Weird Tyre Rotation Arrows
I bought two new Schwalbe Nobby Nics for my MTB. Then, of course I fitted the tyres using the direction arrows. So far so good. Then I fitted the wheels to the bike and checked everything over. Then I saw that the direction arrow on the rear wheel was pointing the wrong way. I looked at the other side and it was pointing the right way. WTF is going on?
Bike facing to the left - arrow points to the front (towards the brake)
Bike facing to the right - arrow points to the rear (away from the brake)
The front tyre is fine!!!!!
Likes For Crankycrank:
Quoted: 18378 Post(s)
Liked 4,512 Times
Any reason why those tires are directional?
Chevron pattern tires are supposed to be directional with the chevron points forward, smooshing water, mud, etc out the back.
But, those waffle tires don't appear directional.
Likes For CliffordK:
Quoted: 427 Post(s)
Liked 700 Times
Just curious--are the sidewalls marked front or rear on them also. Maybe it's recommended to run front and rear in opposite directions?
Likes For freeranger:
Quoted: 3376 Post(s)
Liked 5,518 Times
When copy/paste goes wrong while using CAD equipment.
Likes For Shimagnolo:
Quoted: 2604 Post(s)
Liked 1,933 Times
Bike pictures are always supposed to be taken from the drive side, according to some people. Just make sure the arrows are going in the right direction on that side. Reversing the arrow on the other side can then be taken as a gentle reminder to go to the other side of the bike before clicking.
Of tire rotation arrows could just be a response to OCD reviewers (if there's not an arrow, the tire manufacturer doesn't care enough to make sure you put the tire on the right direction).
Quoted: 1944 Post(s)
Liked 2,164 Times
Likes For 70sSanO:
Liked 4,512 Times
Perhaps the tires are made for a unicycle or trick bike that goes both forward and backwards.
Quoted: 5224 Post(s)
Liked 3,584 Times
probably unidirectional tires & this was their solution to telling the buyers. kinda dumb cuz they could have just not had any arrows. but maybe all their other tires have arrows so they figured yeah, do this
Liked 2,979 Times
smart tire tech doing smart tire stuff.
-Oh Hey!
-Oh Hey!
Must be symmetrical
Although these are two very different tires.
Edit, or not, I guess. Apparently they did have reversed rotation directions f/r, as well as problems with moulding and mixed up arrows. i guess that sort of screw up happens. Google. Add to this there is apparently a new tread design, so who knows. Consider it an invitation to figure out what works best for you?
I’m not too worried about this as it’s only my old cross country mtb, I can’t even do a bunny hop 😂 it’s just a funny thing but I’m also curious as to how this got through the manufacturing process. Weird thing is that the same tyre on the front is AOK.
This is exercising my brain. Is it possible to put this tyre on so that the arrow is pointing in the right direction on the drive side? 🤔
They are directional, you got to look carefully to see it though.
And this from Schwalbe’s web site about how they label front/rear direction arrows.
Likes For Humanbeing757:
Liked 4,512 Times
The tread should be fully vulcanized to the point where there isn't a forward/back distinction.
The casing does have a seam in it, but with overlapping layers that would reduce the significance of that seam.
Tread/casing separation does occur, but I'm not convinced there is a directional component.
I don't remember any discussion about casing separation at seams. Blowouts and tube herniation do occur, so perhaps that would give more information. Still, it doesn't seem like the seams are a major directional component.
There are many road tires that don't have those directional arrows.
Liked 3,584 Times
Likes For rumrunn6:
Quoted: 4806 Post(s)
Liked 3,932 Times
Those tires are for fix gear use. Specifically, for "flip-flop" hubs. If both arrows pointed the same way, half the time the tire would be completely wrong. (And if you believe that, I've got a nice bridge to sell you.)
Likes For 79pmooney:
Quoted: 2338 Post(s)
Liked 2,827 Times
occams razor, they are installed flipped, I have done that so I know.
Take the tires off, and reverse them and re install so that with the cassette faceing you the direction is facing forward.
Quoted: 2483 Post(s)
Liked 2,955 Times
Bikes: 2016 Cervelo R3 & 1999 Litespeed Tuscany
Quoted: 159 Post(s)
Liked 138 Times
I had some Mavic Yksion tires which were directional with the front tire installed the opposite way of the traditional direction. It could apply on these tires as well.
Go to 2:11....
Go to 2:11....
