How to loosen super tight rear cassette lock ring?
Quoted: 800 Post(s)
Liked 512 Times
The lock ring on my Shimano 11speed rear cassette is stuck. And by stuck I mean I can't undo/open the lock ring with the chain whip/cassette tool. That sucker is on there TIGHT!
Anyone have any suggestions on how I can loosen the lock ring?
Thank you.
Thank you.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Cassette tool held on with QR skewer, LARGE adjustable wrench on cassette tool, apply LARGE mallet to wrench while holding the chain whip steady with your off hand.
Sr Member on Sr bikes
Clamp the lock ring tool on a vise. Set the wheel on top to insert it. Use the wheel as your leverage to unscrew it....the same way you’d do with a freewheel.
Dan
Dan
Likes For _ForceD_:
Quoted: 800 Post(s)
Liked 512 Times
@_ForceD_ good suggestion. If only I had a vise.
Liked 2,568 Times
Good tips. I wonder if the through axel (it's not a QR) will hold the cassette tool. And yeah, this might be a good time to invest in a large adjustable wrench. Right now I'm using a set of vice grips.
If you have a QR skewer available, and it's long enough, I think it would be more secure to use that along with a regular cassette tool (i.e. the kind with a hole in the middle, like the Park FR-5.2) and clamp it in place with the skewer, maybe with a fender washer on the NDS to hold the nut in place. It should be pretty secure if you center everything and snug it down. Never tried it though, so I don't know if a typical 135mm QR is long enough to reach the ends of a 142mm TA hub, plus the added width of the cassette tool and any washers. Maybe some 3/8" all-thread rod with nuts and washers would work better.
Expired Member
Quoted: 3674 Post(s)
Liked 5,441 Times
W/O a vise, look around for something else immovable that will hold at least two sides of the lock ring tool. Even 2X4s temporarily tacked down to a deck.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I would hit it with a hammer or mallet only as a last resort.
A proper socket with a breaker bar is what I would use. Pipe on the breaker bar to increase leveage.
Credit where due, the cassette tool with pin recommended by @Metaluna is a great tool.
-Tim-
-Tim-
Dan
mechanically sound
Forgive me if I’m mistaken, but wouldn’t the wheel just “coast” or freewheel if you used it as the “lever?”
Quoted: 2026 Post(s)
Liked 1,096 Times
Nope, doesn't work. If you clamp the lockring tool in a vise and set the wheel on it, you still can't remove the lockring by turning the wheel rim. The freehub freewheels in that direction. The vise will stabilize the wheel but you need a chainwhip around one of the cogs to unthread the lockring.
Expired Member
Liked 5,441 Times
I think the idea was to gain stability and leverage. No reason to not use the chainwhip.
Quoted: 800 Post(s)
Liked 512 Times
Well I ended up going to the LBS and having them crack the sucker for me. They had the proper tools and were able to pop it off. I did/do feel somewhat satisfied though in that the first tool/chain whip selected didn't work and he had to reach for something else/another tool.
Likes For NoWhammies:
Liked 1,096 Times
No, I don't think that's what he was proposing. What he was describing (putting the puller in a vise and using the wheel itself to unscrew the freewheel) does indeed work for a freewheel. It doesn't work to remove a freehub lockring.
Likes For jadocs:
Quoted: 800 Post(s)
Liked 512 Times
Thanks @jadocs. I think I'll have to pick that up the next time I'm at the LBS.
@August West you should have heard the 'pop' noise it made when the mechanic finally loosened it off. There was no way I was going to be able to do that.
Quoted: 645 Post(s)
Liked 797 Times
Won’t work - since the cassette spins the same direction as the lock ring unscrews - hence the use of a chin whip to hold the cassette
Quoted: 1612 Post(s)
Liked 2,594 Times
I had that same problem with a bike I bought. The problem was keeping the whip in place.
Quoted: 1034 Post(s)
Liked 1,292 Times
