weather though, and I don't have any extended, long descents. The first half-life of the pads wears quickly, but slows its rate after that. From what I understand, Black Prince pads stop faster, but also wear faster- including the brake track.
Princess_Allez is offline
Old 10-28-20, 07:30 PM
woodcraft
woodcraft's Avatar
Quoted: 1536 Post(s)
Liked 573 Times in 337 Posts
Reynolds, now on Token (also blue but much less $) which are fine. Didn't like black prince.
woodcraft is offline
Old 10-28-20, 08:51 PM
NoWhammies
NoWhammies's Avatar
Quoted: 616 Post(s)
Liked 218 Times in 135 Posts
So far Mrs. NoWhammies has only used the Reynolds blue pads. Maybe I'll look in to the Token pads when it comes time to replace the existing set.
NoWhammies is offline
Old 10-28-20, 10:56 PM
InvertedMP
InvertedMP's Avatar
Bikes: 2019 Cervelo R3, 2019 Scott Metrix 10
Quoted: 136 Post(s)
Liked 219 Times in 89 Posts
My Reynolds came with Cryo Blue pads. I wasn’t a fan of them and quickly replaced them with Black Prince pads and I am much happier.
www.mp-aviation.com
InvertedMP is offline
Old 10-29-20, 04:01 AM
Fiery
Fiery's Avatar
Quoted: 242 Post(s)
Liked 18 Times in 13 Posts
My guess is that it's a combination of being unaware that Campagnolo pads exist for Shimano-style holders and the general tendency to look for non-groupset manufacturers when buying aftermarket pads. Add to that the image of prestige, style, history of Campagnolo, and people just don't think "I should get me some Campagnolo braking pads for carbon wheels" unless they actually have a Campagnolo groupset and/or Campagnolo carbon wheels.
Fiery is offline
Old 10-29-20, 05:50 AM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Fair enough.. Fulcrum brand red pads are out there too. Noticed that by most reviews campy/fulcrum pads are well reviewed. The Bora carbon wheelsets have been around long enough (1994) that it would make sense that Campagnolo has some history figuring these out.
OTOH, nobody likewise ever mentions Shimano carbon rim brake pads?
Sy Reene is offline
Old 10-29-20, 06:49 AM
Fiery
Fiery's Avatar
Quoted: 242 Post(s)
I have heard good things about Campagnolo red pads, they and Corima red pads seem to be open secret among people in the know. Of Shimano pads I've mostly heard people say they are better than expected (meaning they are perfectly usable), but I haven't really seen them recommended as an upgrade to someone looking for better performance.
Fiery is offline
Old 10-29-20, 08:30 AM
primov8
V8s all day
primov8's Avatar
Quoted: 49 Post(s)
Liked 45 Times in 23 Posts
Another +1 for Campy red pads. If not available, the newer version of the Reynolds Cryo Power blue pads work just as good.
primov8 is online now
Old 10-29-20, 10:32 AM
popeye
Bikes: S works Tarmac, Felt TK2 track
Quoted: 220 Post(s)
Liked 63 Times in 44 Posts
Black Prince.
popeye is offline
