MKS GR-9's, huh?
No cud for foil.
MKS GR-9's, huh?
Howdy.
I'm looking at the MKS GR-9's for my fixie project, because I like the soft-sole business, but I do want double straps.
My quandary, then, for you all to resolve, relates to the double-strappability of these pedals. A fellah who I work with says that double straps and GR-9's don't work, but I don't believe him, though am yet unwilling to buy away, potentially to my own ruin. Any personal experiences? More specifically, do they have two sets of slots to accomodate? Thankee much.
Paste Taster
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
I have seen it done and apears to work fine
edit: I would try the soma quad gat clips they just came out with
No cud for foil.
The Soma clips sound like a good option. I'll probably end up getting their straps, too, unless I can find a cheaper pair that's laminated.
Really, there's no reason it shouldn't work well. I just wanted to put myself at ease.
Edit: Oops, check this out.
"haha those gr-9s are actually really really comfortable, i would have them on my bike right now were it not for their inability to incorporate double straps- i get paranoid about strap breakage and like the feel of strap security, both physically and structurally; but hey, if you're not worried about that sort of thing, then definitely get the gr-9s"
Ripped from the archives. Eff it. Maybe I'll be a bastard and just get Sylvans. Will my feet cozy up to them, or am I going to wear through my treasured sneaks?
Paste Taster
dude get the errebis or run two laminated single stras instead trust me you wont regret getting leminated straps they are more durable stiffer and more secure
loser.
Paste Taster
Originally Posted by tylergarrison
Well, i'm no search wizard, but I do remember there being a picture posted of someone's double strap setup on a pair of GR-9s on this board. The pedal itself does not have 2 slots to accomodate double straps but you can run the second strap under the body of the pedal and, if memory serves me correctly, zip tie it in place or just keep it tight enough to not slip out of its place under the pedal. Make or otherwise acquire one of those leather strap couplers/holders (no idea of the real name but I know a few people on this forum make them) and you should be good to go.
Like I said, I can't come up with that picture at the moment but it was around here somewhere. Double straps with GR-9s are possible if you don't mind taking the time to make them work.
No cud for foil.
Good to hear, all of it. Doubles really aren't overrated, though. I wouldn't ride fixed with just one pair of straps.
Paste Taster
I ride doubles for a comfort thing not so much safety or security as you can acheive those with a quality single strap
my rx-1s however wont work with doubles but I plan to use em
THIS SPACE FOR RENT
One way to do it is to replace the stock bolts that hold on the clips with really long ones that go almost all the way to the spindle, then you have something for the strap to be under rather than it just flopping around.
or tarckeemoon, depending
Bikes: Davidson Impulse, Merckx Titanium AX, Bruce Gordon Rock & Road, Cross Check custom build, On-One Il Pomino, Shawver Cycles cross, Zion 737, Mercian Vincitore, Brompton S1L, Charge Juicer
Dimension/Wellgo track pedals are <$20 and have slots for two straps without the protruding dust caps that Sylvan track pedals have. They are pretty narrow though - almost too narrow for my bigass feet but I wanted plenty of cornering clearance.
Utilitarian Boy
Bikes: Check the sig to find out
Bikes: White IRO Angus
I ride Toshi doubles on gr-9's w/ no problem at all. I did replace the bolts w/ longer ones to better hold the second strap, but otherwise, they work fine.
No cud for foil.
That sounds like a wondrously enticing option. Is finding the longer bolts too difficult? If not, they might be the money.
redonkulous
Bikes: 2001 GT GTB
If all else fails, PM me and ill throw a few in an envelope and send em. I think I have the perfect bolts with matching nuts. if they dont work, im out 39 cents and youre still on the hunt.
Paste Taster
hardware store
THIS SPACE FOR RENT
Originally Posted by Retem
hardware store
Exactly. Take an existing bolt in with you, they usually have little gauges over in the loose hardware section and you can find out exactly what size it is. Be sure to get the right threading as well as diameter, most places have thread gauges but you can also just lay the bolts against each other and tell instantly if they are the same threading.
shadybikes
in my experience, double straps did not work with gr9 to the full capability. they will work but if your set on doubles i suggest sylvans but since your going with soft soles i would point out the kashimax single straps. they are priced like a set of doubles but they are amazing! Also, Soma double straps are nothing but fashion, they dont hold your feet in at all.
Originally Posted by Gyeswho
i agree. they are narrow but the design is great for corner clearance. i got a used pair for free from my bike shop
i'd leave the sweet stuff
Bikes: BCA ten speed / 2007 bfssfg group buy IRO
Originally Posted by adampaiva
anyone know the cheapest place to buy gr-9s?
harris has them for $29.95.
https://sheldonbrown.com/harris/pedals.html#platform
if you have a good LBS they may get them for you sans shipping or even at a discount if they like you...
How wide are the GR-9s? I'm running Sylvans right now, but they are too narrow for my feet; I overhang by about an inch. Which is fine for short, around-the-neighborhood rides, but anything longer starts to build up hotspots right where the pedal ends. Are the GR-9s wider than the Sylvans?
https://www.pedalroom.com/members/iamtim
roll'em high
