I don't understand this Kryptonite Messenger Mini
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
This is a U-lock with an added U that slides onto the shackle. I just am not getting how this is an improvement. I see how they use it (1:30 in the video if you want to skip ahead), but I don't see how it adds either convenience or security. And, if you're going to crow about how you made a lighter lock then why would you turn around and add another shackle to it?
Messenger Mini+
I did notice in all their videos they are putting both wheel and frame inside the shackle, rather than capturing just the wheel but within the rear triangle. Their current solution to the front wheel is to sell you another lock, rather than have you put it in the lock. They do still sell the longer locks, though.
Messenger Mini+
Genesis 49:16-17
Genesis 49:16-17
Quoted: 18378 Post(s)
Liked 4,512 Times
Kryptonite used to sell a pretty long shackle lock. I've got one somewhere (with the old round key).
I kind of like that idea of the messenger. Two axes.
I might do it differently. Main shackle through the frame and wheel, and the "extender" around a post. I'm surprised, however, that that second extender isn't welded. And a single bolt on the lock?
Kryptonite does sell a chain to capture the front wheel. But, with everything... you'll have a 20 pound lock to lock up your 15 pound bike.
Most of my stops are short enough that capturing one wheel is sufficient. I used to always remove the front wheel and lock it through the U.
Bikes: Death machines all
Quoted: 297 Post(s)
Liked 86 Times
The mini U lock in theory is less susceptible to defeat by a tire jack Your U-Lock Is Basically Worthless, but Don't Worry - CityLab because there is not enough room for the thief to operate. So the hybrid design of this mini lock would offer more locking capacity while being less defeatable than a longer U. An angle grinder does not care about such things, and the locking mechanism in this mini does not appear to engage both ends of the U, so it appears a single but could defeat the bike. Better (and heavier) U locks require two angle grinder cuts.
Messenger Mini+
Messenger Mini+
Work is the curse of the drinking classes - Oscar Wilde
Bikes: Working on replacing my stolen Soma Buena Vista Mixte
Quoted: 417 Post(s)
Liked 95 Times
I have a pinhead security bolt on my front wheel. And the. I use the messenger mini to capture the frame and rear wheel.
I have a mixte frame so there is plenty of frame to keep my lock stuffed when needed.
It is not that unsafe where I park my bike on the street and I use bike lockers when it'll be longer in a less safe place. Works pretty well. Except for maybe at the suburban train stations (if you read my other thread).
I have been using this lock for a year.
I regularly see more expensive bikes than mine locked up a whole lot worse than I have locked. So I locked near them. Think fancy road bikes with quick release wheels or Rivendell's. My bike looks non-descript in comparison and I don't have a head badge or head tube logo.
Bikes: Surly Cross-check
Depends on your frame. On my CrossCheck, I would need a really wide lock to capture the rear wheel, the frame, and a post. I had trouble finding a lock that was wide enough to work without being very long. Most of the time I don't need to lock both wheels because of where I can park the bike, but when I know I will need to, I bring the mini along with my normal U-lock and it works great.
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
A shorter Abus U-lock that locks both ends of the shackle looks like a safer choice to me.
The addition for locking the wheel isn't needed - you could just lock the rear wheel through the rear triangle, with the same effect, but for some occasions it might be a bit more convenient.
Disco Infiltrator
Liked 2,105 Times
They don't claim it is... they rate it 7/10 and it's supposed to be lighter and easier to use. They have many smaller, stouter models, some with the double captured shackle. I get all that. The added piece is what flummoxes me.
Genesis 49:16-17
Genesis 49:16-17
Mostly harmless ™
Liked 216 Times
Just an extra option for locking the wheel. It allows for about extra 10 cm forward-backward bike movement when locking. You can lock it through the rear wheel, like a regular u-lock, or move the bike a bit backward, lock it to the frame and use the added part to hold the wheel. That leaves better position for locking the front wheel to a post, or a U bicycle parking spot sometimes. That's my reasoning at least.
Quoted: 417 Post(s)
Liked 95 Times
Mostly harmless ™
Liked 216 Times
It is way way easier to capture your back wheel with the extra piece on more racks. I used to have a regular mini lock and my city started getting thicker and more square racks in bike corrals. I could never get my rear wheel in those with my lock. Now it works on all the types of city locks we have.
Mostly harmless ™
Liked 216 Times
No need to be skeptical. It's as safe as locking the frame. I've never seen, nor heard of someone's rear wheel getting hacked to steel a bike locked this way. And there's no way to take the bike without cutting the lock, or cutting the rear wheel (and the tyre and the tube).
Disco Infiltrator
Liked 2,105 Times
Yeah, cutting up a rear wheel to get the rest of the bike sounds ambitious, thief couldn't ride off or ghost ride it... not to mention difficult, the spoke tension would clamp down on the cut. I sort of think it would hard to do with a saw and entertaining to watch with bolt cutters.
Genesis 49:16-17
Genesis 49:16-17
Mostly harmless ™
Liked 216 Times
Messenger Mini+
Messenger Mini+
